What is the adhesive or tape of choice for installing
the rubber tail skid with roller blade wheel on the bottom of the boom? How often does it need to be re-installed? Thanks Brian |
evostik and "tesa" fabric aileron tape.
I've used plain ol' contact cement. I don't remember
the brand name, but I find it at hardware stores and home supply stores like Lowe's and Home Depot here in North Carolina, USA. I haven't quite got the knack for putting it on straight, but I'm getting pretty good at putting them on crooked. Just a little. Getting it straight is a really good idea if taking off on pavement. On grass, there was never a problem. I removed it and glued it back on, finding out that the contact cement was pretty tough. I'm sure I wasn't using the 'right tool for the right job': I was using what I had available. Yep, screwdrivers and a putty knife. I put a few scratches in the gel coat as I pried the sucker off, but I did get it off. And I don't know of any need to reglue it except when it starts to come unglued. Ray Lovinggood Carrboro, North Carolina, USA At 20:42 21 June 2004, Sf760 wrote: evostik and 'tesa' fabric aileron tape. |
Subject: Rubber Tail Skid Installation
From: Brian Iten Date: 6/21/2004 1:10 PM Pacific Daylight Time Message-id: What is the adhesive or tape of choice for installing the rubber tail skid with roller blade wheel on the bottom of the boom? How often does it need to be re-installed? Thanks Brian I have glued on tip skids with "Goop" that were on over a year, then broke the gelcote trying to knock one off on purpose. Sawed the other one off and sanded the rest down flush to the skin. Not sure if you want that secure of a bond...... - Mark Navarre 2/5 black ace LoCal, USA remove brain to reply - |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
Tail Skid Help / Advice | Ray Lovinggood | Soaring | 3 | January 2nd 04 08:16 PM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Owning | 1 | July 26th 03 11:34 AM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
