#21
I don't disagree that this was a real rookie and from the initial
description it wasn't airframe. Frank BTIZ wrote: I remember that glider on the beach posting shortly after it happened.. I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT "F.L. Whiteley" wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT "F.L. Whiteley" wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
M B wrote:
Do you think the government or the insurance company does a better job of protecting the customer? This was not the point. The point was that the whole idea of a commercial rating should be to protect the costomer. A commercial rating should be a certificate that I can trust somebody. That's the idea. That this is not achived by the ridiculous requirements to get such a rating (in the USA) was exactly my point. Stefan |
A few points.
It's unlikely that the pax knew where the stick was since it's SOP to remove the rear stick when flying with two pax. You can't see the front stick from the back. Most 2-32's will give easily recognizable pre-stall buffet but not all of them. There was variation in SN to SN. As would be expected, two pax in the rear seat will put the CG forward quite a bit and that tends to tame the 2-32's stall/spin behavior. Should an incipient spin departure develop, prompt anti-spin control inputs will stop the spin. I agree that the US commercial glider pilot experience requirements are a joke. I hope that glider ride operations everywhere take this accident as a warning to demand far higher experience from prospective ride pilots. Bill Daniels 2-32 driver "BTIZ" wrote in message news:YL_9e.16042$%c1.5975@fed1read05... I remember that glider on the beach posting shortly after it happened.. I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT "F.L. Whiteley" wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT "F.L. Whiteley" wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
#24
Heresay evidence, blind assumption and lack of experience
in the glider concerned all put together is enough for a hanging is it. If the poor bloke was still alive you could lock him up in Guantánamo. He may have been al-Qaida, a mass murderer perhaps or anything else you care to pull out of the air. Why can you not wait for the results of the enquiry and decide on the evidence instead of speculating about the guilt of someone who cannot defend himself. Land of the Free? Prove it. At 04:30 22 April 2005, Btiz wrote: I remember that glider on the beach posting shortly after it happened.. I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT 'F.L. Whiteley' wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT 'F.L. Whiteley' wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
#25
Don Johnstone wrote:
Why can you not wait for the results of the enquiry and decide on the evidence instead of speculating about the guilt of someone who cannot defend himself. I agree (and always said so) that it is speculation. But *if* this speculation is correct, then that poor young chap is the last person to blame. He was told by the authority that he's a capble pilot to commercial standards. The operator, supposedly an experienced pilot, let im loose with passengers, thus implying the same. So *if* the speculation is correct, this inexperienced pilot is not guilty, but a victim himself! Stefan |
#26
At 13:30 22 April 2005, Don Johnstone wrote:
Heresay evidence, blind assumption and lack of experience in the glider concerned all put together is enough for a hanging is it. I don't think anyone has suggested that the pilot here was directly at fault, rather that it was maybe unwise (even in the absence of an accident) to send passengers up with a relatively inexperienced pilot. In the case of an inexperienced pilot coming to grief, you have to look at the training he received (in this case recently) to find out what could be done better. This is not a world champion that pushed his/her luck too far. If the poor bloke was still alive you could lock him up in Guant�namo. He may have been al-Qaida, a mass murderer perhaps or anything else you care to pull out of the air. .....1...2...3...4...5... Why can you not wait for the results of the enquiry and decide on the evidence instead of speculating about the guilt of someone who cannot defend himself. Land of the Free? Prove it. I'd say open speculation (and disagreement) and the fact that people make it is pretty much proof that it is land of the free. Any speculation made now is (in the reasonable persons mind) just that, speculation, it can (and will) be revised as more evidence comes to light and the NTSB inquiry progresses. And as a previous poster said before, if I died in a glider, I'd rather that the causes were gone over and any lessons learnt, rather than my case being brushed under the carpet. Accidents, and there causes shouldn't be taboo, we can all learn something from them (unfortunately), even from speculation. If we were all perfect pilots then we could carry on as normal without looking at these incidents (but then again there shouldn't be any incidents then should there?). I haven't actually expressed an opinion (intentionally anyway) on the pilots ability and/or failings but to shout down honest and open speculation is unwise and possibly foolish.... Jamie At 04:30 22 April 2005, Btiz wrote: I remember that glider on the beach posting shortly after it happened.. I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT 'F.L. Whiteley' wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT 'F.L. Whiteley' wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
