How do the big boys dimple?
Old December 13th 04, 03:07 AM
larsen-tools
Default How do the big boys dimple?
It seems that they would use something other than "C-frames" with dimple die
sets and a dead blow mallet.
Old December 13th 04, 06:42 PM
Chuck
I made a tool out of a vise grip clamp. I just cut off the ends and brazed a
couple of dies to the ends. Worked great.
"larsen-tools" wrote in message
news:7I7vd.31593$ve.2597@fed1read06...
die
Old December 13th 04, 08:03 PM
John Kunkel
die
http://www.ustool.com/usstore.asp?WC...Item&WCE=94026
Old December 13th 04, 09:15 PM
Morgans
What is the advantage to using heat for dimpleing or riveting, and how hot?
Jim in NC
Old December 14th 04, 06:25 AM
Barnyard BOb -
On a need to know basis.......
You got $22,500 for the machine?
DIMPLING, not dimpleling.
Pssst...
Anyone here teach shop? g
Barnyard BOb -
Old December 14th 04, 07:29 AM
Jan Carlsson
Pssst...
Barnyard BOb -
Does who have know-how!
Jan Carlsson
Old December 14th 04, 08:22 AM
Morgans
Pssst...
Barnyard BOb -
Not your usual spelling word..
By the way, anyone here teach *metal* shop? I don't.
Jim in NC
Old December 14th 04, 01:17 PM
Corky Scott
On Sun, 12 Dec 2004 19:07:00 -0800, "larsen-tools"
Before I bit the bullet and bought a rivet squeezer, I drilled some
bar stock for the size of the dimple stem and set the female piece
into the barstock, then clamped that into the vice.
Did the same thing with the die. Then I drilled the holes I wanted to
dimple, set the die into the hole and set the die into the dimple in
the vice and wacked it with the hammer.
I ended up setting things up so that the sheet of aluminum was
supported at several corners so that the sheet was level where the die
was.
This worked, after a fashion. With a bit of practice the dimples
started looking right. I set the rivets in the same manner: Set
countersunk rivet into the dimpled hole, flipped the work upside down
and held the rivet against a bucking bar clamped in the vice. Then I
used the hammer to squash the rivet until it was flattened about the
proper amount. Needless to say, these weren't structural parts I was
building.
Still don't own a rivet gun, but I should get one one of these days.
Corky Scott
Old December 14th 04, 02:50 PM
Barnyard BOb -
Pssst...
Barnyard BOb -
Gee whiz.
Carpe Diem, dude !!!!!
Dimpling might not be a *USUAL* word for you....
but, a grade school *spelling rule* should be.
Seize the initiative, surf the net and elsewhere
for answers in areas where you are weak...
for your personal growth and development.
At some point....
Spoon feeding info is like giving a hungry man a fish.
Better to teach him to fish, so he can take care of himself.
Fishing lesson #1 -
A short GENERAL spelling pattern lies below.
It's NOT applicable for all words, but no way could
you do worse by simply and always dropping the "E"
and adding "ING".
dimple - dimpling
true - truing
rotate - rotating
bore - boring
taste - tasting
bake - baking
make - making
ride - riding
BB -
Old December 14th 04, 03:05 PM
On Tue, 14 Dec 2004 08:17:46 -0500, Corky Scott
building.
OTOH, a friend of mine built an entire T-18 this way. The airplane has been
flying for almost 30 years....
Sun'n Fun Used to Be the Gathering of the Good Ol' Boys of Flying jls Home Built 29 April 7th 04 01:29 AM
rivet and dimple paint prep Dick Home Built 2 August 12th 03 08:31 AM
