Things to put in the "remarks" section of the flight plan
Old June 16th 05, 08:18 PM
Gary Drescher
ink.net...
"Gary Drescher" wrote in message
What is the purpose of the special call sign that Angel Flights use to
distinguish themselves?
According to Angel Flight West the call sign "indicates to ATC the
'...need for appropriate (but not priority) handling by ATC'."
According to an Air Traffic Bulletin issued six years ago use of the call
sign identifies the flight as a non-profit, charitable, community service
involving no priority handling, but minimal delay would be appreciated.
Oh, ok. Is 'priority' a technical term for ATC? In ordinary language,
minimizing delays (to a greater extent than for ordinary flights) would be a
form of priority (though perhaps not as high as the priority afforded to
some other flights).
--Gary
  #32
Old June 16th 05, 08:36 PM
Dan Luke
"Will Rogers" wrote:
Seems like these days the most common not-particularly-useful-to-ATC
remarks I see a
None
followed closely by:
PIC Joe Shmoe, 555-678-1212
DUAT will put the pilot's name in the remarks if you don't tell it not to.
I have often had evidence that controllers are ignoring the remarks. A
common example is being asked my on-course heading by Departure when I filed
it in "remarks."
Dan
C-172RG at BFM
  #33
Old June 16th 05, 08:57 PM
Steven P. McNicoll
"Jose" wrote in message
What if a controller gives priority when there is no other reason to - for
example (you can make a better one up) two planes approaching the same
waypoint at the same time. One is given vectors for delay. Would giving
the delay vectors to the non-angel flight aircraft be a viloation of
7110.65?
No, as Angel Flight is not mentioned in FAA Order 7110.65.
  #34
Old June 16th 05, 09:03 PM
Steven P. McNicoll
Yes.
http://www.faa.gov/atpubs/ATC/Chp2/atc0201.html#2-1-4
In ordinary language, minimizing delays (to a greater extent than for
ordinary flights) would be a form of priority (though perhaps not as high
as the priority afforded to some other flights).
If two aircraft are a dead ass tie and one of them is an Angel Flight,
everything else being equal, I'd put the Angel Flight ahead of the other
one.
  #35
Old June 16th 05, 09:09 PM
Gary Drescher
ink.net...
Yes.
Thanks, good to know.
  #36
Ron Natalie
remarks I see a
None
Huh? It will always put the ACCOUNT HOLDERS name in the PIC block no
matter what you enter. Does it really enter stuff serrupticiously
in the remarks field?
  #37
Old June 16th 05, 09:48 PM
Jose
Then on what basis to you make the following statement? And on that
same basis, how do you answer my subsequent question relating to
otherwise equal consideration?
If a controller gives a flight priority handling
based on an Angel Flight call sign he is acting contrary to FAA Order
7110.65.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain."
(chapter 10 of book 3 - Harry Potter).
  #38
Old June 16th 05, 10:29 PM
Dan Luke
Yep, if you don't tell it not to when you're setting up the defaults for your
account.
Dan
C-172RG at BFM
  #39
Old June 17th 05, 12:11 AM
Newps
Angel Flight means nothing to ATC, most controllers don't even know what
it is. And why would you put it in the remarks and not just use the
three letter ID allocated to Angel Flight(NGF)?
  #40
Old June 17th 05, 12:19 AM
Gary Drescher
"Newps" wrote in message
be a form of priority (though perhaps not as high as the priority
it is. And why would you put it in the remarks and not just use the three
Uh, I wouldn't. That's why I was asking specifically about the use of the
Angel Flight call sign (which is obviously supposed to mean something to
ATC--they don't think it's a type of airplane, do they?).
--Gary
The things Bush didn't mention in his speech Ewe n0 who Naval Aviation 1 May 26th 04 04:04 PM
The things Bush didn't mention in his speech Ewe n0 who Military Aviation 0 May 26th 04 02:10 PM
Things I Have Learned As First Time Buyer/Owner (long) MRQB Owning 12 April 19th 04 02:12 PM
making the transition from renter to owner part 2 (long) Journeyman Piloting 2 April 15th 04 10:19 PM
31 things that are really true about Fighter pilots Big John Piloting 5 November 28th 03 05:33 PM
