Polar Analysis from flight logs?
Old January 11th 05, 02:51 PM
Robert Ehrlich
Robert Ehrlich wrote:
After this discussion we are far from the original question, i.e.
can we infer anything about the polar of a glider just from GPS
fligth logs of this glider?
... solution proposed ...
After a bit thinking about that my conclusion is that the above
solution doesn't work. Even if the system I was talking about
is overdetermined, there is always an undetermination on the couple
vertical speed of airmass/sink speed of glider relatively to airmass,
any combination of both with the same sum satisfies in the same way
the equations, so no valuable information on the polar of the glider
can be obtained unless we add some information on the airmass, either
by some other data, or by some further modelling (e.g. assuming the
total vertical movement of the airmass is zero, which is not realistic,
or that it is some given percentage of the average lift, or anything we may
think about it)
  #82
Old January 11th 05, 05:06 PM
Eric Greenwell
think about it)
Maybe the laser airspeed devices could be applied to flight testing, but
by having them on the ground instead of in the glider. Pointing up, they
could be used to determine how much the atmosphere is moving during a
conventional, Johnson-style, flight test. The data could then be
corrected with this measurement of the actual air mass movement.
It would take units designed for long range measurements (meteorological
instruments, likely), of course, not ones really designed for airspeed
indicators.
Or, perhaps the laser unit could be used to determine when the airmass
is steady enough to make flight testing worthwhile, even it if can't
measure the vertical velocity sufficiently accurately to make
corrections useful.
Eric Greenwell
Washington State
USA
  #83
Old January 12th 05, 11:15 AM
Robert Ehrlich
think about it)
indicators.
corrections useful.
OK, but this is far from the original question. Making Johnson-style flight
tests is one thing, using flight logs for polar analysis in another one.
A flight log provides some information about the polar as long a we have
or can assume some information about the airmass. We have here a huge
quantity of data it would be intersting to use. We could get some information
not found in flight test, like how far various gliders of the same model
are from the tested one, how performance degrades with time, ...
  #84
Old January 12th 05, 07:43 PM
Eric Greenwell
corrections useful.
I think the thread drifted from the original question because no one
could think of how to account for the airmass movement in any useful
way, so people began thinking of what the next best thing might be. A
new proposal on how to achieve a polar from flight logs would bring the
thread back to the original subject, I think.
Here's another way that flight logs might used: Comparison flights using
GPS logs to determine the difference between gliders would be useful,
but that requires at least two gliders to fly together at the same
airspeed; again, useful, but as you point out, not an answer to the
original question.
Eric Greenwell
Washington State
USA
  #85
Old January 13th 05, 12:03 AM
Mike I Green
Wouldn't it be sufficient if the other glider was calibrated?
mg
corrections useful.
flight
information
original question.
  #86
Old January 13th 05, 12:05 AM
Mike I Green
mg
corrections useful.
flight
information
original question.
  #87
Old January 13th 05, 12:06 AM
Mike I Green
mg
corrections useful.
flight
information
original question.
  #88
Old January 13th 05, 12:34 AM
Eric Greenwell
mg
I'm not sure what you mean by sufficient, but in any case, using a
comparison sailplane (calibrated or not), was not what the original
poster had in mind.
The advantage of a using a calibrated sailplane for the comparison is
you could actually calculate a polar, rather than just a relative
performance curve. Perhaps that was what you meant?
using GPS logs to determine the difference between gliders would be
useful, but that requires at least two gliders to fly together at the
same airspeed; again, useful, but as you point out, not an answer to
Eric Greenwell
Washington State
USA
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
