Key Locks -- Part II
Old May 18th 05, 03:53 PM
RST Engineering
Sorry. I left out something that I took for granted. You hold the switch
terminals down, keyhole up and squirt/rotate. That means that the cleaner
goop (that's a technical term, you'll get used to it) has to travel through
the switch mechanisms and out the back end before it gives up. If you
squirt it with the switch in the normal horizontal position, all you clean
is the bottom end and most of it will run back out the keyhole. Most
switches won't let you get the little nozzle straw far enough into the
keyhole to really spray the innards.
As to the AD on that switch, the owner can do the AD and sign it off. It is
REALLY HARD to do. You fire the airplane up. You take it to the runup
area. You turn the switch "off" with some reasonable force. If the engine
stops, the AD passes. Ten seconds at the outside. And that is worth a $150
switch to get rid of the AD? $150 buys more beer than even JAY can drink in
a day.
I teach a similar trick to my students for computer 12 volt fans that start
howling. Two small bowls or coffee cans. Half-fill one with paint thinner
and one with a 50-50 solution of MMO and paint thinner. Run the fan for an
hour submerged in the paint thinner (cleans all the crap out of the
innards). Run it for an hour submerged in the MMO solution. Run it for
thirty seconds in the thinner again to get the surface oil off. Set it on a
paper towel to drain. In 95% of the cases you have pretty much a new fan.
Of course, I would NEVER EVER suggest that trick to something that goes on a
certificated blessed stamped and exonerated aircraft. The fact that it
works has ABSOLUTELY nothing to do with it.
BTW, gang, those computer 12 volt fans are just the trick for avionics that
need a bit of extra cooling. In a homebuilt, of course.
Is there any reason I have to remove the switch from the panel to try
this? Can I put a rag behind it in the panel, and try cleaning it?
Old May 18th 05, 07:28 PM
nrp
When it was demonstrated to me by the local CRS, the beyond-off force
(moment) capability was maybe "reasonable" - at least it didn't go so
far as needing a pliars on the key - but it was substantial. I took it
apart & fixed it. Otherwise we had to replace it on the 172.
I'm saving the old one for a homebuilt.
Old May 18th 05, 08:46 PM
Ron Natalie
Jay Honeck wrote:
Take the mag switch out of the panel. Get Mary to do it. A little person
wriggling around under the panel is a WHOLE LOT more comfortable than you
or I.
Hey -- I'm only 89.9% of the guy I was a year ago! (177 pounds, as of
yesterday...)
I was down to 183 as of this morning, down to about 85%.
Old May 18th 05, 08:48 PM
Ron Natalie
a day.
While it's probably obvious to most people, I just want to make sure
people understand this is to be done with the throttle at IDLE. Do
not crank it up to $1700 and do something that might cycle both mags
off and on again. You'll do what Rod Machado refers to as his
student's click-click-click-BANG mag check. Not good for the
exhaust.
Old May 18th 05, 10:10 PM
Jay Honeck
yesterday...)
Wow -- we just keep gaining more useful load by the day!
Of course, arguably, you and I own the two singles with the highest useful
loads on the group, so our efforts are obviously solely for health and
vanity reasons...
So what's your secret?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 18th 05, 10:11 PM
Jay Honeck
Thanks for the clarification, Jim.
Always remember you're dealing with the electronically impaired here. Even
the most basic concepts should never be taken for granted!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 19th 05, 01:35 AM
Mark Hansen wrote:
I thought that actually shutting off the engine during a simulated
engine out situation was really frowned upon?
It probably is frowned upon by some. IMHO, If you really want to
shut the engine off during a glide, you should use the mixture. With
only the ignition off, the fuel/air mixture is still cycling through
the cylinders and soaking your plugs.
  #28
Old May 19th 05, 01:43 AM
Jay Honeck wrote:
Anyone who did that to me would not be able to get out of the plane
unassisted.
In some other situation I might have been ****ed. But on this flight,
he was the PIC (my BFR was expired), plus I was 1,000 ft. AGL, right
next to an automotive proving ground. There were several miles of
usable runway right under me. Landing there safely would have been
easier than at an airport.
  #29
Old May 19th 05, 01:47 AM
snip
$1700? Freudian slip, or were you subliminally describing the end
result of the explosion on the exhaust system? ;-)
  #30
Old May 20th 05, 12:47 AM
Ron Natalie
Margy is doing weight watchers, I'm just following along./
Airman Finds True Calling as Part of 'Best Force' Otis Willie Military Aviation 0 September 10th 04 11:18 PM
BergFalke II/55 part. Bruce Greeff Soaring 2 May 12th 04 02:32 PM
commercial privileges Gary Drescher Piloting 32 February 27th 04 02:42 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
Part 91 Commercial Glider Rides to be Outlawed? Vaughn Soaring 9 October 27th 03 09:26 PM
