Glass big learning curve?
Old September 26th 05, 07:45 PM
Michael
"You can't fly this plane
partial panel, so just couple up the autopilot to the GPS and have it
fly the approach" - which is, no ****, what glass-panel Cirrus pilots
are told.
In that case it's no wonder the insurance rates are so high.
In one sense, no. I don't believe there is a single accident
attributed to lack of partial panel proficiency in a Cirrus, with the
possible exception of the guy who launched into 800 ft ceilings on the
first flight after major panel work and wound up pulling the chute.
The airplane is quite reliable. People are not crashing because they
are depending on systems that fail.
But in another sense you are right. People are crasing because their
skill level is not up to the airplane, and this basic problem is not
being addressed. Limited panel flying has intrinsic value over and
above coping with the particular failure being simulated - it forces
the pilot to become sharper, to get more out of the instruments, and to
become smoother. It improves all aspects of his flying.
As long as all the automation works, the Skyhawk IFR pilot can be a
Cirrus IFR pilot with his existing skill set
This is no different than telling a VFR pilot to set the auto pilot
and let it fly if he/she runs into bad weather, or poor visibility.
Let's say it's a difference in degree only, and not in kind. On my
first flight in the glass panel Cirrus I asked the owner why there was
no CDI other than in the PFD. He didn't see my point. I explained
that if the PFD went out, the only approach we could shoot would be a
GPS or GPS overlay (using the Garmin display) since there were 2
GNS-430's but no external CDI for either. I felt this was acceptable
(what are the odds of PFD failure in conditions where GPS approach
conditions are not in range?) but suboptimal. He then explained that
the factory recommends not shooting a manual approach with a failed PFD
at all - just couple up the autopilot and let it do the job. This
despite the fact that altimeter, ASI, compass, and AI are all
available.
But at least part of the problem must be laid squarely at the feet of
the people doing the teaching and testing. This pilot took his IFR
checkride in his Cirrus, and the DE insisted he do a manual LOC
approach with the PFD off. Of course the GPS is NOT as accurate as a
LOC close in, but the DE didn't want to hear it. Thus I am reluctant
to blame the peope who are not being properly trained - what chance do
they have if even the DE's have no clue?
You have not created a better pilot, you have given him/her a crutch
to make up for lack of skill which is a very poor teaching method and
dangerous practice.
Like I said,
Personally, I think that's a ****-poor way to do things.
The real hazard, though, is not that the system that the pilot is
depending on will fail. These are fairly new airplanes, and those
systems are reliable. They're not failing a lot. The real problem is
that the system only does what it's built to do. Training makes a
pilot better overall. Substitute systems for training, and you better
hope you have systems to do EVERYTHING the pilot does, because without
the training, you will have an inferior pilot.
Michael
Old September 26th 05, 09:40 PM
SR20GOER
"Michael" wrote in message
Michael
I have kept out of this debate but the above raises a significant
opportunity.
I don't know what exists yet in the US, but in Oz there is some classroom
training associated with flying the Cirrus however I am unaware of any
"glass cockpit" course per se.
Our regulator has kept the syllabus to the days of rag and string and pommie
motors, with a lot of emphasis on technical matters of no real use.
What is needed is a part of the syllabus / course / book on the management
and use of the glass cockpit, based around the current Avidyne/Garmin gear.
It's the way of the future and training should respond accordingly to assist
pilots to make the transition. Particularly us "matures" as the next
generation will be flying these cockpits as the norm.
Brian
Old September 27th 05, 02:13 AM
cjcampbell
Thomas Borchert wrote:
Robert,
So, I'm wondering if all this talk about a long transition
time is mostly for the generation that didn't grow up with computers.
After reading the articles and spending 30 minutes flying the Entegra
system on a clear VFR day, I tend to agree with your view.
I tend to agree. Guys who are used to computers seem to pick it up
pretty fast. The user interface on these new systems is more intuitive
and people are less afraid of doing something wrong. It is the guys who
insist on trying to memorize every key and menu setting before they
will touch the thing that run into trouble.
Old September 29th 05, 06:57 PM
Robert M. Gary
Guys who are used to computers seem to pick it up pretty fast.
I'm a computer guy but I got lost on the Garmin 430 a couple times when
I first flew behind one (at the time it was just a stupid box to me, I
really didn't need to turn it on). When in map mode if you turn the
little knob and the big knob a couple times you can quickly get lost.
The GX GPS has a "map" button to get you back to the map when you get
lost, the 430 could really use a "main menu" type button to get you
unstuck. I've power cycled them before.
-Robert
Old September 30th 05, 02:47 AM
cjcampbell
Yes, it certainly could use a button like that. I like the 430, but I
think the buttons are too small and the menus are a mess. Simple things
like switching radios or navaids can be a real problem if you are not
familiar with it.
The nearest competitor, the KLN 89B, shares many of the same problems.
Both units also need a dedicated missed approach button, IMHO.
Old September 30th 05, 04:47 AM
Roger
On 29 Sep 2005 10:57:55 -0700, "Robert M. Gary"
1. Learn how to turn on.
2. Learn hot to get to, or back to the default menu.
#2 may be more important than #1.
If the default menu doesn't contain the basic flight instruments,
boycott the manufacturer.
www.rogerhalstead.com
-Robert
Cambridge 302 learning curve cont. Tuno Soaring 4 July 5th 04 10:10 AM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
learning curve in fs 2002.. David Ciemny Simulators 5 December 30th 03 12:18 AM
18m polar curve Alan Irving Soaring 1 December 15th 03 11:45 PM
Lesson in Glass JimC Owning 3 August 6th 03 01:09 AM
