#31
![]() "Mike Rapoport" wrote in message ink.net... There has never been a case of rudder reversal caused by icing. Wrong. Flow seperation due to icing is normal. |
#32
Julian Scarfe wrote:
"Matthew S. Whiting" wrote in message ... However, keep in mind that most thermometers have some error in them. So, even though ice doesn't form above 0C, it may form above 0C as indicated on your airplane thermometer. Absolutely true, but remember that your thermometer is one of the easiest instruments in the aircraft to calibrate. The ATIS gives the temperature on the ground before flight -- it's well worth a check. Julian Scarfe Yes, but where is their thermometer? On the ground near the level of your plane, or on top of the tower? Makes a lot of difference. Also, the error may be a slope error, not just a offset. It may be off by 2 degrees at 70 degrees, but less than that at 32 (or more, but typically error gets less at lower temps). I prefer to watch things very carefully when the temp is between about 0 and 35F. Most ice I've picked up was between 26 and 32 as indicated by my Skylane thermometer. No idea how accurate it was, but I think it was within a couple of degrees which is close enough for most purposes. I make decisions based on what is happening on the wing, not what the thermometer says, generally anyway. Matt |
#33
Bob Gardner wrote:
That is the icing rule all pilots should remember: There are no hard-and-fast rules with regard to airframe icing. Well, I think there is one ... get out of the condition causing the airframe icing ASAP! Matt |
#34
Please cite a single reference of rudder reversal caused by icing.
Mike MU-2 "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message ink.net... There has never been a case of rudder reversal caused by icing. Wrong. Flow seperation due to icing is normal. |
#35
Julian Scarfe
Absolutely true, but remember that your thermometer is one of the easiest instruments in the aircraft to calibrate. The ATIS gives the temperature on the ground before flight -- it's well worth a check. Although the temperature at the ATIS station and the temperature where you thermometer is located may quite a few degrees off. Kinda like setting your Heading Indicator when lined up on the runway. Hilton |
#36
In article . net,
"Hilton" wrote: Julian Scarfe Absolutely true, but remember that your thermometer is one of the easiest instruments in the aircraft to calibrate. The ATIS gives the temperature on the ground before flight -- it's well worth a check. Although the temperature at the ATIS station and the temperature where you thermometer is located may quite a few degrees off. Kinda like setting your Heading Indicator when lined up on the runway. Hilton Not to mention that: 1) The ATIS could be up to an hour old 2) The ATIS temperature was taken with a thermometer in a carefully designed enclosure which keeps it out of direct sun and wind. Your OAT probe has none of those protections. On the other hand, a slurry of crushed ice and water makes a pretty good home-made 0C temperature reference. If you wanted to, I suppose you could use that to calibrate your OAT-o-meter. |
#37
![]() "Mike Rapoport" wrote in message ink.net... Please cite a single reference of rudder reversal caused by icing. It is all part of the FAA's results from their icing study. Brownlee expressed FAA's surprise that the results of their experiment were the opposite of what their expectations had been. If you mean that you want me to do a google search for you, I think you know better than that. |
#38
... Yes, but where is their thermometer? On the ground near the level of your plane, or on top of the tower? Makes a lot of difference. Fair point. At least in my part of the world, reported temps are supposed to be 2 metre temps (measured about 6 ft above the ground). But as others have pointed out there may be differences because of the local measurement environment. I still think it's well worth making a comparison between your OAT and the reported temperature. It's not difficult to spot consistent deviations of a couple of degrees. Julian Scarfe |
#39
"Tarver Engineering" wrote:
Please cite a single reference of rudder reversal caused by icing. It is all part of the FAA's results from their icing study. LOL |
#40
No, I want you to provice a single reference of rudder reversal caused by
icing which you are contending is a major problem. Not only is it not a major problem, it has never occured Mike MU-2 "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message ink.net... Please cite a single reference of rudder reversal caused by icing. It is all part of the FAA's results from their icing study. Brownlee expressed FAA's surprise that the results of their experiment were the opposite of what their expectations had been. If you mean that you want me to do a google search for you, I think you know better than that. |
Removing water repelent from fiberglass lay-up? | Roger | Home Built | 2 | December 2nd 04 11:15 PM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
water bombers | Stew Hicks | Home Built | 2 | September 8th 03 11:55 PM |
water bombers | Stew Hicks | Home Built | 0 | September 7th 03 04:27 PM |
Need help with Fluid Mechanics equation | Doug | Home Built | 4 | August 16th 03 03:13 AM |
