Turbo Lance II opinions
Old August 20th 05, 11:39 PM
John Doe
Default Turbo Lance II opinions
Hello,
I'm looking to talk with someone who's owned a Turbo Lance for their
opinions on ownership and maintenance.
Thanks.
Old August 21st 05, 02:55 AM
Mike Rapoport
My first airplane was a 79 Turbo Lance. I bought it for the roomy cabin for
my dogs, reasonably fast cruise and fairly good altitude capibility. It was
a releative bargin compared to other six place, 170+kt, turbo airplanes. I
found it to be a good airplane for me and it met my expectations. Mine had
most of the availible speed mods and an intercooler which I recommend. I
only had if for about 16 months so I can't tell you what the long term cost
of ownership would be.
MU-2
"John Doe" wrote in message
k.net...
Hello,
Thanks.
Old August 21st 05, 04:04 AM
Vertical Rate
Hello,
Thanks.
I used to fly one for a small company. It's a good airplane overall, lots
of room and payload. When this company was looking for an airplane, they
asked me to research the Turbo Lance II, specifically a 1979 they were
looking at and eventually purchased. I discovered from an analysis of
accidents in the NTSB database that this model has had a number of smoke in
the cockpit and/or fire in the engine compartment events due to the
turbocharger. IIRC, one of the events occurred even though an AD
specifically designed to stop this kind of thing was incorrectly done, and
some of the fault was laid on the AD itself for being difficult and
confusing.
While I've since lost the data, somebody posted a question about this make /
model in this newsgroup or R.A.P a few years ago and I responded to it (not
under this username) by posting my summary of what I learned about the
plane. You can probably find it in google / dejanews.
Engine temp control is important and you ought to have an all cylinder
engine monitor on it like a JPI. Get the cowling mod because it provides a
little speed increase and more importantly improves cylinder cooling.
Old August 21st 05, 05:43 AM
Mike Rapoport
Wasn't there a change in the exhaust system to iconel that fixed the
problem?
MU-2
"Vertical Rate" wrote in message
Hello,
Thanks.
in
confusing.
(not
a
Old August 21st 05, 04:30 PM
John Doe
ink.net...
for my dogs, reasonably fast cruise and fairly good altitude capibility.
It was a releative bargin compared to other six place, 170+kt, turbo
airplanes. I found it to be a good airplane for me and it met my
expectations. Mine had most of the availible speed mods and an
intercooler which I recommend. I only had if for about 16 months so I
can't tell you what the long term cost of ownership would be.
MU-2
With all that being said, why did you sell it so fast?
Old August 21st 05, 04:38 PM
John Doe
ink.net...
MU-2
I must admit that I'm not very smart on the turbo options. This would be my
first turbo engine.
I've seen some Lance's advertised with Turbo and then there are some that
specifically advertise Turbo with Intercooler. Are these two seperate
options available or are they one in the same? The Lance I'm looking at
just says Turbo in the ad and doesn't mention any intercooler.
Thanks.
John Doe
ink.net...
MU-2
first turbo engine.
Thanks.
Old August 22nd 05, 03:14 PM
Mike Rapoport
ink.net...
ink.net...
MU-2
I needed an airplane that could cross the Sierra in virtually any weather so
I needed deice and radar. I was making flights where I had to be at the
destination.
MU-2
Old August 22nd 05, 03:17 PM
Mike Rapoport
news
ink.net...
MU-2
my
first turbo engine.
Thanks.
The intercooler is a aftermarket STC'd modification. Without it, the
airplane will not be able to maintain high power settings above about
16,000' without overheating.
MU-2
Old August 22nd 05, 04:39 PM
john smith
An intercooler is a radiator that cools a gas (air) instead of a liquid.
When air is compressed (what a turbocharger does) it heats up. When a
gas is heated it wants to expand (return to an uncompressed state), so
you place an intercooler (or two) inline following the turbocharger and
before the engine air intake, to cool the heated, compressed air before
it enters the engine, providing cooler, more dense air to the engine.
Cooler dense air can absorb more heat than hotter dense air and provide
greater expansion and therefore more power.
Why turbo normalizer? Robert M. Gary Piloting 61 May 20th 05 05:33 PM
Turbo prop AT-6/SNJ? frank may Military Aviation 11 September 5th 04 03:51 PM
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 10:08 PM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 11:43 PM
Piper Lance Renee Purner Owning 22 November 4th 03 08:47 PM
