In a classic left turn traffic pattern stall spin that is caused be a
cross control attempt to rudder a turn to align the ship to final after it breaks over the top which way is it spining and what is the proper recovery? In a steep left turn coring a strong thermal at low altitude the outside or high wing enters the surrounding down and the spin over the top happens, which way is the glider spinning and what is the proper spin recovery? No time to think correct answer please your life depends on it. |
At 19:00 16 January 2005, Greg Arnold wrote:
'Apply full rudder opposite to the direction of the yaw string' -- what does that mean? What is the direction of the yaw string? If the loose end of the yaw string is on the right side of the canopy, is the direction of the yaw string to the right, or is it to the left? Seems like there is some potentially confusing terminology being used here that I've never heard before. I've always been taught that the the 'direction' of the yaw string is the side of the glider it leans to, and so you correct by pressing the rudder on the opposite side. Here I think people are saying that if the yaw string is displaced to the right side of the glider it is 'pointing' left. While I can understand how you might naturally want the front end to be the tip of the 'pointer', I think it's confusing to refer to 'pointing' at all because of this left/right confusion. I prefer to say the yaw string is 'to the left' or 'to the right' as position is less ambiguous that the 'pointing' direction. To be honest, I've never looked at the yaw string in a spin as it has never been ambiguous to me which way the world was turning - if the world is going round and round counter-clockwise how can this not be spinning to the right? I guess I presumed that for a spin to persist the glider would have to stay skidding, but in a fully established spin you might wonder, if the yaw string was far enough forward (say in a two-seater), whether the rotation overcomes the skid in terms of the local flow across the canopy - apparently not given the comments here. Boy I'd hate for that to be wrong though. Years ago when I was flying a Ventus A 16.6 (easy to spin unintentionally in my experience) I taught myself that if the inside wing in a turn ever dropped, to push the stick forward and into the turn and to hit top rudder. You try to make it as instinctive as possibe, but it takes practice. The top rudder is the easiest part - the stick movement is against most people's instincts. 9B |
It means exactly the same rudder direction you apply
in any other, non spinning, yawed condition (how could it be otherwise as the string doesn't change its mode of action in a spin?). The front end of a yaw string is stuck to the canopy and if the loose end is pointing left in a spin you apply apply right rudder. I have never heard of anyone referring to the front end of the yaw string being the way that it is pointing. If they do that in the States the wording could be changed. However, since pilots have ingrained into thenm the wording 'full opposite rudder' for spin recovery, I would strongly suggest retaining the word 'opposite' and referring to the loose end of the yaw string as the way it points. There is nothing new to learn in what I suggest - I just picked it up from Reichmann's book. The change in emphasisis just that the attention is directed to the yaw string in any case of doubt rather than to watching the houses whirling about. John Galloway At 19:00 16 January 2005, Greg Arnold wrote: 'Apply full rudder opposite to the direction of the yaw string' -- what does that mean? What is the direction of the yaw string? If the loose end of the yaw string is on the right side of the canopy, is the direction of the yaw string to the right, or is it to the left? I think you mean that if the loose end of the yaw string is on the right side of canopy, you apply right rudder? Or the opposite of the normal rule? The yaw string *always* points to the inside of a spin (according the Reichmann and others) and modifying the teaching to 'apply full rudder opposite to the direction of the yaw string' would be a more certain way of choosing the life rudder pedal rather than the death one at low altitude |
On the same topic, I entered an unintentional stall spin for the first
