Sparkplug torque values
Old July 4th 05, 08:36 AM
Roger
Default Sparkplug torque values
I've spent the better part of an hour and a half on the net searching,
tried to get into the ABS site which appeared to be down, spend
several hours searching through what manuals I have, but I couldn't
find the torque required for the spark plugs in an IO-470N.
I did find the torque values for about any bolt size you'd ever find
on an airplane (wet or dry) though:-))
Any one have that, or a URL for the source?
www.rogerhalstead.com
Old July 4th 05, 11:06 AM
Philippe
For all sparks
diameter
18mm
- in steel : 34-45N.m / 3.5-4.5kg.m / 25.3-32.5lb.ft
- in Al alloy: 35-40N.m / 3.5-4.0kg.m / 25.3-28.9lb.ft
14mm
- in steel : 25-35N.m / 2.5-3.5kg.m / 18.0-25.3lb.ft
- in Al alloy: 25-30N.m / 2.5-3.0kg.m / 18.0-21.6lb.ft
12mm
-in steel : 15-25N.m / 1.5-2.5kg.m / 10.8-18.0lb.ft
- in Al alloy: 15-20N.m / 1.5-2.0kg.m / 10.8-14.5lb.ft
10mm
- in steel : 10-15N.m / 1.0-1.5kg.m / 7.2-10.8lb.ft
- in Al alloy: 10-12N.m / 1.0-1.2kg.m / 7.2-8.7lb.ft
8mm
- in Al alloy: 8-12N.m / 0.8-1.0kg.m / 5.8-7.2lb.ft
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old July 4th 05, 04:25 PM
RST Engineering
....tug ... tug ... right about ... THERE.
BTW, that copper loaded goose grease is so far superior to the black
graphite stuff it isn't even funny. Just FYI
"Roger" wrote in message
Old July 4th 05, 06:07 PM
Jim Carriere
I thought it was tighten until it strips, then back off a quarter turn?
Old July 4th 05, 06:41 PM
A former cow-orker had an old Stinson on which, at some point
in time, the threads had been stripped and repaired with helicoils.
He used _Never Seize_ (which I think is grease with powdered nickel)
on his sparkpluck threads and the heli coils backed out.
Dunno if the Never_Seize was to blame, but he said the problem
didn't repeat after he cleaned it off.
FF
Old July 4th 05, 07:11 PM
Dan, U.S. Air Force, retired
That's on aluminum blocks. On iron you tighten until the plug breaks,
remember how it felt and don't tighten so much next time.
Old July 5th 05, 12:19 AM
jerry wass
Jim I take a little artists brush & paint that coppercoat all over
the insulator too--makes'em easier to see if you drop them in the dirt.
Old July 5th 05, 12:30 AM
jerry wass
on another note, the nickel stuff is really great---Back in the gas
drillin boom days, the rigs used that stuff out of 5 gallon pails,
mopped it on the drill stem joints with mops. the nickel was suspended-
(immediately after stirring) in a very heavy chloro-ethylene solvent.
anybody need a gallon ??
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 12:46 AM
Torque values for oil screen John Clonts Owning 2 January 25th 05 12:01 AM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
About those anti-aviatoin newsgroups C J Campbell Piloting 200 August 21st 03 02:25 PM
