Things I Have Learned As First Time Buyer/Owner (long)
Old April 13th 04, 07:46 AM
MRQB
Default Things I Have Learned As First Time Buyer/Owner (long)
Well I learned when doing a pre buy be sure you take it to the avionics shop
and have all the avionics and instruments checked out before you buy my
mistake only thing that was not checked at the pre buy waqs the avionics. I
was more concerned about the engine and airframe. I had the transponder
checked about 3 weeks ago all tested ok Well today while flying in class C
airspace (KPDX) the transponder went out the tower did not like that very
much and was told to depart their airspace ASAP. I landed at the nearest
airport and went to an avionics shop what do you know the transponder
stopped receiving and transmitting at it happens things fail.
The next airplane I buy ill have the avionics checked out in the pre buy
defiantly. Now all my avionics and instruments are now new and or checked
out and working 100% correctly. I have been told that I should contact my
local FSDO about the A&P-IA that signed things off as things were not done
correctly and could have caused major problems. Not sure I want to do that
and not sure what I should do.
The last avionics shop told me my ADF was bad I sent it out to a shop of my
choice it checked out ok no repairs needed. It was my ADF antenna that was
the problem a little scotch bright took care of that. Just a little
corrosion on the wire antenna connection. They also told me my Glide Slope
Was Not fully deflecting and my VOR was off 8 degrees and needed to be
replaced. Retested by another shop and well it is well within factory limits
humm. They set my altimeter settings wrong + 110' on the ground yeiks. Said
my marker beacon receiver was bad and entire audio panel needed replaced
with a new one. Nope it was a $3.00 diode. Now I am wondering if they over
pressurized my pito system and blew my airspeed indicator diaphragm to try
and sell me a new one of them also who knows.
Well 5 hours at the avionics shop today and a rebuilt Transponder, Repaired
3LMB and a new sticker in the log book showing how the problems that the
last shop goofed up on. Now all is fixed and what a joy to fly every things
works very very very well.
I am glad that my transponder went out on me today and forced me to land at
a larger airport to get it fixed. I was kinda questioning in the back of my
mind the business ethics of the last avionics shop, after the ADF came back
from the repair house ok with no problems. I think I will let it go as a
$600.00 lesson learned and steer business away from that avionics shop that
goofed things up and refer to the shop I went to today at leased they have
proper equipment to do it right. They had equipment that looked like it
needed a manual larger than a Linux manual to operate.
I will not mention names until I confront the last avionics shop with my
paperwork showing them that items that they said were defective were not ill
see what they will do about the diagnostic time they charged me.
Lessons learned:
Don't ignore the avionics on a pre buy even if there is not an avionics shop
at the airport you buy it at take it to one get it checked worth the $300.00
in labor you may save you a few thousand.
Don't trust shops that tell you it cannot be fixed and you must replace it
and try and sell you a entire new panel for $10,000 get a second opinion it
may save you a headache and a bunch of money.
Only go to shops that have modern equipment to do the job right ask to see
their equipment and library you may see binders of schematics that's a good
if they will show you bad if they don't have it, You may see a few newer
turbine aircraft in their hanger and higher rates (+$20.00 an hour more than
others but modern $30,000+ test equipment has to be paid for some how) You
may want to pay now or you will be paying pay later. I am an electronics
engineer by trade I am not comfortable paying $80.00 to have a $3.00 part
replaced but way better than paying $1,800 for a new audio panel.
Biggest lesson learned is who not to deal with well worth the $600 I had to
spent today to learn that.
Old April 13th 04, 10:35 AM
Ben Jackson
MRQB wrote:
I think I will let it go as a $600.00 lesson learned
The thing I have learned as a first time buyer/owner: The headaches
associated with owning a plane can easily suck all the joy out of
ownership. Though it goes strongly against my nature I'm slowly learning
to let the little irritations go so that they don't sour my outlook on
flying.
I could list a half dozen little irritations as examples, but that would
set me back on my 12 step "let it go" program. :-)
Ben Jackson
http://www.ben.com/
Old April 13th 04, 07:55 PM
Tony Cox
"MRQB" wrote in message
shop
I
Why do you think things were not done correctly? Things do break you
know. Unless you have specific reason to believe the electronics shop
screwed up, I'd leave it.
my
limits
You do seem to have far more problems than most people I know. How
did you pick the shop? Who did other pilots at the airport recommend?
You can test your own VOR you know. It's easy. I check mine every month.
Repaired
things
Your log book is filling up with gripes about previous shops?
at
my
back
that
ill
Aren't you the guy who was threatening to sue an FBO for not
having a specific plane available for you when you wanted it?
