Local altimeter at BFM
Old June 14th 04, 08:53 PM
Dan Luke
Default Local altimeter at BFM
BFM is a Class D airport. The ILS 32
http://www.naco.faa.gov/d-tpp/0406/00268I32.PDF and VOR 18 plates say
"Obtain local altimeter on CTAF." Why in the world would they say that?
The local altimeter is available on the ATIS or ASOS 24/7. Another
plate says "When control zone not in effect: ... Use Mobile altimeter
setting." Why not use the ASOS altimeter? The VOR 14 plate does not
mention the altimeter setting at all.
Dan
C172RG at BFM
Old June 14th 04, 09:06 PM
Steven P. McNicoll
"Dan Luke" wrote in message
Nit. There are no Class D airports, BFM has Class D airspace.
The ILS 32
Looking at an A/FD a few years out of date shows an ASOS without broadcast
capability at BFM. The current sectional shows the ASOS now broadcast on
135.57, the same frequency as the ATIS. The capability of broadcasting the
ASOS on the ATIS frequency when a part-time tower is closed was supposed to
have been installed nationwide years ago, but is way behind schedule.
Apparently it was completed at BFM not so long ago, the IAPs will eventually
reflect it.
Old June 14th 04, 09:48 PM
Dan
C172RG at BFM
The notes probably predate the installation of the ASOS.
Old June 15th 04, 02:01 PM
Stan Prevost
If you email them about it, they will fix it. At least that has been my
experience.
Stan
Dan
C172RG at BFM
encoding altimeter mcfrog Instrument Flight Rules 1 May 26th 04 08:40 PM
Altimeter inaccurate smf Instrument Flight Rules 13 May 8th 04 02:49 AM
Adjustment of Altimeter Ron Home Built 5 April 5th 04 03:12 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
