Approach From a Hold
Old April 15th 05, 12:30 AM
Mitty
Default Approach From a Hold
Question for the controllers he
The KMIC VOR-A is a pretty vanilla approach. The FAF is the Gopher VOR (GEP)
about 5 miles north of the field. The missed procedure is to go back to GEP and
hold north, left turns -- depicted as a dotted race track on the plate. (The FAA
link seems to be broken for me, at least:
http://naco.faa.gov/d-tpp/0405/05158VGA.PDF)
I have been vectored into that hold (not entered from a miss) and then cleared
for the approach. At that point, I flew the inbound leg towards the VOR/FAF and
continued down the approach path to KMIC. Seemed logical to me and it certainly
seemed to be what Minneapolis Approach was expecting.
I have a CFII friend who thinks this was improper -- that since the hold was not
depicted on the approach plate (as part of the approach) that I should have
flown the full approach including the procedure turn. I guess his thought is
that I wasn't really receiving vectors since I was in the hold.
Who is right here? Me and Approach, or my friend?
TIA,
Mitty
Old April 15th 05, 12:47 AM
Roy Smith
Mitty wrote:
(The FAA link seems to be broken for me, at least:
Yeah, I get some kind of weird redirection loop. But, the airnav link
(http://www.airnav.com/depart?http://...3/05158VGA.PDF)
works fine.
cleared for the approach.
I'm not sure what you mean by "vectored into that hold". Do you mean you
were vectored to the final approach course? Or do you mean you were given
veectors to the Gopher VOR and then instructed to hold there? Or something
else? What was the exact wording the controller used?
Old April 15th 05, 12:48 AM
How were you vectored into the hold if you did not hold?
Sounds like vectors to final to me, in which case you are required to go straight-in
unless you request the procedure turn and are given an amended clearance.
That holding pattern could also be used for timed approaches, in which case you
would also be expected to proceed straight in once cleared for the approach.
Finally, let's say you missed the approach and park in that pattern until the
weather improves. Because it is a pattern that is lined up correctly and not more
than 300 feet higher than the FAF altitude, you can go straight-in once cleared for
the approach.
The procedure turn is for folks arriving from every which way to GEP.
TIA,
Mitty
Old April 15th 05, 01:07 AM
Bob Gardner
I think that the first thing you would hear from the controller if you
followed the instructor's method is "Where are you going? If you want the
full procedure, ask for it."
A good rule to follow is this: The easiest way is almost always the correct
way. Remember that the flight test folks have to fly these procedures and
they don't like to be jerked around (I'll admit that flight test is unlikely
to be assigned a hold).
Bob Gardner
"Mitty" wrote in message
(GEP) about 5 miles north of the field. The missed procedure is to go
back to GEP and hold north, left turns -- depicted as a dotted race track
on the plate. (The FAA link seems to be broken for me, at least:
cleared for the approach. At that point, I flew the inbound leg towards
the VOR/FAF and continued down the approach path to KMIC. Seemed logical
to me and it certainly seemed to be what Minneapolis Approach was
expecting.
was not depicted on the approach plate (as part of the approach) that I
should have flown the full approach including the procedure turn. I guess
his thought is that I wasn't really receiving vectors since I was in the
hold.
TIA,
Mitty
Old April 15th 05, 02:32 AM
Mitty
On 4/14/2005 6:48 PM, wrote the following:
We were shooting practice approaches in IMC and I flew a low approach at Anoka
(ANE) about 5 miles to the east, then asked for the hold since I wanted it to
update currency.
It was a while back, but I'm pretty sure the instructions were along the line
of: "Proceed direct Gopher and hold as published at 3000, expect further
clearance at xx:xx Zulu." 3000 seems to be minimum vectoring altitude in that area.
While holding, probably during the first full time around, Approach had me climb
to 4000 so he could run someone in under me. I did that. When I told him I was
ready to go he cleared me for the approach. I then asked for another turn in
the hold to lose altitude (FAF crossing is 2500), which was approved.
the approach.
Sounds reasonable. Is that printed somewhere?
and not getting vectors.
TIA,
Mitty
Old April 15th 05, 02:43 AM
Newps
Which would involve language like "fly headig xxx, direct Gopher,
holding instructions.") You were only vectored to the hold if you were
told you were being vectored into the hold and not "vectors for the
final approach course."
You never fly the full approach when vectored unless you specifically
work that out with the controller. If you're last instruction from
Approach was something like "N123, you're 5 miles from Gopher, maintain
3000 until established on the final approach course, turn left heading
xxx cleared VOR A approach into Crystal." then you were being vectored
to final and were not supposed to go back outbound when you got to the
VOR. It's hard to believe a "CFI" could screw this up. This is a
garden variety VOR approach.
I
guess his thought is that I wasn't really receiving vectors since I was
in the hold.
It all comes down to the wording. What exactly did the controller say
to you?
Old April 15th 05, 02:54 AM
Roy Smith
that area.
That makes sense. I'm not sure why you said you were "vectored into the
hold", though. You went direct to the VOR and held. Nothing vectorish
about it :-)
When I told him I was ready to go he cleared me for the approach. I
then asked for another turn in the hold to lose altitude (FAF crossing
OK, here's my take on this. Since you were not vectored to the final
approach course, and were not approaching the FAF along a segment labeled
NoPT, you were required to perform a PT. A racetrack pattern is a
perfectly acceptable way of flying a PT, and it sounds like this is what
you did.
On the other hand, this is a bit of a grey area in my mind. Rather than
second guessing the controller, a quick radio call will eliminate any
possible confusion on both sides. Lack of confusion is always a good thing.
until the weather improves. Because it is a pattern that is lined up
correctly and not more than 300 feet higher than the FAF altitude, you
can go straight-in once cleared for the approach.
What does the "300 feet higher" have to do with anything? The AIM says:
5-4-9. Procedure Turn
a. A procedure turn is the maneuver prescribed when it is necessary to
perform a course reversal to establish the aircraft inbound on an
intermediate or final approach course. The procedure turn or hold in lieu of
procedure turn is a required maneuver. The procedure turn is not required
when the symbol "No PT" is shown, when RADAR VECTORING to the final approach
course is provided, when conducting a timed approach, or when the procedure
turn is not authorized.
I don't see anything in there about 300 feet.
Old April 15th 05, 03:10 AM
Steven P. McNicoll
expecting.
hold.
If you made a turn (or more) in the hold which established your aircraft
inbound on the FAC then you DID fly the full approach.
You and approach.
Old April 15th 05, 01:02 PM
OtisWinslow
I should have flown the full approach including the procedure turn.
TIA,
Mitty
You did. If you were on the protected side (procedure turn) side
of the final approach course you chose a perfectly fine way to
get turned around.
Old April 15th 05, 01:29 PM
update currency.
the approach.
The AIM discusses timed approaches, and shows a holding pattern like that one. When
straight-in from such holding patterns was not authorized, IAPs like that used to have a
note "Final Approach from XYZ holding pattern not authorized." But, the procedures folks
were told to stop using that note and make the patterns useable for such approaches.
If you want it in writing you should contact your regional FAA Flight Procedures Office
for clarification. Many things are imperfect with the FAA.
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