Flying is about fun, not confrontation. I suspect you'll end up being
blacklisted yourself if you're not careful. Then what would you do?
Lessons learned:
shop
$300.00
it
good
than
You
to
It's cheaper to learn who you *should* be dealing with. My mechanic
has guided me to excellent electronics shops and engine repairers. Ask
around & you'll find who to deal with and who to avoid.
Old April 13th 04, 08:01 PM
G.R. Patterson III
Right on. When I picked up my 150, everything was working correctly. Before I got 30
miles away on the trip homw, the NAV radio had gone TU. The COM side died a few
months later.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 13th 04, 09:49 PM
Otis Winslow
Avionics doesn't last forever. It can be working fine one day and go
south the next day. It's not anyone's fault. When an A&P/IA signs
something off it just means it was functioning within specs at the
time they checked it. It's not a guarrantee.
shop
I
my
limits
Repaired
things
at
my
back
that
ill
Lessons learned:
shop
$300.00
it
good
than
You
to
Old April 13th 04, 10:28 PM
G.R. Patterson III
Otis Winslow wrote:
When an A&P/IA signs something off it just means it was functioning within
specs at the time they checked it.
For that matter, I can't recall any time that an A&P or IA signed off on my avionics.
It's not part of what they check for an annual inspection. The only time anyone has
signed off one of my units was when I took it to an avionics shop for repair or for
some required tests, and that person is not an A&P.
George Patterson
Old April 13th 04, 10:42 PM
MRQB
"Tony Cox" wrote in message
ink.net...
shop
avionics.
I
C
very
checked
my
done
that
I am not going to do any thing except for confront the shop about their
unethical business tactics.
my
was
Slope
limits
over
try
Recomendation's from other pilots that i do not know at the local airport
Please explain how?
Repaired
things
No gripes about the other shops in the log book just records of things being
done over again the gripes are on the A&P's diagnostic paperwork.
at
my
back
that
have
ill
I am a fair person, the only thing I did was ponder the thought to get pre
paid funds back for unused block time from the FBO as a last resort, we
resolved it by other means that satisfied both of us. But you are probably
the type person that if someone ripped you off for a few hundred dollars or
even thousands you would not confront them. Well I will confront them! maybe
the last avionics shop's testing equipment is out of calibration and don't
know it, it can happen! I know on my equipment for cretin jobs I must have
calibration certificates for my testing equipment. Is it required some ware
in the FAR's for instrument and avionics testing?
Lessons learned:
shop
$300.00
it
it
see
good
than
You
part
to
You live and learn right, I think I found a shop that is highly respected &
fits my service standards but most everyone says they are to expensive not
really if you think about it. "Yes you have a bad part this is the part and
this is why it went out replace part check unit to factory specs as listed
in the factory service manual not from memory problem solved" Seems like
this shop has the proper tools & knowledge to fix things properly. It is
well worth the extra expense rather than have a shop with little knowledge
spend unnecessary hours working on your equipment at lower rates will equal
the same rates or even higher rates.
Old April 13th 04, 10:51 PM
Tony Cox
ink.net...
Please explain how?
The AFD has a list of VOR receiver check points which list
the direction and distance over various points on the ground, or
in some cases *on* the ground. Just go there and see what your
VOR/DME says.
There are also VOR test facilities at different airports.
You can also check one VOR against another, if you have two.
Now in my case, I just open my hangar door and there's BLD on
top of the hill just 3.1 miles away. Not everyone is so lucky.
Old April 13th 04, 11:00 PM
Tony Cox
or
Not at all. If someone ripped me off I'd be ****ed. But I generally
give people the benefit of the doubt. I get the impression that you
are spoiling for a fight with just about everyone you deal with, so I'm
suggesting to you that you lighten up a bit before shops stop dealing
with *you*.
Most of these places have slim profit margins & word will soon get
around that you are going to be more trouble than the few dollars
they'll be making from you is worth.
maybe
ware
Of course. Certified repair shops are highly regulated.
Old April 13th 04, 11:26 PM
MRQB
I am not spoiling for a fight!!! I just don't like being told things are bad
and need to be replaced when they are not and being charged for it if you
took something in for repair and something seemed to be working right and
they told you that is it not working and needed to be replaced and other
things are broken and could not be serviced I bet you would get a second
opinion from another shop before replacing a $1,000 piece of equipment and
that what I did. Seemed like the last shop just wanted to sell me all new
avionics being dishonest to customers is a bad thing.
ink.net...
or
with *you*.
maybe
don't
have
ware
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 03:33 PM
the complete minute by minute timeline on 911 Krztalizer Military Aviation 27 January 27th 04 05:35 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
