Problems with Rapco dry vacuum pumps.
Old September 22nd 05, 03:41 PM
How about a slinger followed by a felt seal? The slinger can be made
from an o-ring. Felt will catch any tramp oil, is cheap, & can run dry.
The felt will wear. It's used in many older aircraft wheel
bearings (even some newer ones, and it doesn't work that well. It has
to be saturated with grease to prevent water uptake, and thereby
attracts dust. If it soaked up oil it would become saturated and allow
the oil past.
Autos and trucks abandoned felt seals in the '40s and '50s.
Dan
Old September 23rd 05, 12:53 AM
abripl
Me,
I am (was) a kit builder. 200hrs PPL, now flying the
completed kit 18 months, 84hrs. Guess thats why
I am complaining since there was little "bad"
vacuum pump info available to me as a builder.
I do have a science/engineering background.
Hey, I am also a fellow Canuck but living in US now.
Wish I had the money back for all things I tried
that didn't work out as well.
SQ2000 canard: http://www.abri.com/sq2000
What's your experience?...
Old September 23rd 05, 02:13 AM
Reggie
If the pump ran for the life of the engine TBO, who
would make money on that!!!!!
For a sealless drive use a magnetic coupling similar
to:
http://www.micropump.com/tech_tips/magnetic_drives.asp
Reggie
Old September 23rd 05, 04:31 PM
It would be nice to use a magnetic coupling, but the power
transfer in these pumps is too much. The mag coupling has been around
for years and the vac pump manufacturers would be aware of it. Another
problem with magnets: they'd be close to the magnetic compass, being on
the back of the engine in most cases, and we have enough trouble with
magnetic fields as it is when we go to calibrate compasses.
"abripl"'s solution of an electric drive, especially if it's
away from the engine, is alright as long as he doesn't intend to fly
IFR, unless he has a vacuum-driven turn coordinator. Most TCs are
electric, and with attitude and heading gyros relying on an electrical
source all attitude info would be lost if the electrical system quit,
which they can do at the worst possible times. I haven't yet dealt with
the new glass panels, but would hope that they'd have some backup
power; the ones I see have peanut gyros in the panel as backups.
Dan
Old September 23rd 05, 08:16 PM
abripl
Actually it was not a solution for my vaccum pump but I simply went to
an electric horizon - removing the vacuum. I only use the electric
horizon (plus altimeter and speed ind.) as backup. I use Dynon's
EFIS-D10 for my primary flight instruments - and have the necessary IFR
certifications. You can see the panel on bottom of
http://www.abri.com/sq2000/choices.html
Old September 23rd 05, 09:05 PM
abripl
Most TCs are electric, and with attitude and heading gyros relying on an
electrical source all attitude info would be lost if the electrical system quit,
Oh that. I have a dual battery system and my EFIS-D10 has its own
internal backup battery to last an hour. The dual batteries have
40amp-hour total capacity and normal flight current is only about 12A.
Read more details at http://www.abri.com/sq2000
Old September 23rd 05, 11:57 PM
Reggie
MAGNETIC pump drive
Date: 23 Sep 2005 08:31:24 -0700
Local: Fri, Sep 23 2005 8:31 am
Subject: Problems with Rapco dry vacuum pumps.
Dan
http://www.manufacturingcenter.com/d...ustonemore.asp
The drives are manufactured by MagnaDrive Corp, Seattle, WA. Suited for
motors from 10 to 1000 hp, the company's drives and couplings,
according to Ron Woodard, MagnaDrive president and CEO, "also
eliminate hard starts and much
of the vibration associated with power transfer, allowing M-I/SWACO to
redesign their oil centrifuges with fewer control systems and with a
smaller footprint."
THEREFORE Dan,
Your torque limit is a design / weight problem, not a technology
limit. (Reggie)
http://www.sacskyranch.com/rapco.htm
The Edo(or Sigma-Tec) quill-shaft is designed to fail at 100
inch-pounds of torque,
whereas
Airborne drive takes (250 inch-pounds) to snap .
Therefore it's not a lot of torque required, and you would not
need the break away coupling as the magnetic field does that....
(Reggie)
As far as the magnet compass problem
Beware of:
Alternators, especially permanate magnetic ones.
Elecrtic gyro instruments.
Too closely placed electric vaccuum pumps
and
Magnetized steel air frame structure.
Reggie
  #28
Old September 24th 05, 03:48 PM
You're right. There would be plenty of torque transfer available for
a vacuum pump. Now someone needs to try it.
Dan
  #29
Old September 25th 05, 05:29 AM
abripl
Tim,
Wish you posted this before. I kind of suspected possibly cleaning it
but was afraid of messing it up. I sent it back to Rapco who refused to
warranty service it but gave me a discount deal on a new replacement
pump.
Tim Hickey wrote:
If you do not hear the vanes fall, they most likely are "hung up" due
to some contamination. Open the pump, and clean everything. Put it
back together. I use a little silicon seal to act as a gasket on the
back joint of the pump.
I think that the pumps fail when the vane gets sticky and refuses to
slide in and out of the slot in the rotor. I know that the slots in
the rotor will wear larger eventually, but I listen to my pump every
25 hours at the oil change and have had to clean the pump twice in the
last 250 hours. The pump now has about 800 hours on it.
Wet vs Dry Vacuum Pump Fastglasair Owning 7 December 17th 04 11:46 PM
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Dual vacuum pumps bad news Javier Henderson Owning 3 May 7th 04 09:06 PM
Low vacuum at idle Chad Lemmen Owning 1 August 18th 03 09:24 PM
