Removing water repelent from fiberglass lay-up?
Old November 20th 04, 09:51 AM
Roger
Default Removing water repelent from fiberglass lay-up?
I had about a third of the inside of the horizontal stab get a through
dose of water repellent for leather. The stuff has a very low
viscosity and I think will soak right into the resin preventing a good
bond. No it's not silicon.
Any good way of removing this stuff without destroying the stab in the
process. There are a not of nooks and crannies that you just can't
reach.
www.rogerhalstead.com
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 3rd 04 12:15 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
