I've been looking to buy a turbo lance and I've demo'd two of them so far.
One I flew was rock solid, but the second one the engine would not hold a solid MP. It would flucuate +/- an inch or so especially on take off. We even got the overboost light just off the end of the runway. After seeing that, I am pretty concerned about the turbo system on the lance. has anyone else seen this problem? Was it just that plane or more of a turbo problem that I would have with any lance? |
Did it fluctuate or just rise an inch or two and then stay? The wastegate
is manual so it isn't moving unless you are moving the throttle. You should be adding throttle until you get about 2-3"MP below where you want to be for takeoff. As the exhaust path heats up and the "bootstrapping" subsides the MP will stabilize Mike MU-2 "John Doe" wrote in message news:IG2_e.27708$8q.271@lakeread01... I've been looking to buy a turbo lance and I've demo'd two of them so far. One I flew was rock solid, but the second one the engine would not hold a solid MP. It would flucuate +/- an inch or so especially on take off. We even got the overboost light just off the end of the runway. After seeing that, I am pretty concerned about the turbo system on the lance. has anyone else seen this problem? Was it just that plane or more of a turbo problem that I would have with any lance? |
![]() "Mike Rapoport" wrote in message . net... Did it fluctuate or just rise an inch or two and then stay? The wastegate is manual so it isn't moving unless you are moving the throttle. You should be adding throttle until you get about 2-3"MP below where you want to be for takeoff. As the exhaust path heats up and the "bootstrapping" subsides the MP will stabilize Good question, Its been a month since I've flown that one. I'll have to go back and fly it again. I'll let you know. Thanks. |
Like anything else, you will get used to this if you buy the airplane.
Mike MU-2 "John Doe" wrote in message news:YJj_e.27941$8q.5517@lakeread01... "Mike Rapoport" wrote in message . net... Did it fluctuate or just rise an inch or two and then stay? The wastegate is manual so it isn't moving unless you are moving the throttle. You should be adding throttle until you get about 2-3"MP below where you want to be for takeoff. As the exhaust path heats up and the "bootstrapping" subsides the MP will stabilize Good question, Its been a month since I've flown that one. I'll have to go back and fly it again. I'll let you know. Thanks. |
Turbo Lance empty weight | John Doe | Owning | 3 | September 1st 05 04:56 PM |
Turbo Lance II opinions | John Doe | Owning | 25 | August 30th 05 02:14 PM |
Why turbo normalizer? | Robert M. Gary | Piloting | 61 | May 20th 05 04:33 PM |
FS: Duo Discus Turbo - Texas, USA | Mark Zivley | Soaring | 2 | May 4th 05 11:34 PM |
Piper Lance | Renee Purner | Owning | 22 | November 4th 03 07:47 PM |
