Steve Foley wrote:
With the information given, and the information requested, I feel my response was appropriate. No, an appropriate response would have been "I need more information in order to comment", or "engine life is highly variable and there is no way to tell if your engine will run 1 more hour or 1,000 more hours." Your comment was almost certainly wrong, but may have been right in a very small percentage of cases. No statement was made regarding compression, making metal, or oil consumption, how the engine was treated (taken care of or abused). The OP said the compression was good. There was no comment about metal, oil consumption, or maintenance though. By "Run Out", I mean that the engine will not serve the owner for many years to come. We knew what you meant, and we know that you don't know what you are talking about. Matt |
Sorry Mike, I was obviously wrong. Go ahead and buy this plane. TBO means
nothing. "Michael Horowitz" wrote in message ... I have a lead on a Tcraft with an A-65 engine that has exceeded recommended TBO. It is my understanding the compression is still good. How should I approach this engine ( i.e. just assume everything over 1800 hours was a freebee and there is no guarantee it's not about to poop out)? - Mike |
![]() I have a lead on a Tcraft with an A-65 engine that has exceeded recommended TBO. It is my understanding the compression is still good. How should I approach this engine ( i.e. just assume everything over 1800 hours was a freebee and there is no guarantee it's not about to poop out)? - Mike A friend of mine at our local AP (3S8) has an Apache (twin O-320's). After 3500 hours on the engines he decided they needed an overhaul (only because he wants to give instruction in it). So the actual number of hours on the engine means little. What really matters is how it was taken care of / flown... |
I'm not sure what you base your assumption that it will NEED
replacement/rebuilding shortly. My old Chief had 2400 hours on its C-85. Compressions were well into the upper 70s. I have a friend who flew Citabrias to 10000 hours between overhauls. The key to that long of a life was useage. They used them for power line patrol and flew 10-12 hours daily. He believed the key to longevity was usage. Sitting unused it what kills these engines...TBO is RECOMMENDED, unless it is used in commercial operations, where it's required. Scott Steve Foley wrote: Yup. It's run out, and will need replacement/rebuilding shortly. Like you said, anything else is gravy. Don't you have a T-Craft engine? "Michael Horowitz" wrote in message ... I have a lead on a Tcraft with an A-65 engine that has exceeded recommended TBO. It is my understanding the compression is still good. How should I approach this engine ( i.e. just assume everything over 1800 hours was a freebee and there is no guarantee it's not about to poop out)? - Mike |
The question to which I replied was "How should I approach this engine?"
The question was not "How long will this engine last?". The question was not "How can I tell how long this engine will last?" I believe that when purchasing a plane with an engine beyond TBO , expect the worst. Expect to will need replacement shortly. I never said it WOULD need replacement. I said to treat it as if it would need replacement, and pay accordingly. It appears everyone else thinks you should closely examine the logs to see if it has been well cared for, and offer more for the plane as a result. I disagree. "Scott" wrote in message ... I'm not sure what you base your assumption that it will NEED replacement/rebuilding shortly. My old Chief had 2400 hours on its C-85. Compressions were well into the upper 70s. I have a friend who flew Citabrias to 10000 hours between overhauls. The key to that long of a life was useage. They used them for power line patrol and flew 10-12 hours daily. He believed the key to longevity was usage. Sitting unused it what kills these engines...TBO is RECOMMENDED, unless it is used in commercial operations, where it's required. Scott Steve Foley wrote: Yup. It's run out, and will need replacement/rebuilding shortly. Like you said, anything else is gravy. Don't you have a T-Craft engine? "Michael Horowitz" wrote in message ... I have a lead on a Tcraft with an A-65 engine that has exceeded recommended TBO. It is my understanding the compression is still good. How should I approach this engine ( i.e. just assume everything over 1800 hours was a freebee and there is no guarantee it's not about to poop out)? - Mike |
![]() "RST Engineering" wrote in message ... "Jonathan Lowe" wrote in message ... Making Metal, means that particles of the metal lineing on the main bearing shells Or the rod bearing inserts. We may complain when an A&P grounds an aircraft An A&P cannot ground an aircraft. An IA cannot ground an aircraft. There is argument on both sides that an FAA inspector cannot ground an aircraft. This is an unfortunate phrase left over from the military, where a mechanic CAN ground an aircraft. Civilian life is a bit different. He may not be able to "ground" an aircraft, but if an A&P decides that the engine needs maint carried out, he, or she, aint gonna put it back together and sign it off so it can be flown anywhere else for a second opinion. So although technically speaking he can't ground an aircraft, in reality he can. Ric Jim |
TBO is a rather cupreous number. If you were in part 135 you can petition
the FAA for a 10% (IB) extension in the TBO hours if all the parameters are good. That is how the manufacturers get longer recommended TBOs. "Scott" wrote in message ... I'm not sure what you base your assumption that it will NEED replacement/rebuilding shortly. My old Chief had 2400 hours on its C-85. Compressions were well into the upper 70s. I have a friend who flew Citabrias to 10000 hours between overhauls. The key to that long of a life was useage. They used them for power line patrol and flew 10-12 hours daily. He believed the key to longevity was usage. Sitting unused it what kills these engines...TBO is RECOMMENDED, unless it is used in commercial operations, where it's required. Scott Steve Foley wrote: Yup. It's run out, and will need replacement/rebuilding shortly. Like you said, anything else is gravy. Don't you have a T-Craft engine? "Michael Horowitz" wrote in message ... I have a lead on a Tcraft with an A-65 engine that has exceeded recommended TBO. It is my understanding the compression is still good. How should I approach this engine ( i.e. just assume everything over 1800 hours was a freebee and there is no guarantee it's not about to poop out)? - Mike |
![]() He may not be able to "ground" an aircraft, but if an A&P decides that the engine needs maint carried out, he, or she, aint gonna put it back together and sign it off so it can be flown anywhere else for a second opinion. So although technically speaking he can't ground an aircraft, in reality he can. Bull****, and I'm not going to argue this point still a THIRD time in two months with somebody that doesn't have a clue. Jim A&P, IA |
RST Engineering wrote:
"Jonathan Lowe" wrote in message ... Making Metal, means that particles of the metal lineing on the main bearing shells Or the rod bearing inserts. Another thing to consider since it is a Continental after all ;-), is just how much oil it is drooling all over itself out of every seam, gasket and seal, to help determine whether or not it's time to tear it down for the inevitable rebuild. (Not that I'm insinuating old Continentals are profuse oil leakers -- no nothing like that!) |
![]() "RST Engineering" wrote in message ... He may not be able to "ground" an aircraft, but if an A&P decides that the engine needs maint carried out, he, or she, aint gonna put it back together and sign it off so it can be flown anywhere else for a second opinion. So although technically speaking he can't ground an aircraft, in reality he can. Bull****, and I'm not going to argue this point still a THIRD time in two months with somebody that doesn't have a clue. Why does it have to be an argument, a disscusion would suffice and isnt that what newsgroups are all about? As for stating I don't have a clue.......well that shows more about you than me :0) My point stands, the fact you don't wish to "argue" the point, I think, means you agree but don't wish to lose face. Don't sweat it mate. Ric LAME (A&P, IA) Jim A&P, IA |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