time last year. I have about 1,000 hours in gliders and 450 hours in my ASW 20. I was flying fully ballasted in a cross-country contest task on a typical Arizona summer day with strong, turbulent thermals. Entering a thermal, I eased into a left bank, slowing down and applying flaps as I've done thousands of times. However, I overshot my normal fully-ballasted zero flap setting and went to plus 1 instead. Suddenly, I was aware that something was wrong. The air went quiet, the controls went sloppy and suddenly the yaw string pointed left and slightly away from me. For a moment or two, I didn't have a clue as to what was happening. The glider then fell sideways out of the thermal. Following the clue of the yawstring, I centered the stick, applied full right rudder and full negative flap. The glider recovered immediately, but lost a few hundred feet in the ensuing dive out as I recovered airspeed. I never got any sense of rotation. From my log file, it looks as if I overshot the center of the thermal and entered severe outflow windshear. With the airspeed gone, aided by a tad too much positive flap, the glider momentarily quit flying and dropped sideways. The yaw string was my only clue as to what was happening. I agree with others that the experience was totally different from spin training, in which the spin entry is expected. The problem is recognizing what is happening and you don't have time to scan instruments. The yaw string is the most responsive and most effective inidicator of unusual airflow. Mike ASW 20 WA |
John Galloway wrote:
It means exactly the same rudder direction you apply in any other, non spinning, yawed condition (how could it be otherwise as the string doesn't change its mode of action in a spin?). The front end of a yaw string is stuck to the canopy and if the loose end is pointing left in a spin you apply apply right rudder. I have never heard of anyone referring to the front end of the yaw string being the way that it is pointing. Really? I picked it up somewhere in my instruction. Something to the effect of "Think of the yaw string as an arrow with the head attached to the canopy. It points to the the rudder pedal you need to push to coordinate." Seemed very natural and simple to me. Shawn |
At 23:00 16 January 2005, Shawn wrote:
John Galloway wrote: It means exactly the same rudder direction you apply in any other, non spinning, yawed condition (how could it be otherwise as the string doesn't change its mode of action in a spin?). The front end of a yaw string is stuck to the canopy and if the loose end is pointing left in a spin you apply apply right rudder. I have never heard of anyone referring to the front end of the yaw string being the way that it is pointing. Really? I picked it up somewhere in my instruction. Something to the effect of 'Think of the yaw string as an arrow with the head attached to the canopy. It points to the the rudder pedal you need to push to coordinate.' Seemed very natural and simple to me. Shawn So that's the pedal you'll want to press in a spin. Use your way of thinking about it. No dispute between us. See Mike the Strike's posting. John Galloway |
![]() Really? I picked it up somewhere in my instruction. Something to the effect of "Think of the yaw string as an arrow with the head attached to the canopy. It points to the the rudder pedal you need to push to coordinate." Seemed very natural and simple to me. Yes. I use this most often with transitioning power pilots who are taught to "step on the ball" of the inclinometer ("step on the head of the arrow"). With ab initio glider pilots I start with telling them to add rudder on the opposite side of where the tail of the string is pointing. If that doesn't work, I switch to the above. Tony V. |
John Galloway wrote: It means exactly the same rudder direction you apply in any other, non spinning, yawed condition (how could it be otherwise as the string doesn't change its mode of action in a spin?). The front end of a yaw string is stuck to the canopy and if the loose end is pointing left in a spin you apply apply right rudder. I have never heard of anyone referring to the front end of the yaw string being the way that it is pointing. Really? I picked it up somewhere in my instruction. Something to the effect of 'Think of the yaw string as an arrow with the head attached to the canopy. It points to the the rudder pedal you need to push to coordinate.' Seemed very natural and simple to me. Yes, it is pointing into the relative wind; point the glider toward that. Shawn |
![]() "Nyal Williams" wrote in message ... We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. View the string as a pointer. The forward end (the point) points at the required rudder pedal. Duane |
![]() "Duane Eisenbeiss" wrote in message ... "Nyal Williams" wrote in message ... We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. The above post was incomplete. Over sensitive Send button. View the string as a pointer. The forward end (the point) points at the required rudder pedal to continue the turn or stop yaw. Therefore opposite rudder in a spin would be the other rudder pedal or the top of the string. Duane |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
String in the middle does not protect you from a spin | Jim | Soaring | 10 | January 30th 04 02:57 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
