Carb heat = no rpm drop
Old October 8th 05, 05:21 PM
figurado figurado is offline
Junior Member
First recorded activity by AviationBanter: Sep 2005
Default Carb heat = no rpm drop
I just bought a 1973 Cessna 172. During runup at 1700 rpm there seems to be no noticeable drop in rpm when carb heat is applied. We inspected the operation of the cable, and flapper and inspected the box and everything looked fine. We inspected the ducting for blockage and found nothing. What might explain this? Thanks in advance for your help.
Old October 8th 05, 11:14 PM
Roy Smith
help.
Is it possible the tach is sticking? Does a strobe on the prop confirm no
RPM change?
Old October 8th 05, 11:57 PM
RST Engineering
Had the same problem with the 182. Sent the muffler down for overhaul and
more important, sent the shroud down for overhaul.
25 RPM drop before; 200 RPM drop thereafter. $500 fix.
"figurado" wrote in message
help.
figurado
Old October 9th 05, 12:43 AM
A '73 172 has a little open-ended box on the right front exhaust
stack. Carb heat air is drawn from this thing. If you are running the
engine with the cowl off, there's so much blast from the prop that the
carb won't get any heated air, and there'll be no RPM drop.
Dan
Old October 9th 05, 03:11 AM
B. Jensen
I suspect your heat muff / shroud is leaking air...especially if it is a
closed system.
BJ
help.
Old October 9th 05, 07:53 PM
Junior Member
Thanks much for the responses.
I don't think the tach is sticking but it will be checked in a week when it goes in to my local mechanic to deal with a few squawks.
I'm hoping the exhaust and shroud don't need an overhaul but I'll check that also.
The testing was with the cowl on.
One thought is that the full rich position of carb is not rich enough. Any thoughts?
Old October 9th 05, 11:43 PM
A. Smith
that also.
Any thoughts?
figurado
One way to check the idle mixture is to set the RPM at 1,000 when full rich.
Slowly pull the mixture knob out while watching the tach. You should see a
25-50 RPM increase just before the engine dies. If you do not see the RPM
rise then you may be to lean and it should be checked. If there are any
doubts about the heater shroud and exhaust system in general get it checked
too, with winter coming on you will be using it.
Allen
Old October 10th 05, 10:54 PM
Helen Woods
Give the good folks at the Cessna Pilot's association a call. Bet
they'll have an answer. They are good group to join too. There are a
ton of knowledgable people on their web forum.
http://www.cessna.org/
Helen
Lycoming Carb Heat Mitty Instrument Flight Rules 19 September 21st 05 06:43 PM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
alternate carb heat Ray Toews Home Built 16 October 29th 04 12:41 PM
