#11
Nathan Young wrote:
On Sat, 18 Jun 2005 23:02:25 GMT, john smith wrote: Le Chaud Lapin wrote: Being a software developer, I am very suprised to discover that not every aicraft costing over $30,000 has a full-featured glass cockpit. Unless I am missing somethnig, it appears that everything that a pilot needs can be made with very very cheap hardware. Already been done. 10-15 years ago Burt Rutan had one of his aircraft (Catbird?) completely controlled by an Apple laptop computer with custom coded software. His asymetric twin, Boomerang used a laptop for much of the instrumentation. I think this is just wonderful. I've always dreamed of making an ultr-lightweight aircraft using advance controls like this. Hopefully in a few years I will be able to jettison my current occupation and devote my effort to it full-time. -Chaud Lapin |
USB. I think it would be highly appropriate for this type of application. It's way too easy to trip over the cord with USB -- or to have it vibrate loose. My experience with USB indicates that it isn't reliable enough for my servers at work, it's not good enough for any airplane I fly. Maybe if you replaced the connectors or soldered everything well.... But, I'm reluctant to suggest USB to my users for anything more permenant than a mouse. -Luke |
wrote: Are you ready to bet your life on Windows XP and some $200 disk drives made in China and designed to operate in an office? Actually yes. Of course, I would take into the account of altitude/pressure/temp problems. As a matter of fact, I would be more comfortable with commodity components than something that's customized, unless the customization were very very trivial. If you do that, don't ever plug the machine into the Internet. Also remove IE. I take care of about 250 computers, and there's no way I'd bet my safety on a desktop Windows installation. A customized/embedded/trimmed version that runs off a ROM might be acceptable if it's been through a *very* rigorous testing process -- but after you've seen the difference in performance between a clean machine and a machine after it's been out in the real world (even with Mozilla Firefox, AdAware, Spybot S&D, *and* Symantec Corporate Anti-Virus 10 running on it), you won't want to trust your @$$ to what most people think of as Windows either. A trimmed/embedded/customized Linux would work too, although I think I'd be most comfortable with a device running something like VxWorks[0]. As for the disk drives, I recommend a pair CompactFlash storage modules wired up as IDE devices[1] set up in a RAID mirror setup. That way, the system is more resistant to things that damage moving parts, and with the RAID setup, it will continue to run if one of the CompactFlash devices fails. Use three or four if you don't feel lucky. Of course, you couldn't run desktop Windows on this because the swapfile would quickly wear out the CompactFlash (they can only be written a finite number of times[2]). -Luke [0] In one of my earlier jobs, my task was to make VxWorks run on a single-board-VME Sun clone. I got to read some of the source code, and it's some of the most carefully documented/commented and sanely designed C code I've ever seen. [1] CompactFlash is electrically similar enough to IDE that they can be wired into an IDE bus without the need for a chip. [2] I don't remember exactly what the number is -- I seem to remember that a USB keydrive could take about 500k writes, but it wouldn't surprise me if that has been extended to a couple of million. Also, most Flash devices will remap data internally to avoid repeatedly writing a particular block -- so that the device will last longer. |
Luke Scharf wrote:
Maybe if you replaced the connectors or soldered everything well.... Er, I meant to say that it might work if you soldered everything or replaced the connectors. My post-writing editing made what I was trying to say unclear (though better organized!) -Luke |
Luke Scharf wrote:
Le Chaud Lapin wrote: USB. I think it would be highly appropriate for this type of application. It's way too easy to trip over the cord with USB -- or to have it vibrate loose. My experience with USB indicates that it isn't reliable enough for my servers at work, it's not good enough for any airplane I fly. Maybe if you replaced the connectors or soldered everything well.... But, I'm reluctant to suggest USB to my users for anything more permenant than a mouse. There is already an adequate standard buss for interconnecting avionics devices. I'm sure you can purchase a PC card to interface to that. But you're on the right track. Non-stop, fault-tolerant computing is the issue. |
![]() Stubby wrote in message ... Luke Scharf wrote: Le Chaud Lapin wrote: USB. I think it would be highly appropriate for this type of application. It's way too easy to trip over the cord with USB -- or to have it vibrate loose. My experience with USB indicates that it isn't reliable enough for my servers at work, it's not good enough for any airplane I fly. Maybe if you replaced the connectors or soldered everything well.... But, I'm reluctant to suggest USB to my users for anything more permenant than a mouse. There is already an adequate standard buss for interconnecting avionics devices. I'm sure you can purchase a PC card to interface to that. But you're on the right track. Non-stop, fault-tolerant computing is the issue. The Space Station uses IBM 760xd laptops for their glass cockpit. http://spaceflight.nasa.gov/gallery/...l/sts105-304-0 25.html http://spaceflight.nasa.gov/gallery/.../iss002e5478.h tml http://spaceflight.nasa.gov/gallery/.../iss003e5552.h tml http://www.spaceref.com/news/viewnews.html?id=213 http://www.cisco.com/en/US/tech/tk65...study09186a008 00b53b6.shtml |
Make Thousands of Dollars easily!!!! | [email protected] | Piloting | 0 | June 1st 05 04:15 AM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Lesson in Glass | JimC | Owning | 3 | August 6th 03 01:09 AM |
