Altimeter Disassembly
Old April 1st 05, 11:02 PM
Dick
Default Altimeter Disassembly
Received an old , externaly corroded Piper altimeter a while ago and I'd
like to take it apart for a look-see but can't figure how the guts mechanism
comes out. Presently have the glass lens, holder and knob off.
Any suggestions short of cutting the case in two G would be appreciated.
Thanks, Dick
Old April 2nd 05, 12:29 AM
Dan, U.S. Air Force, retired
Thanks, Dick
Look at the back of the case for screws. The innards are mounted to the
back of the case.
Old April 2nd 05, 07:17 AM
Ernest Christley
Dan, U.S. Air Force, retired wrote:
I'd like to take it apart for a look-see but can't figure how the guts
mechanism comes out. Presently have the glass lens, holder and knob off.
appreciated.
Thanks, Dick
back of the case.
Dan, can it be opened without destroying the instrument?
I have a Garwin, Inc. altimiter. Serial number 721, dated Mar 29 1962.
It's in working condition, and I'd like it to stay that way. It has
a little crust on the inside of the front glass. Not enough for me to
pay someone to clean it, but I'd like to run a damp cloth across it if I
could get to it.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old April 2nd 05, 01:27 PM
guts mechanism comes out. Presently have the glass lens, holder and
knob off.
appreciated.
Thanks, Dick
the back of the case.
could get to it.
Sure can, just remove the faceplate. If you can find some gasket
material to replace the old one so much the better, in any even use a
pencil to make a witness mark on one side where the bezel meets the
case. It's going to take a razor blade to scrap the crust. Just be very
careful when you separate the bezel from the case. If it is internally
lit don't try to take the glass out of the bezel. In internally lit
instruments the glass is actually 2 wedge shaped pieces and lining them
up is a royal pain.
Make sure you leak check it when you are done.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
