Turbo Lance II opinions
Old August 22nd 05, 04:55 PM
Mike Rapoport
"john smith" wrote in message
I've seen some Lance's advertised with Turbo and then there are some that
specifically advertise Turbo with Intercooler. Are these two seperate
options available or are they one in the same? The Lance I'm looking at
just says Turbo in the ad and doesn't mention any intercooler.
The intercooler is a aftermarket STC'd modification. Without it, the
airplane will not be able to maintain high power settings above about
16,000' without overheating.
An intercooler is a radiator that cools a gas (air) instead of a liquid.
When air is compressed (what a turbocharger does) it heats up. When a gas
is heated it wants to expand (return to an uncompressed state), so you
place an intercooler (or two) inline following the turbocharger and before
the engine air intake, to cool the heated, compressed air before it enters
the engine, providing cooler, more dense air to the engine.
Cooler dense air can absorb more heat than hotter dense air and provide
greater expansion and therefore more power.
Or it can provide the same power with all the temperatures being lower
(inlet, combustion, EGT, TIT).
Mike
MU-2
Old August 22nd 05, 05:29 PM
John Doe
Thanks for all the info. This is all great stuff and hopefully I'll be able
to make the right decision when it comes time to purchase.
Old August 22nd 05, 05:31 PM
John Doe
I found some readings that said the Turbo Lance has a fixed wastegate and
that there are other systems out there that have a manual wastegate that
allows the pilot to better control the turbo.
How much of this is really a factor and should I really care?
Old August 22nd 05, 05:44 PM
Mike Rapoport
You could interpret a manual wastegate as something that you have more
control over or you could say that it just provides more workload :-). The
Turbo Lance wastegate is attacked to the throttle linkage and works pretty
well. The best system is a compensated automatic wastegate but that is
considerably more expensive and complex.
Mike
MU-2
"John Doe" wrote in message
news:R5nOe.17574$Co1.9024@lakeread01...
Old August 22nd 05, 06:40 PM
Dave Butler
For my money, I'd care. There is a series of 6 articles on turbocharging by John
Deakin at avweb.com. Here's a link to the index of John's Pelican Perch articles:
http://www.avweb.com/news/columns/182146-1.html
Scan down the list to the "Those Fire-Breathing Turbos" articles.
Dave
Old August 22nd 05, 08:39 PM
John Doe
"Dave Butler" wrote in message
news:1124732805.292189@sj-nntpcache-3...
by John Deakin at avweb.com. Here's a link to the index of John's Pelican
Perch articles:
Dave
Awesome link, THANKS!
Old August 22nd 05, 11:59 PM
On Mon, 22 Aug 2005 14:39:32 GMT, john smith wrote:
snip
gas is heated it wants to expand (return to an uncompressed state), so
you place an intercooler (or two) inline following the turbocharger and
before the engine air intake, to cool the heated, compressed air before
it enters the engine, providing cooler, more dense air to the engine.
Technically, an intercooler is a "radiator" placed between a
exhaust-driven turbine compressor and a mechanically-driven turbine
compressor (a la B-17). Your description of an aftercooler is spot-on.
You may not be familiar with the Turbo Lance/'Toga "intercooler"
installation. It is a relatively inefficient aftercooler installation
that has other very important benefits.
It changes the existing lower cowl design from a single common air
inlet which is shared between updraft cylinder cooling, induction air
supply, and oil cooling air cupply. The new lower cowl has separate
inlets for updraft cylinder cooling, induction air, and oil cooling,
as well as the aftercooler inlet.
Unfortunately, the outlet of the aftercooler heat exchanger is
exhausted into the pressure area for the updraft cylinder cooling.
The installation will drop operating CHT by approximately 40-60
degrees F, and operating oil temp by 20-40 degrees. Considering that
CHT can run 450 F and oil temp 220+F this is a very good thing.
I honestly cannot recall the typical induction air temp drop, but the
overall package works quite well. IMHO this is as much a result of
improved engine/oil cooling air flow as actual induction air cooling.
Personally, I would not consider operating a Turbo 'Toga/Lance without
this modification.
Regards;
TC
Old August 23rd 05, 04:59 PM
John Doe
this modification.
Well it seems that after reading all the articles mentioned on turbos and
your comments, my decision has come down to one aircraft with and one
without this intercooler mod.
I'm assuming this mod can be performed aftermarket. Do you happen to know
the cost of performing the mod?
The asking price difference right now between the two is about 20k. There
are some other factors going into that cost, but I need to be able to
justify the extra $$$.
Old August 24th 05, 12:45 AM
On Tue, 23 Aug 2005 11:59:51 -0400, "John Doe"
10 years ago it was around $6500 + install. Only web reference I could
find for the kit says $7495 (no idea how old).
Unfortunately, other digging around on the 'net indicates that
Turboplus is not currently an operatiing GA entity. Found a post by a
guy that says he owns all the paperwork/assets and is looking for a
buyer.
Could call these guys, I guess:
http://www.barteltaviation.com/install.htm
Back to airplane shopping:
If I was looking at these aircraft, I would want to know EXACTLY how
much total time was on the exhaust components. Would NOT recommend
running any of them past recommended TBO. Anybody that tells you any
different has very likely never seen the results of a turbo lance/toga
exhaust failure/engine fire.
On a test flight, look/ask about typical oil temp/CHT indications in
cruise. If the engine has been operated for any period of time with an
oil temp over 210 or CHT over 450 (hard to tell, no numbers on factory
gauge) is likely to have cam spalling & accelerated e-valve guide
wear.
Don't ask me how I know this...
TC
Old August 24th 05, 01:19 AM
John Doe
buyer.
wear.
TC
TC,
Thanks. That's what I'm worried about. It only has an EGT gauge and
nothing to monitor CHT or TIT, etc.
Is there going to be problems getting parts for the turbo system ?
Why turbo normalizer? Robert M. Gary Piloting 61 May 20th 05 04:33 PM
Turbo prop AT-6/SNJ? frank may Military Aviation 11 September 5th 04 02:51 PM
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 09:08 PM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 10:43 PM
Piper Lance Renee Purner Owning 22 November 4th 03 07:47 PM
