Tower with only Class G Airspace
Old May 9th 04, 06:19 AM
Jeff Saylor
Default Tower with only Class G Airspace
Allen C Perkinson Airport/Blackstone Army Airfield (KBKT) in
Virgina has a control tower, at least part of the time. It also
has class G airspace to 700 ft AGL.
What are the procedures for operating at a tower in uncontrolled
airspace? When are you obligated to communicate with the tower,
other than touching the runways? I don't recall this being
discussed much during flight training way back when.
How common is it to have a tower (other than a special temporary
tower, e.g. the one during EAA Oshkosh or AOPA fly-in.) without
at least Class D airspace?
Old May 9th 04, 06:43 AM
nooneimportant
"Jeff Saylor" wrote in message
Got two towers closeby to my field that are not in Class D... My field is
currently nontowered, but is expected to get a tower and upgrade itself, and
one of the two nearby fields to Class D airspace. Basically what I hear is
to treat it just like Class D... 4 mile radius up to 2500 AGL, contact to
transition, land or depart from. From what i understand, and i could be
wrong here, the diff between Towered G and Class D is that Class D does have
radar service.
Old May 9th 04, 06:46 AM
Steven P. McNicoll
§ 91.126 Operating on or in the vicinity of an airport in Class G
airspace.
(d) Communications with control towers. Unless otherwise authorized or
required by ATC, no person may operate an aircraft to, from, through, or on
an airport having an operational control tower unless two-way radio
communications are maintained between that aircraft and the control tower.
Communications must be established prior to 4 nautical miles from the
airport, up to and including 2,500 feet AGL. However, if the aircraft radio
fails in flight, the pilot in command may operate that aircraft and land if
weather conditions are at or above basic VFR weather minimums, visual
contact with the tower is maintained, and a clearance to land is received.
If the aircraft radio fails while in flight under IFR, the pilot must comply
with §91.185.
Not very, and becoming more rare. Under airspace reclassification some ten
years ago, airports with control towers and control zones that were not in a
TCA or an ARSA had Class D airspace established. Note that a tower AND a
control zone were required for Class D airspace. There were a few airports
with control towers that had no control zones, such as Blackstone.
Old May 9th 04, 07:03 AM
Jeff Saylor
radar service.
That's not correct, many (most?) Class D towers do not have radar services. If
they have a radar display at all, it is probably a remote from another facility,
unless the class D is surrounded by a TRSA. (Or it has its own approach
control, such as KRDG, Pennsylvania.)
Old May 9th 04, 07:12 AM
Jeff Saylor
airspace.
with §91.185.
So basically it's not very different to the pilot than a class D airspace tower.
Was there any advantage to having the airspace class G or E instead of making it
D and charting it appropriately? It would make the airspace more clear, user
friendly, and standardized for the pilot.
I can barely remember the old airspace system, but at least the newer
classifications are (usually) more standard and make more sense. (Until you go
to another country, of course and find out they use Class B as enroute higher
altitude airspace, rather than just for large terminal areas)
I never thought that an Airport Radar Service Area was very descriptive from a
Terminal Radar Service Area, since Airport and Terminal are not well
distinguished terms from each other for that purpose, even though their defined
FAA meanings were quite differenet.
Old May 9th 04, 07:23 AM
Steven P. McNicoll
"nooneimportant" no.spam@me wrote in message
news:fGinc.54758$Ik.4084674@attbi_s53...
From what i understand, and i could be wrong here, the diff
radar service.
Well, you're wrong here. Radar service has nothing to do with Class D
airspace.
Old May 9th 04, 07:28 AM
Steven P. McNicoll
instead of making it D and charting it appropriately? It would make
the airspace more clear, user friendly, and standardized for the pilot.
A permanent control tower in Class E airspace would make no sense since it
would have all the properties of Class D airspace.
(Until you go to another country, of course and find out they use
Class B as enroute higher altitude airspace, rather than just for
Where the various classes of airspace are used is variable, but the
properties of the airspace are not.
Brad Z
Blackstone is weird in that the tower is operational only by notam.
Although, I flew in IFR for a practice approach once and Washington Center
approved a freq change...since there was no notam I made a position report
on CTAF (diff freq from tower) and got a "cleared to land" from somebody.
Caught me off guard, since the tower is almost never open. Since then, I
have gone back to my old approach of trying the tower frequency first. To
answer your question, if the CT is active, treat it like Class D.
Old May 10th 04, 10:53 PM
Ron Natalie
"Jeff Saylor" wrote in message ...
Pretend it has a class D. While this sort of non-sense was not supposed
to happen after the airspace reclassification, the FAA added the rules back
shortly thereafter. Check 91.126(d) and 127(c)
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 03:29 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 03:53 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 07:12 PM
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? steve mew Piloting 38 October 28th 03 07:08 PM
