Engine exceeds TBO
Old October 11th 05, 01:11 AM
Michael Horowitz
Default Engine exceeds TBO
I have a lead on a Tcraft with an A-65 engine that has exceeded
recommended TBO. It is my understanding the compression is still good.
How should I approach this engine ( i.e. just assume everything over
1800 hours was a freebee and there is no guarantee it's not about to
poop out)? - Mike
Old October 11th 05, 01:56 AM
Steve Foley
Yup. It's run out, and will need replacement/rebuilding shortly. Like you
said, anything else is gravy.
Don't you have a T-Craft engine?
"Michael Horowitz" wrote in message
poop out)? - Mike
Old October 11th 05, 08:05 AM
RST Engineering
"Steve Foley" wrote in message
Yup. It's run out,
No, it is not "run out" whatever you mean by that statement. It is still
holding compression, not making metal, and does not have excessive oil
consumption.
Really? And what diameter was the crystal ball that you used to make this
determination? I've seen engines that have been taken care of go DOUBLE
TBO. I've seen abused engines go HALF TBO. It is strictly a function of
the care and feeding of the engine.
poop out
Engines don't "poop out". Engines have a slow, steady slide into required
serious maintenance. Every now and again, one will have an unforeseen
catastrophic failure, but those are few and far between.
The other side of that coin is that bearing/crankshaft wear tends to become
exponential after a point in time when it departs from linear. That is, for
a long time (extrapolated by the manufacturer to be "TBO") the wear on the
bearings and the crank is linear. At some point when the bearings get to be
sloppy on the crank, the wear accelerates, and the faster it accelerates,
the faster it accelerates. If you want to play the crankshaft roulette
game, you extend TBO until the bearings start to make metal. Then you pull
the engine down, and if you are lucky, the bearings (the cheap part) took
the hit and left the crank journals intact. If you lose, you grind the
crank UNLESS somebody else played crankshaft roulette before you and the
crank had already been ground to minimums. Now you REALLY have a rough row
to hoe, in that you get to find a replacement crank ... which ain't cheap by
anybody's standards.
Old October 11th 05, 03:49 PM
Steve Foley
With the information given, and the information requested, I feel my
response was appropriate.
No statement was made regarding compression, making metal, or oil
consumption, how the engine was treated (taken care of or abused).
By "Run Out", I mean that the engine will not serve the owner for many years
to come.
While we are nit-picking, What do you mean by "Making Metal"? I always
thought matter could not be created or destroyed.
(This is a rhetorical question. I know what you mean by making metal, just
as I'm pretty sure you knew what I meant by run out)
"RST Engineering" wrote in message
Yup. It's run out,
consumption.
poop out
become
for
be
pull
row
by
Old October 11th 05, 03:50 PM
Jean-Paul Roy
Thanks Jim for making it so clear and understandable.
Jean-Paul
Quebec, Canada
Yup. It's run out,
consumption.
poop out
become
for
be
pull
row
by
Old October 11th 05, 05:41 PM
Jonathan Lowe
years
to come.
Making Metal, means that particles of the metal lineing on the main bearing
shells is peeling off and showing up in the oil filter and in the oil when
you drain the sump / oil tank. That's a sure indication that the engine
should not be run a minute longer as failure is very near and unpredictible.
We may complain when an A&P grounds an aircraft with metal in the oil
strainer but should be mighty glad when we consider that he's just saved a
falure in the air.
Cheers,
Jonathan Lowe,
Rallye 100
EI-BFR
Yup. It's run out,
still
consumption.
this
of
poop out
required
become
for
to
be
accelerates,
pull
took
row
cheap
by
Old October 11th 05, 06:09 PM
RST Engineering
"Jonathan Lowe" wrote in message
bearing
shells
Or the rod bearing inserts.
An A&P cannot ground an aircraft. An IA cannot ground an aircraft. There
is argument on both sides that an FAA inspector cannot ground an aircraft.
This is an unfortunate phrase left over from the military, where a mechanic
CAN ground an aircraft. Civilian life is a bit different.
Old October 11th 05, 06:10 PM
RST Engineering
Then you and Einstein disagree. I know who I believe ...
news:hiQ2f.9552$tU1.1516@trndny07...
Old October 11th 05, 06:25 PM
Steve Foley
Touché!
- Steve
Old October 12th 05, 12:15 AM
Matt Whiting
poop out)? - Mike
Baloney. Engine life is highly variable depending on usage, care in
maintenance, etc. An engine run infrequently and not maintained well
might not make it to 500 hours. An engine run every day and maintained
well might run to 3,000 hours.
Matt
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
