Key Locks -- Part II
Old May 17th 05, 01:01 PM
Jay Honeck
Default Key Locks -- Part II
After reading the other posts about key locks, the responses brought another
question to mind.
My key ignition switch works very hard, and the key can be removed in any
position. It's hard to push it in and keep the starter engaged (it's one
of those turn-while-you-push switches), so we usually end up pushing it
several times to get the engine started.
Can that ignition switch be dismantled and repaired, or is this a
"replace-only" job?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 17th 05, 02:21 PM
Jay Honeck wrote:
: Can that ignition switch be dismantled and repaired, or is this a
: "replace-only" job?
Unlikely to be repairable without some questionable dissasembly. Those
switches are usually made with little metal tabs bent to hold on the back plate
insulator. The tabs have to be be unbent to remove, and then rebent to reinstall.
There's probably some impressive spring assembly in there, as well (to take care of
the rotational spring, and the push-in spring).
-Cory
* Cory Papenfuss *
Old May 17th 05, 02:29 PM
Ron Natalie
"replace-only" job?
I had a similar problem with mine (the key would actually FALL OUT)
in flight and it would appear to be in the OFF position and still
leave one MAG hot. I just replaced the blasted thing. A new bendix
switch wasn't that much. My ignition key didn't match the canopy
or baggage compartment locks anyhow.
Old May 17th 05, 02:32 PM
Jay Honeck
Now, for the real question:
Do I have to get this part from Piper (for big $$$), or can I use the
(apparently identical) switch shown in the Aircraft Spruce catalog?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 17th 05, 08:17 PM
Robert M. Gary
It must have a TSO or STC. If the TSO lists your aircraft then you are
good to go. I would be surprised if this isn't the case.
-Robert
Old May 18th 05, 01:53 PM
Chuck
On Tue, 17 May 2005 09:29:56 -0400, Ron Natalie
"replace-only" job?
Besides,
Isn't there a reoccuring AD on those Bendix ignition switches???
Something about leaving the mags hot even if you turn it to the off
position. Why not just replace it and not have to worry about a
reoccuring AD or the hi effort problem?
Chuck
Old May 18th 05, 02:55 PM
Dave Butler
Google AD 76-07-12.
Dave
Old May 18th 05, 03:21 PM
Jay Honeck
Google AD 76-07-12.
Thanks, Dave.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 17th 05, 04:54 PM
Michelle P
Jay,
If the part is TSO or PMA with equiv part number it is fine.....
Michelle
question to mind.
"replace-only" job?
Old May 17th 05, 08:16 PM
Robert M. Gary
You may actually have an AD that requires you to replace the mag
switch. I had to replace mine two years ago after a shop showed me an
AD that says it must be replaced if the key can be removed in flight. I
have no idea why the hell such an AD exists.
-Robert
Airman Finds True Calling as Part of 'Best Force' Otis Willie Military Aviation 0 September 10th 04 11:18 PM
BergFalke II/55 part. Bruce Greeff Soaring 2 May 12th 04 02:32 PM
commercial privileges Gary Drescher Piloting 32 February 27th 04 02:42 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
Part 91 Commercial Glider Rides to be Outlawed? Vaughn Soaring 9 October 27th 03 09:26 PM
