First Glider LS4
Old September 10th 04, 02:18 PM
John Doe
Well if you are looking for an easy flying glider...you
can't go too far wrong with a Discus, it doesn't get
the same rave reviews of handling like the LS4, but
is still one of the nicest gliders I've ever flown
and it is slightly newer without getting into the realm
of Discus 2's, ASW28's and other really expensive modern
German glass.
Barn door airbrakes make field landings easy, decent
enough wheelbrake, launches easy, docile stall, goes
like the clappers and is forgiving of most indescretions
in thermalling.
At 13:06 10 September 2004, Waduino wrote:
I'm still building my experience before buying a first
glider, and from
reading RAS over the past year or so, I've also concluded
that an LS4 would
be a great choice.
Is there a newer model plane that people adore as much
as an LS4 for its
good balance of performance and behaviour?
Thanks.
Waduino.
'Jeff Runciman' wrote in message
Thank you again for your advise. Any more thoughts
on the LS4? Any concerns with the age? What should
I pay for one? And are there any flying groups for
the LS4? Thank you again and I hope I can contribute
to the group as I go along.
Jeff
Old September 10th 04, 02:50 PM
Ventus B
The wheel brake in my LS4 was also ineffective at first. Turns out all
I needed to do was a minor adjustment, and then you could put the
glider on it's nose. Secondly, there is also the possibility of
having the brakes modified (I believe by a motorcycle shop in
California) that will make the drum brakes very effective.
The LS4 was my first glider and a great one too. I couldn't have
asked for better handling and docile stall characteristics. It's
strong as hell, and the manually connected ailerons and spoilers were
a snap. In fact it was easier and faster to assemble my LS4 than my
second glider which was a Ventus that had automatic control hookups.
You can't go wrong with a well cared for LS4.
Stefan wrote in message ...
The LS 4 is one of the most docile gliders I've ever flown. In some
European clubs it's even used as first solo training glider! The age is
no factor, the shape it's in is. Later LS4s have authomatic hook ups,
early ones don't, this should be reflected in the price.
The LS 4 has two negative points: One is the bad surface quality.
Depending on the use, they need a refinish rather soon. (In a club
environment after 15 years or so.) So take a careful look. The second is
the wheel brake. The wheel brake is a joke. This can be a problem if you
have to outland in a short field.
Stefan
Old September 10th 04, 03:21 PM
Tim Mara
"Waduino" wrote in message
I'm still building my experience before buying a first glider, and from
reading RAS over the past year or so, I've also concluded that an LS4
would
be a great choice.
Is there a newer model plane that people adore as much as an LS4 for its
Thanks.
Waduino.
Yes!.....HpH Glasflugel 304C!
newer...(new) nicer quality, better performance, all automatic control
hook-ups, better brakes, hinged panel, nicer cockpit, and even nicer
handling, etc etc etc
tim
Old September 10th 04, 04:35 PM
Andy Durbin
Marc Ramsey wrote in message . com...
Make sure you check with the insurance companies (through the SSA
program, or otherwise) before you buy anything. They have very specific
experience requirements that will determine whether they will provide
you with a policy at a reasonable price, and even whether they will
insure you at all. One big factor is going to be the number of hours
you have in over 35:1 gliders...
Marc
For the SSA plan the experience levels are set by flights in 35:1 or
greater not hours. That can make a huge difference. I've just been
through getting my inexperienced (flying that is) wife insured for my
ASW 19b.
Andy
Old September 10th 04, 05:20 PM
Stewart Kissel
than my
control hookups.
Mr B.-
RU positioning flaps in negative and being sure to
lift up a little on the trailing edge as the wings
go in? I time myself to make sure no lying here, and
I can consistently rig by myself with a rigger in 30
minutes from trailer top up to tape finished. Once
the first wing is in and positioned correctly...as
long as one is careful with the second wing for the
last 1'...I generally don't need help for the final
push from the other wing. Some guys also teflon the
fuse surface that the spar rubs on...but I find the
key is proper alignment...and a rigger helps with this
quite a bit. Also a nice flat asphalt surface.
