#21
Sorry. I left out something that I took for granted. You hold the switch
terminals down, keyhole up and squirt/rotate. That means that the cleaner goop (that's a technical term, you'll get used to it) has to travel through the switch mechanisms and out the back end before it gives up. If you squirt it with the switch in the normal horizontal position, all you clean is the bottom end and most of it will run back out the keyhole. Most switches won't let you get the little nozzle straw far enough into the keyhole to really spray the innards. As to the AD on that switch, the owner can do the AD and sign it off. It is REALLY HARD to do. You fire the airplane up. You take it to the runup area. You turn the switch "off" with some reasonable force. If the engine stops, the AD passes. Ten seconds at the outside. And that is worth a $150 switch to get rid of the AD? $150 buys more beer than even JAY can drink in a day. I teach a similar trick to my students for computer 12 volt fans that start howling. Two small bowls or coffee cans. Half-fill one with paint thinner and one with a 50-50 solution of MMO and paint thinner. Run the fan for an hour submerged in the paint thinner (cleans all the crap out of the innards). Run it for an hour submerged in the MMO solution. Run it for thirty seconds in the thinner again to get the surface oil off. Set it on a paper towel to drain. In 95% of the cases you have pretty much a new fan. Of course, I would NEVER EVER suggest that trick to something that goes on a certificated blessed stamped and exonerated aircraft. The fact that it works has ABSOLUTELY nothing to do with it. BTW, gang, those computer 12 volt fans are just the trick for avionics that need a bit of extra cooling. In a homebuilt, of course. Jim Is there any reason I have to remove the switch from the panel to try this? Can I put a rag behind it in the panel, and try cleaning it? |
When it was demonstrated to me by the local CRS, the beyond-off force
(moment) capability was maybe "reasonable" - at least it didn't go so far as needing a pliars on the key - but it was substantial. I took it apart & fixed it. Otherwise we had to replace it on the 172. I'm saving the old one for a homebuilt. |
Jay Honeck wrote:
Take the mag switch out of the panel. Get Mary to do it. A little person wriggling around under the panel is a WHOLE LOT more comfortable than you or I. Hey -- I'm only 89.9% of the guy I was a year ago! (177 pounds, as of yesterday...) I was down to 183 as of this morning, down to about 85%. |
#24
RST Engineering wrote:
As to the AD on that switch, the owner can do the AD and sign it off. It is REALLY HARD to do. You fire the airplane up. You take it to the runup area. You turn the switch "off" with some reasonable force. If the engine stops, the AD passes. Ten seconds at the outside. And that is worth a $150 switch to get rid of the AD? $150 buys more beer than even JAY can drink in a day. While it's probably obvious to most people, I just want to make sure people understand this is to be done with the throttle at IDLE. Do not crank it up to $1700 and do something that might cycle both mags off and on again. You'll do what Rod Machado refers to as his student's click-click-click-BANG mag check. Not good for the exhaust. |
#25
yesterday...) I was down to 183 as of this morning, down to about 85%. Wow -- we just keep gaining more useful load by the day! Of course, arguably, you and I own the two singles with the highest useful loads on the group, so our efforts are obviously solely for health and vanity reasons... :-) So what's your secret? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#26
Thanks for the clarification, Jim. Always remember you're dealing with the electronically impaired here. Even the most basic concepts should never be taken for granted! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#27
![]() Mark Hansen wrote: I thought that actually shutting off the engine during a simulated engine out situation was really frowned upon? It probably is frowned upon by some. IMHO, If you really want to shut the engine off during a glide, you should use the mixture. With only the ignition off, the fuel/air mixture is still cycling through the cylinders and soaking your plugs. John Galban=====N4BQ (PA28-180) |
#28
![]() Jay Honeck wrote: Anyone who did that to me would not be able to get out of the plane unassisted. In some other situation I might have been ****ed. But on this flight, he was the PIC (my BFR was expired), plus I was 1,000 ft. AGL, right next to an automotive proving ground. There were several miles of usable runway right under me. Landing there safely would have been easier than at an airport. John Galban=====N4BQ (PA28-180) |
#29
![]() Ron Natalie wrote: While it's probably obvious to most people, I just want to make sure people understand this is to be done with the throttle at IDLE. Do not crank it up to $1700 snip $1700? Freudian slip, or were you subliminally describing the end result of the explosion on the exhaust system? ;-) John Galban=====N4BQ (PA28-180) |
#30
Jay Honeck wrote:
So what's your secret? Margy is doing weight watchers, I'm just following along./ |
Airman Finds True Calling as Part of 'Best Force' | Otis Willie | Military Aviation | 0 | September 10th 04 11:18 PM |
BergFalke II/55 part. | Bruce Greeff | Soaring | 2 | May 12th 04 02:32 PM |
commercial privileges | Gary Drescher | Piloting | 32 | February 27th 04 02:42 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
Part 91 Commercial Glider Rides to be Outlawed? | Vaughn | Soaring | 9 | October 27th 03 09:26 PM |
