Another reason to fly GA...
Old July 27th 05, 06:47 AM
Roger
On Tue, 26 Jul 2005 11:18:36 -0400, Corky Scott
I wrote:
Sorry Icebound, I can't tell if you are being sarcastic or if you
really believe this. I thought it was common knowledge now that the
Bush administration actually did invent the WMD specifically to start
the war.
On Mon, 25 Jul 2005 17:55:23 -0400, Bob Noel
at one time it was common knowledge that the earth was flat.
Exactly, until it was overwhelmingly proved otherwise. Thanks, great
parallel.
Unfortunately, some still believe the world is flat... Another great
parallel.
Yup! The only way you can have true parallels N/S AND E/W is on a flat
surface. We've been given two paralles so it must be flat.
www.rogerhalstead.com
Corky Scott
  #112
Old July 27th 05, 10:49 PM
Matt Whiting
W P Dixon wrote:
Wow that's sad!,
I don't understand why the cops have such poor shots. At 500 meters I
am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on
out there. Really makes the officers look like Keystone Cops when the
only inflicted wound in a 50 round fired shoot out is a bruise from an
ejected 9mm empty brass!
You are obviously using much larger targets than the rest of us.
Matt
  #113
Old July 27th 05, 11:32 PM
John E. Carty
W P Dixon wrote:
Wow that's sad!,
Ever been in a firefight where the 'target' is shooting back at you? Makes a
difference :-)
  #114
Old July 27th 05, 11:49 PM
W P Dixon
As an old Marine you could say I have been in a 'few" firefights..and my
target was the basic human "shadow" and all hits are in the center chest .
Also Marine rifle coach with 4 awards expert rifleman. And I still do not
see how a 'trained' professional marksman can miss so much. An M-16/AR-15 is
a very accurate weapon in the right hands.
Patrick
"John E. Carty" wrote in message
W P Dixon wrote:
Wow that's sad!,
a difference :-)
  #115
Old July 27th 05, 11:56 PM
Sylvain
there is also a bit of a difference between shooting in a safe
environment at cardboard targets that don't move and don't
shoot back (I am not half bad at that either) and doing
same in a combat zone environment (about which I don't have
the beginning of a clue, but I'd guess it probably affects
one's marksmanship a bit)
--Sylvain
  #116
Old July 28th 05, 12:03 AM
W P Dixon
You are correct , it will have an effect but some of these stories of 50-75
shots being fired within 15 feet and no one gets a scratch? Hardly a
professional marksman. A SWAT sniper should NEVER miss as for the fact is he
is a sniper and should be in hiding and not seen thus not in the situation
of having return fire .
Patrick
"Sylvain" wrote in message
--Sylvain
  #117
Old July 28th 05, 03:21 AM
John E. Carty
I'm also a former combat Marine and could always hit 10 for 10 from the 500
yard line (it was never measured in meters for us) with an M-16 with open
sights. However, firing a rifle from the prone position and firing a handgun
while on the move are two entirely different things :-)
"W P Dixon" wrote in message
is a very accurate weapon in the right hands.
Patrick
W P Dixon wrote:
Wow that's sad!,
I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy
on out there. Really makes the officers look like Keystone Cops when
the only inflicted wound in a 50 round fired shoot out is a bruise from
an ejected 9mm empty brass!
Makes a difference :-)
  #118
Old July 28th 05, 03:36 AM
W P Dixon
but John,
50 or so shots and not hit anything? Now firing the old .45 out the huey
door while flying, doubt I could hit anything ..but you'd have to be running
away firing over your shoulder not to hit anything that close. My grandma
could get a better grouping than that! heck alot of these "shoot outs" are
within 15 feet. Maybe it's all the donut glaze stuck on their trigger
fingers?
Semper Fi,
Patrick
500 yard line (it was never measured in meters for us) with an M-16 with
open sights. However, firing a rifle from the prone position and firing a
handgun while on the move are two entirely different things :-)
. Also Marine rifle coach with 4 awards expert rifleman. And I still do
not see how a 'trained' professional marksman can miss so much. An
M-16/AR-15 is a very accurate weapon in the right hands.
Patrick
W P Dixon wrote:
Wow that's sad!,
from an ejected 9mm empty brass!
  #119
Old July 28th 05, 05:28 AM
John E. Carty
Patrick,
Hey, that old .45 certainly had better stopping power then a 9mm, but we
only had 7 rounds in which to hit the target! :-)
Semper Fi,
John
{Formerly}
Headquarters Company
2nd Force Service Support Group
Fleet Marine Force Atlantic
Camp Lejeune, NC
but John,
running away firing over your shoulder not to hit anything that close.
My grandma could get a better grouping than that! heck alot of these
"shoot outs" are within 15 feet. Maybe it's all the donut glaze stuck on
their trigger fingers?
Semper Fi,
Patrick
Patrick
W P Dixon wrote:
Wow that's sad!,
meters I am bullseye 10 out 0f 10 , with a scope that range would get
wayyyy on out there. Really makes the officers look like Keystone
Cops when the only inflicted wound in a 50 round fired shoot out is a
bruise from an ejected 9mm empty brass!
  #120
Old July 28th 05, 01:14 PM
W P Dixon
Yep,
The old .45, we seemed to always have the most rattlin' pistols available.
Loose barrels and all, but was sad to see them start going bye bye in the
80's. And now I carry a 9mm, would not dream of carrying the .45 anymore. I
like the .45 stopping power, but I am much more accurate with the 9mm. Can't
say that is the way it is for everyone but it sure makes a difference in my
grouping!
But hey maybe we may be onto something there? Maybe some of those
officers need to caliber down? Maybe they could also get a better grouping
by using the smaller cal? I like the CZ52 myself, matter of fact I need to
get me another one! Pick them up really cheap and do some custom work on it
and you have a nice custom slabside for a fraction of the cost of the new
tricked out .45's . And sorry guys , I guess we have gotten way off the
aviation toipc here.
Patrick
student SPL
aircraft structural mech
(formerly)
HML-167, HMM-261 REIN
MCAS NEW RIVER
USS Iwo Jima 22MAU
Peacekeeper
Patrick,
Semper Fi,
John
{Formerly}
Camp Lejeune, NC
The Real Reason For Airlines' No Smoking Policy Larry Dighera Piloting 3 April 3rd 05 09:16 PM
Give Me A GOOD Reason [email protected] Piloting 43 January 27th 05 03:24 PM
Is expense of a new sailplane the reason? Nolaminar Soaring 0 January 7th 05 03:40 PM
