how roll fuselage/engine package
Old May 8th 05, 12:04 PM
Dick
Neal,
Leaning towards a stub-out wing section with permanent gear mounted. This
allows me to: complete braking system; still fit project alongside my flying
plane; continue folding wing mechanism developement; etc.
Thanks for positive thoughts, Dick
I was originally going to suggest making a structure that would bolt to
the ends of the main spar fittings, but that could impart stress on
those fittings that could damage them. The bed/carpet sling idea is
OK, except that you will be running the engine, not just moving the
assembly around. How about making a wood structure that "sandwiches"
the wing stub ( say about a foot outboard of the fuselage sides ) Think
of the "clapboard" that the movie industry uses before each "take" of a
scene. Cut out the shape of the airfoil between (2) 2 x 8's. Hinge
the 2 x 8's on one end and bolt them together on the opposite end.
Then extend a vertical board on the forward end of the structure and
put casters/wheels on the end. You could arrange the casters far
enough forward that you wouldn't have to add weight to the tail with
the wings removed. Make one for each side and maybe secure each
structure to the other one for rigidity. Of course making the whole
thing stout as hell and protect the wing. Might work.
Neal
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
