Yaw String in a Spin
Old January 16th 05, 11:05 AM
John Galloway
Default Yaw String in a Spin
In another thread Ian Strachan wrote:
'The standard recovery procedure once a full spin has
developed that
works for most aircraft is,
1. Full rudder opposite to the spin direction (make
sure it really is
opposite to the rotation, I for one have applied the
wrong rudder in a
spinning jet when I was caught by a surprise departure).'
I have long surmised that application of the wrong
rudder in a panic situation might be a cause of failure
to recover from a spin. If it can happen to a military
test pilot of Ian's calibre then it can certainly happen
to me.
The yaw string *always* points to the inside of a spin
(according the Reichmann and others) and modifying
the teaching to 'apply full rudder opposite to the
direction of the yaw string' would be a more certain
way of choosing the life rudder pedal rather than the
death one at low altitude
Slip balls do not, apparently, invariably point to
the outside of spins so they are not as certain a guide.
'Every saiplane should have a yaw string' - said Helmut
Reichmann for this reason.
John Galloway
Old January 16th 05, 12:23 PM
John,
interesting thoughts. Even with strong visual cues, the more nose down
a spin, the more difficult it might be to surmise its direction. Thus,
a quick reference to the yaw string is in order. Isn't the Pooch known
for its nose down attitude while spinning?
Yet another reason to put the emphasis on stall avoidance and prompt
recovery from prestall conditions. A suprise stall and autorotation at
low altitude presents a great a risk, even for well trained, heads-up
pilots.
Old January 16th 05, 03:48 PM
Papa3
I agree that this is an interesting point. Even experienced, current pilots
can be caught off guard, and perhaps a better training/recognition method
might be in order. Maybe the yaw string can/should be a more integral
part of the program in terms of spin recovery training?
For what it's worth, I have had a couple of unintentional spin entries over
the last 20 years. One in particular sticks in my mind. A guy at the
local gliderport is an experienced aerobatics competitor; he owns a two
place Fox aerobatic glider. He asked me to go up with him one day, since
he was having some trouble getting the Fox to climb. He figured thermals
were a lot cheaper than 5,000 foot aerotows.
We got into a moderate thermal, and I took the controls to show him how we
"real" soaring pilots thermal. I cranked us over to 40 degrees of bank to
core the thermal. "Now, watch how I slow us up to really tighten the
circle..." I said. The owner mentioned that I ought to "be a little
careful [since] stall speed at this..." He never finished the sentence.
Departure was instantaneous. Rotation was spectacular. I recall at first
doing everything wrong. It took me at least one full revolution to realise
that the glider was spinning, and I think it was a couple of seconds more
before I figured out the direction. Fortunately, we were at least 4,000
AGL at the time, and the owner just sat back and let me figure things out.
This flight came on a day when I had been the duty instructor in the club.
I had probably done 4 or 5 incipient spin lessons earlier in the day, and I
probably had 40 hours flying in the preceeding 90 days. So, I was current
and reasonably on top of my game.
This experience just reinforced the fact that the ability to recognize a
spin, especially an unplanned one, is probably not an easy thing to teach.
The normal training mode is thoroughly unnatural, as the student is primed
and ready. The reality is a lot different, and I'm wondering if any of us
emphasize the recognition aspects of the immediate post-departure moments
enough?
Erik Mann (P3)
John,
pilots.
Old January 16th 05, 04:43 PM
John Galloway
Since my original post today I mentioned the subject
to 2 instructors round the table at our club. One
had himself applied the wrong rudder in a spin and
he had also experienced a pupil doing the same.
When I was first taught spinning (aged 17 in 1969)
it was not immediately intuitively obvious to me which
way I was rotating without thinking back to what direction
the glider had been circling before departure - or
which wing had dropped if the instructor had started
the spin from a level stall. I confess that during
spin training, as the instructor started the spin
entry procedure, I made sure that I mentally rehearsed
in advance which rudder to apply - which rather defeated
the point I guess.
John Galloway
current pilots
method
be a more integral
spin entries over
mind. A guy at the
he owns a two
He figured thermals
to show him how we
'real' soaring pilots thermal. I cranked us over
core the thermal. 'Now, watch how I slow us up to
really tighten the
circle...' I said. The owner mentioned that I ought
to 'be a little
careful [since] stall speed at this...' He never finished
the sentence.
I recall at first
in the day, and I
So, I was current
to recognize a
enough?
Erik Mann (P3)
roups.com...
John,
the more nose down
the Pooch known
and prompt
and autorotation at
trained, heads-up
pilots.
