Could someone please tell me the proper torque for the oil screen housing in my IO-520-FCL? Also the oil drain
plug? I can't get hold of my A&P until Monday but I want to change the oil tonight... Thanks! John Clonts Temple, Texas N7NZ |
John Clonts wrote:
Could someone please tell me the proper torque for the oil screen housing in my IO-520-FCL? Also the oil drain plug? I can't get hold of my A&P until Monday but I want to change the oil tonight... Thanks! John Clonts Temple, Texas N7NZ John, Both of these items use a copper crush gasket for sealing. I am not aware of any "torque" value published for such items. Using *new* gaskets, turn the screen/plug in until gasket contact is made, then an additional 1/4 turn (45 degree rotation) should do it. As you are turning your wrench, you will feel the friction gradually increase, until proper compression is achieved, at which point the friction starts to rapidly increase. This is sometimes called the "calibrated elbow" approach, and is quite adequate for these types of gasket. As a side note, a quick drain plug greatly simplifies this procedure, if space permits. As far as the oil screen goes, most people safe-tie these, but is not necessary. Take a look at the next TCM factory new/overhauled engine you get a chance to see. Happy Flying! Scott Skylane N92054 |
![]() "Scott Skylane" wrote in message ... John Clonts wrote: Could someone please tell me the proper torque for the oil screen housing in my IO-520-FCL? Also the oil drain plug? I can't get hold of my A&P until Monday but I want to change the oil tonight... Thanks! John Clonts Temple, Texas N7NZ John, Both of these items use a copper crush gasket for sealing. I am not aware of any "torque" value published for such items. Using *new* gaskets, turn the screen/plug in until gasket contact is made, then an additional 1/4 turn (45 degree rotation) should do it. As you are turning your wrench, you will feel the friction gradually increase, until proper compression is achieved, at which point the friction starts to rapidly increase. This is sometimes called the "calibrated elbow" approach, and is quite adequate for these types of gasket. As a side note, a quick drain plug greatly simplifies this procedure, if space permits. As far as the oil screen goes, most people safe-tie these, but is not necessary. Take a look at the next TCM factory new/overhauled engine you get a chance to see. Happy Flying! Scott Skylane N92054 Thanks Scott, I ended up delaying so I can get the new gaskets. But I also found this: http://www.tcmlink.com/serviceBulletins/pdf/sb96-7B.pdf If I read it right it's about 16 ft-lbs for the oil sump drain, and 42 ft-lbs on the Oil filter screen... Cheers, John Clonts Temple, Texas N7NZ |
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). | Phillip Rhodes | Military Aviation | 0 | September 7th 04 01:30 PM |
Narrow Foil Strips for Ground Plane | Dennis Mountains | Home Built | 22 | August 29th 04 01:09 AM |
Foil Antenna on Carbon Fiber | Dennis Mountains | Home Built | 7 | April 24th 04 12:54 AM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
Garmin 195 screen problem | BPattonsoa | Home Built | 30 | December 3rd 03 02:14 AM |
