It actually happened today!! Vacuum failure in IMC.
Old October 8th 05, 04:57 AM
Newps
If you're already talking to ATC just tell the controllr what the
problem is, no need to change the transponder. Doesn't matter what
airspace you are in.
skym wrote:
It is my understanding that 7700 is what we are supposed to dial into
the xpdr when we declare an emergency. I was in controlled airspace.
Does that make a difference?
Old October 8th 05, 11:41 PM
skym
Thanks to both. Didn't know that. Hope I don't ever need it again!!
Old October 9th 05, 12:05 AM
skym
I don't remember if the a/p was on but I think it was. I know that may
seem weird, but the whole thing was so unexpected (naturally), that I
just focused on acting and my memory is . If it was on, the a/p would
have been on nav mode rather than hdg mode since I had been given a
clearance to a VOR, "then as filed", so I would have dialed in the VOR
freq and set the a/p to it.
Eventually, after getting some no-gyro vectors using the t/c and timed
turns on the compass, and alt instructions, I set up the GPS to CLT and
set the a/p to it. At that point I began to breathe easier.
Old October 10th 05, 02:12 AM
You did nothing wrong by squawking 7700. Better to error on the
conservative side, and that is what you did.
Also, the 7700 squawk really wakes up the system to work in your behalf.
Old October 10th 05, 09:04 AM
David Cartwright
"skym" wrote in message
Yes - it lights you up distinctly (a different colour, I believe) on the
radar screen. So although the controller would see you no matter what code
you were transmitting, if you switch to an emergency code (7700, 7600, 7500,
etc) the equipment makes you more prominent and so lightens his workload a
little.
D.
Old October 10th 05, 02:52 PM
Newps
little.
That's funny. Completely wrong, but funny.
  #28
Old October 10th 05, 04:57 PM
Barry
As for flying the GPS rather than the ILS into CLT, I've been so
indoctrinated into flying headings rather than "chasing the needle" on
an ILS that I had to rule that out.
I agree with flying a GPS approach instead of an ILS when partial panel - it's
much easier to fly because the needle doesn't get more and more sensitive as
you continue. Another factor to consider is that with only the magnetic
compass it's easier to hold an east or west heading than north or south. So,
for example, at CAE, I'd ask for the GPS 11 or 29 instead of 5 or 23.
Barry
  #30
Old October 10th 05, 09:54 PM
Matt Whiting
I'd fly an ILS over a GPS any day if I was PP. I WOULD use the GPS to
give me a better indication of the heading as opposed to the compass,
but why give up the lower minimums and greater accuracy offered by an
ILS, especially when the chips are already down a little.
Matt
My first in-flight mechanical failure Peter R. Piloting 52 October 5th 04 09:05 PM
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
