The regs say you must communicate, have permission, a clearance, have a
transponder, etc to fly in any Class B/C/D Airspace. The airspace is generally defined by the airport reference point altitude and location on the field. For example the definitions state "from the surface to..." What requirements are there for flying BELOW the airport surface? I know several airports with the requisite airspace that are located above surrounding terrain where it would be possible to fly below the airport surface. What say the group? |
A propeller strong enough to dig through the asphalt? "john smith" wrote in message ... The regs say you must communicate, have permission, a clearance, have a transponder, etc to fly in any Class B/C/D Airspace. The airspace is generally defined by the airport reference point altitude and location on the field. For example the definitions state "from the surface to..." What requirements are there for flying BELOW the airport surface? I know several airports with the requisite airspace that are located above surrounding terrain where it would be possible to fly below the airport surface. What say the group? |
"john smith" wrote in message ... The regs say you must communicate, have permission, a clearance, have a transponder, etc to fly in any Class B/C/D Airspace. What requirements are there for flying BELOW the airport surface? What say the group? To fly BELOW the airport surface is never recommended. Cumulo granite could ruin your day ![]() I fly out of an airport that is near a Class C with a bottom of 1400....just stay below that and there's not a problem. Further down the road is a conglomeration of airspace, but if I stay above 1100, but below 1800.....you get the picture. This technique is probably more trouble than would be worth to plan if you were just passing through, but for the local folks it works well. Later, Stephen Foley, Alabama |
We have just the situation you describe at Seattle-Tacoma Airport...it sits
on high ground adjacent to Puget Sound. On the sectional, just west of the "all the way to the ground" portion of the Class B, there is a blue square with "-30" in it, and the legend says "Minus ceiling value indicates surface up to but not including that value." The surface it refers to is the water. Ergo, the Class B goes all the way to the water, and you can't fly past SEA at 500 feet above the water without a Class B clearance. Paine Field's Class D does not have a similar graphic, but its airspace extends over Puget Sound and I'm guessing that the same reasoning applies. Note that AIM 3-2-5 says that Class D "generally extends from the surface to 2500 feet above airport elevation," thus making a distinction between the surface and field elevation. Bob Gardner "john smith" wrote in message ... The regs say you must communicate, have permission, a clearance, have a transponder, etc to fly in any Class B/C/D Airspace. The airspace is generally defined by the airport reference point altitude and location on the field. For example the definitions state "from the surface to..." What requirements are there for flying BELOW the airport surface? I know several airports with the requisite airspace that are located above surrounding terrain where it would be possible to fly below the airport surface. What say the group? |
Assuming you mean 'below the airspace'
Well, for one... there's the mode C veil. 30 miles from the primary airport located in class bravo, mode C transponders are required and must be transmitting altitude data. |
On Mon, 27 Jun 2005 23:15:06 GMT, john smith wrote in
:: What requirements are there for flying BELOW the airport surface? I would think you'd need some digging equipment. :-) |
There is also a speed issue when inside the 30 mile radius of the Class
Bravo primary. FAR 91.117 covers that..."No person may operate an aircraft in the air space underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots. Fred "john smith" wrote in message ... The regs say you must communicate, have permission, a clearance, have a transponder, etc to fly in any Class B/C/D Airspace. The airspace is generally defined by the airport reference point altitude and location on the field. For example the definitions state "from the surface to..." What requirements are there for flying BELOW the airport surface? I know several airports with the requisite airspace that are located above surrounding terrain where it would be possible to fly below the airport surface. What say the group? |
"john smith" wrote What requirements are there for flying BELOW the airport surface? I know several airports with the requisite airspace that are located above surrounding terrain where it would be possible to fly below the airport surface. What say the group? I would say that if you chose to go down that path of picking at cracks in the definitions, don't be surprised when the crack opens up and sh*ts all over you. g -- Jim in NC |
... The regs say you must communicate, have permission, a clearance, have a transponder, etc to fly in any Class B/C/D Airspace. The airspace is generally defined by the airport reference point altitude and location on the field. For example the definitions state "from the surface to..." The airspace isn't defined by reference to the airport altitude. An airspace that goes down to the surface goes down to the surface at each point in that airspace; otherwise, it would say e.g. "airport elevation to 2600" rather than "surface to 2600". --Gary |
My Cherokee 140 won't even do 140 kts (unless I'm out back pushing it
while in a tailwind and descending g) Fred Choate wrote: There is also a speed issue when inside the 30 mile radius of the Class Bravo primary. FAR 91.117 covers that..."No person may operate an aircraft in the air space underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots. Fred |
| Does USA need a Club Class? | MC | Soaring | 42 | April 7th 05 09:07 PM |
| Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 03:29 AM |
| Meigs Class D Airspace | Defly | Instrument Flight Rules | 0 | July 19th 04 03:53 PM |
| Tower with only Class G Airspace | Jeff Saylor | Piloting | 8 | May 10th 04 10:53 PM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