Old September 10th 04, 05:26 PM
solo89
I bought an LS4a just a few weeks ago. The insurance company asked
about the number of flights in 35:1 or greater. They didn't seem as
interested in hours. The question about hours did not reference l/d.
The question about flights did.
I had 99 flights in 35:1 or greater (total 103 flights). My hours were
pretty low. Something like 20 hours pic. In talking to others, I think
I have a pretty normal rate.
For me there is very little conversion. The only thing to adjust to is
a cg towhook. So far, that hasn't been an issue.
The glider is easy to fly. Coordination is much easier than G102/103.
I think now I can begin to shift some of my effort to what I want to
do with the glider and away from the mechanics of flying.
Tomorrow looks good for flight number 3. Wish me luck
Doug
Marc
Old September 10th 04, 05:39 PM
Marc Ramsey
Stefan wrote:
Higher premium because of low time in "anything" may make sense, but
because of low time in over 35:1 certainly doesn't.
If you consider that, here in the US, time in "under 35:1 gliders" often
means Schweizer 2-33, it starts to make sense...
Marc
Old September 10th 04, 05:59 PM
Matt Herron
I've been flying an LS-4 for the past two years. Everything said about
it in this forum is true -- it's a great first glider, responsive,
forgiving, with excellent thermalling and Xcountry qualities.
There's also a very good owners forum on Yahoo with lots of people
offering helpful advice:
http://sports.groups.yahoo.com/group/LS-gliders/
Negative points:
Surface: Mine has some gelcoat degrading near the wing roots but I
very much doubt if it affects performance much at all. I briefly
considered refinishing (expensive) but then decided to live with it.
Wheel brake: Admittedly not great, but there are ways to deal with it.
Search for the brake discussion in the Yahoo forum.
Tail wheel: A much more annoying problem in my estimation. In American
versions of the LS-4, a wheel the size of an in-line skate wheel is
mounted on a rubberized skid. DON'T ATTEMPT TO PUSH THE GLIDER
BACKWARD WITHOUT THE TAIL DOLLY. The skate wheel will swivvel sideways
causing all kinds of problems, the most serious of which is that the
glider may run off the runway on tow unless the tail wheel is lined up
carefully. I finally replaced the skate wheel with a decent sized tail
wheel, and all the problems disappeared.
Main wheel gas strut: When the gear is extended, it's locked in place
by a gas strut. These struts weaken after a few years of use and must
be replaced. Otherwise the gear may collapse on landing or (as mine
did) on takeoff. By all means make this your first maintenance check
if you buy an LS-4. The replacement strut is not particularly
expensive, and it's a hellofalot cheaper than a belly job. Again,
check the Yahoo forum for advice.
Please don't be put off by these negative points. Every glider has its
defects, but the LS-4 is a glider to love.
Old September 10th 04, 06:35 PM
Stefan
LS 8
Old September 10th 04, 06:50 PM
Mark James Boyd
Keep in mind that you are really talking about something different
from the hang gliding idea. An LS-4 vs. a Russia is different
in terms of landing out. Pulling something apart in a
field or short strip somewhere and getting the trailer
through the dirt with 300# vs 600# of glider is different.
I always had a hand disassembling the PW-5, and maybe
bought someone dinner for helping. With some gliders,
a lot of people scatter, or you might need to buy them
dinner subtle off color remark begins AND make them breakfast
subtle off color remark ends.
I'm going to go assemble a pegasus this weekend just to
feel the wings. If you have a chance, before buying,
disassemble the glider you are thinking of. Try a
PW-5/AC-4or5/Sparrowhawk, then try the LS-4.
Maybe it won't affect your decision, but it might
get you to buy wingstands or a gym membership...:P
Mark J. Boyd
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 10:41 AM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 12:18 PM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 04:50 PM
