Wet Vacuum Pumps
Old August 19th 04, 12:07 AM
DBlumel
Default Wet Vacuum Pumps
Is anyone besides me using a wet vacuum pump out there. If so how are you
dealing with the oil output? Do you have an air/oil separator just for it? I
tried tying it into my Christen inverted oil system separator but that does not
work because of the large air volume, (high pressure) from the vacuum pump
compared to the engine breather (very low pressure and low volume). I am
loosing about a quart every 4 hours durring non aerobatic flight. I am running
with about 6 quarts on an IO-360-C1D6 angle valve engine. I don't want to throw
oil away ($$) plus its a mess on the belly. $360.00 from M-20 for a vacuum pump
separator seems alot for what it is.
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 16th 04 12:30 AM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 05:34 PM
Resin INfusion: Better than Vacuum Bagging Steve G Home Built 0 February 3rd 04 12:11 AM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 06:42 AM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 07:10 PM
