How get get serial number of GNS-430?
Old September 25th 05, 03:54 AM
Andrew Gideon
Default How get get serial number of GNS-430?
Wanting to put our club's 430s on the upgrade list, I need to get the serial
numbers. Is there a page with this in the unit itself? I looked the other
day, but didn't spot it.
Thanks...
Andrew
Old September 25th 05, 11:57 AM
Peter R.
Thanks...
I don't recall seeing a page either. How about looking in your aircraft's
maintenance logs or the club's paper receipts for the unit?
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old September 26th 05, 02:11 AM
Andrew Gideon
I've not checked myself, but another club member has for one aircraft and
didn't locate this.
- Andrew
Old September 26th 05, 07:55 PM
Chuck
Thanks...
Peter
The installing shop will have the serial number. I just checked with my installer (G-Force at CAK) and they had already sent in all the names for the units they had installed. Now if/when Garmin says the word.....
Chuck
Old September 26th 05, 08:29 PM
Yankee Whiskey
serial
other
Get an allen wrench, unlock it from the tray, yank it out, and take a look
at the tag on the back. You're not going to hurt it.
Old September 26th 05, 08:47 PM
Andrew Gideon
You've never seen me operate an allen wrench.
- Andrew
Old September 26th 05, 08:50 PM
Peter R.
Will pulling the unit from the power supply cause it to revert back to its
factory-set defaults?
When my unit was pulled and repaired by Garmin (which reverted all settings
back to their defaults), the avionics shop had to recalibrate my GNS480
with the HSI.
Peter
Old September 26th 05, 09:40 PM
Rob
Side question: How does one intentionally reset a garmin 430 to
factory defaults? There must be some "three-fingered-salute" or key
combination at power-on that does this but I can't find it in the
manual. I just got mine a few months ago. When I first got it, it was
in "East is up" mode. Not North. Not track. I figured that one out.
Also, when I go to the "nearest airports" page, it's always empty. Not
a major inconvenience yet, but I'd like the information to be there
should I really need it someday. The nearest NDBs, VOR's, FSS, Center,
etc. lists are all populated, but nearest airport is empty. I'm
thinking somewhere in the setup is a radius setting for nearest
airports that's set way too small, but I'd like to just reset my 430
and start from scratch. Anyone know how?
-R
Old September 26th 05, 09:51 PM
Yankee Whiskey
look
No.
Old September 26th 05, 10:10 PM
Frank Stutzman
manual.
AFAIK, its not in the user manual. It may be in the installation manual.
Hold the 'clear' button down while powering on the unit. You may have to
keep holding the 'clear' button down until it finishes its self test, but
I don't remember exactly.
If you hold the 'enter' button down while powering it on, you to the
hardware set-up page that allows you to do all sorts of things that Garmin
and your avionics shop would prefer you didn't. I'm thinking you may be
able to get the s/n of the unit though here as well, but I havn't had a
chance to check it myself.
This is probably not a time for fat-fingering the wrong button.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
p3/95 [email protected] Military Aviation 1 September 27th 04 12:27 AM
B29 tail serial number Tarakan WW2 Joanne Smedley Military Aviation 6 August 13th 03 02:11 PM
