rivet and dimple paint prep
Old August 12th 03, 01:26 AM
Dick
Default rivet and dimple paint prep
My recently acquired 30+ year old project restoration
had some "powder" under the paint at the rivet/dimples
on the fuselage. I believe it was old body putty.
What "filler" can be recommended for smoothing over the rivet/dimple prior
to repriming/repainting?
Thanks, Dick
Old August 12th 03, 06:36 AM
BD5ER
That "powder" sounds remarkably like corrosion, so it might behhove you
to drill out a couple of the rivets with the most powder and see what
lies beneath.
Once you have eliminated corrosion as the source of the powder and repaired as
needed, try some Superfil. I've not heard from anyone that was dissatisfied
(knowing this group that may change). I'd stay away from polyester based
filler. It tends to swell in the wet and crack in the cold.
Old August 12th 03, 09:31 AM
Richard Lamb
First, do check for corrosion because that's the only "powder"
I know of that could be under a rivet.
AND if that's what it is, seriously consider replacing all the rivets.
Corrosion under rivets means things are working loose.
It is not an indication of a structurally sound wing.
As for filling dimples?
I have been trying out blue bondo as an alternative.
Just doing rivets, usa a small stiff squeegee to fill,
then flush each rivet.
Wipe off any streaks before they set hard. Don't leave them
to sand off later!
Repeat as necessary, since is is still a polyester based resin.
BTW, the blue stuff has a creamier consistency and seems more
fragile in the green state than old red bondo. Finer texture.
But once hardened, it has a smoother surface and sands out slick.
It also takes microballoons, cabosyl, flock, etc. well (BEFORE
catalyzed!).
I use a little bit of this stuff here and there, usually to fair
intersections.
I do NOT lay on thick layers to build up a smooth surface.
Layers of any filler add weight.
Richard
lies beneath.