#27
Heresay evidence, blind assumption and lack of experience in the glider concerned all put together is enough for a hanging is it. Check the subject line, Don. Would you have let your loved ones ride with a pilot who had a comparable background, in those surroundings? Or even hear over the cornfields of N. Illinois for that matter? We are all rejoicing that more were not killed. If anyone is to be condemned out of hand, it is an organization which would hire someone to do this sort of work who had "48.4 hours". I'm sure that all of us have great confidence that appropriate measures will be taken via the civil courts and in the matter of future insurance costs/availability for the commercial glider operation responsible. If you have a burr under your saddle concerning certain aspects of US international policy, why not take it to another newsgroup where someone cares? Jack |
#28
....and not a lot of experience to be taking PAX on the lee side of a ridge
where there's no place to land. If you go to on the lee side and get below the ridge line you have no nice options. Obviously none of us know what happened, but it smells to me like a strong lee downdraft. "BTIZ" wrote in message news:YL_9e.16042$%c1.5975@fed1read05... I remember that glider on the beach posting shortly after it happened.. I do have some very limited time in the 2-32... the one I flew I felt it was very honest.. giving plenty of warning before the stall with rumbling and stick shaking.. one report that came from our local witness.. that is not addressed in the preliminary report... and taken with a few grains of salt or sand...is that the passengers reported that the stick was full back the entire time when the spin started... no forward movement to stop the spin.. In less than one month.. this individual went from Student Pilot certificate issue.. to Private Pilot to Commercial Pilot... and crashed. No mention is made of his experience prior to receiving his student pilot certificate. But based on the documentation provided, one can expect that he had worked up to pre-solo before getting his student certificate and quickly completed two written exams and check rides. Not a good position to put an insurance company in. BT "F.L. Whiteley" wrote in message ... I don't disagree, but there are other possibilities. 2-32 gives zippo spin warning, it tends to flick over the top from a tight turn. I thought the local operators were a bit more discriminating, requiring some referral. However, as I told my young friend, break one and drop in the ocean, the next week it would be old news there and the rides would continue. Different operator, same location http://www.soarcsa.org/glider_on_the_beach.htm FWIW one suggestion was the 'extreme return'. Vertical speed limiting dive to the numbers, rotate to landing. My young friend thought this would be a big seller. But parachutes would cut down on useful load. Shoe-horning them in was the order of the day. Frank BTIZ wrote: based on a witness report.. that is now flying here... minimum experience.. lack of spin training... I'd go with the lack of Airmanship.. BT "F.L. Whiteley" wrote in message ... Ramy wrote: As usual, the NTSB report is useless. Doesn't even attempt to analyze the cause for the accident. One of my younger soaring friends hauled rides there for a couple of stints. He clocked over 100 hours a month in 2-32's which we reckoned may have 20,000 to 40,000 hours on them in all that salt air. Airmanship or lack of it may have had nothing to do with this sad incident. |
#29
I shocked, truly SHOCKED, to read such rampant speculation. I have
never before heard of such an untoward thing on RAS! In deed, we should all wait 1-2 years for the OFFICIAL NTSB proclamation that this accident was caused by pilot error (low PIC time a contributing factor). Tom |
#30
Tom, You either completly missed the point or just ignore it. Unless
you consider the pilot experience detailed in the NTSB report as speculation. This poor fellow just soloed 3 weeks ago and was allowed to take paid passengers for a ridge soaring ride for god's sake. Don't you see what's wrong with this picture? The purpose of discussions like this is to prevent similar things from hapenning again. Waiting 1-2 years for official NTSB report which will most likely be identical is a waste of time. It will be old news by then. I rather wait for the accident report in Soaring magazine. But again, this is not the point of this discussion. |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