Old January 16th 05, 05:03 PM
Tony Verhulst
Since several experienced pilots have said that they have had trouble
determining the direction of the spin, I accept that it happens - and
that it can happen to me. I do not understand why. Most glider spins
happen when turning and, in the hunderds of intentional spins that I've
done (I have only one unintentional spin), the glider spins in the
direction of the turn. What am I missing? I do like the yaw string idea.
Tony V.
Old January 16th 05, 05:32 PM
Stewart Kissel
The first time I went over-the-top into a spin...it
definitely took a minute to figure out the rotation...others
experience may vary.
I was thinking about this topic and came up with this
observation....
1.) Training spin fatalities seem to happen from a
distance above earth that involves several rotations
before impact...for whatever reason, the spin developed
and could not be stopped.
2.) Inadvertant spin fatalities seem to almost always
occur so low (base to final)...that once the spin has
started, proper recovery probably would not save the
pilot.
So IMHO...are we really training for what is occuring?
have had trouble
it happens - and
Most glider spins
spins that I've
spins in the
Tony V.
Old January 16th 05, 05:46 PM
Nyal Williams
developed that
sure it really is
wrong rudder in a
to me.
John Galloway
Good post, but I must point out a trap. I learned
from a student that it is easy to misunderstand which
end of the string is doing the pointing.
I always taught students to 'step on the head of the
snake.' One student could never get it right (never
been around snakes) and he was stepping on the tail
-- the aft, unattached end. I found that other students
had figured out their own way of bringing the string
into line and just ignored my comments.
We should have a conversation with students specifically
about which end of the yaw string is the pointer/tail/indicator,
etc. and which foot does what to that end of the string
under discussion.
On the other hand, perhaps my analogies are just weird.
Old January 16th 05, 05:57 PM
Ken Kochanski (KK)
I had a two turn spin in my 20 a couple of years ago at a Mifflin
contest. The ship was in a coordinated right 45 degree bank, nose on
the horizon, and I was making my third searching circle attempting to
center the strong core of a good thermal. I was stable and coordinated
in the turn when the tail pitched up violently and the ship rolled
inverted to the right. My first thought was that I got hit by another
glider ... but since my searching couldn't locate another ship, I then
thought something broke. (It's amazing how time slows down in these
situations...) Entering the second rotation, I figured I was high
enough (4000')to jump, but continued to scan outside and inside and I
happened to look at my hand ... which was holding the stick just aft of
center. What, could this be a stall/spin? Opposite rudder, stick
forward, flaps to negative ... yep, recovery ... and immediately
climbing in the thermal again. I hit the tail dump switch and made a
promise to see if I could duplicate the situation when I got home ...
which I did.
Looking back, I suspect my left outside wing went through the tight
strong thermal core, which pushed the wing up, I instinctively applied
left aileron, and of course, the inside wing stalled, and the
combination of forces kinda 'snap-rolled' the ship to the right. The
spin entry from level flight and relatively violent forces disguised
the situation and delayed my recovery ... which of course is deadly at
lower altitude. So, stall/spins don't happen the way you practice them
.... although the recovery inputs taught are correct ... you just have
to execute immediately.
I now have a rule ... or mindset ... to execute stall/spin recovery
first in any situation like this. It won't help if you do indeed have
a structural or control problem ... but it is imperative avoid an
intellectual exercise if you are really in a stall/spin. As soon as
you hear yourself saying, "What the F___" ... you should be executing
stall/spin recovery.
KK
pilots
method
integral
entries over
two
since
thermals
how we
bank to
sentence.
first
realise
more
4,000
out.
club.
and I
current
recognize a
teach.
primed
of us
moments
enough?
Erik Mann (P3)
John,
down
Thus,
known
prompt
at
heads-up
pilots.
Old January 16th 05, 06:02 PM
Greg Arnold
"Apply full rudder opposite to the direction of the yaw string" -- what
does that mean? What is the direction of the yaw string? If the loose
end of the yaw string is on the right side of the canopy, is the
direction of the yaw string to the right, or is it to the left?
I think you mean that if the loose end of the yaw string is on the right
side of canopy, you apply right rudder? Or the opposite of the normal rule?
Old January 16th 05, 06:31 PM
Don Johnstone
under discussion.
I don't think they are weird, mine were 'kick the ball'
and 'draw the string'. Of course these days I never
have to use them that is why I remember them so well.
Isn't stepping on snakes a bit dangerous? :-)
Spin Training JJ Sinclair Soaring 6 February 16th 04 04:49 PM
String in the middle does not protect you from a spin Jim Soaring 10 January 30th 04 02:57 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
