Engine exceeds TBO
Old October 13th 05, 04:35 AM
W P Dixon
Well dang Jim!
There would only be two or three folks on here that can win!!!!
Patrick
student SP
aircraft structural mech
By the way, condescending loses every time.
Jim in NC
Old October 13th 05, 05:30 AM
Morgans
"Ric" wrote
My point stands, the fact you don't wish to "argue" the point, I think,
means you agree but don't wish to lose face. Don't sweat it mate.
Hmm, ric spouts off, new on the scene. Jim spouts off, been around since
dirt was invented (sorry, Jim) and now I have to make a choice.
Not a hard decision, mate.
Jim in NC
Old October 13th 05, 07:57 AM
Bret Ludwig
An aside, most of these airplanes that had 65 horse Continentals
originally were upgraded to 75, 85 or bigger engines with starter and
generator pads and electrics. It added a little weight but power went
up and the airplane flew better. Then they ripped the electrics out and
went back to the 65s for authenticity, I guess.
If you want to fly NORDO, buy an ultralight, is my philosophy. I want
lights and radios.
  #24
Old October 13th 05, 08:02 AM
Bret Ludwig
RST Engineering wrote:
snip
The other side of that coin is that bearing/crankshaft wear tends to become
exponential after a point in time when it departs from linear. That is, for
a long time (extrapolated by the manufacturer to be "TBO") the wear on the
bearings and the crank is linear. At some point when the bearings get to be
sloppy on the crank, the wear accelerates, and the faster it accelerates,
the faster it accelerates. If you want to play the crankshaft roulette
game, you extend TBO until the bearings start to make metal. Then you pull
the engine down, and if you are lucky, the bearings (the cheap part) took
the hit and left the crank journals intact. If you lose, you grind the
crank UNLESS somebody else played crankshaft roulette before you and the
crank had already been ground to minimums. Now you REALLY have a rough row
to hoe, in that you get to find a replacement crank ... which ain't cheap by
anybody's standards.
As Smokey Yunick said, the more often you rebuild, the cheaper it is.
Going much beyond TBO on an aircraft engine-or beyond what the
consensus says is the usual life on other engines, be they car or
boat-is fool's coinage. Dismantle, clean, mike and magnaflux.
  #25
Old October 13th 05, 08:47 AM
Ric
"Morgans" wrote in message
Why do you feel you have to make a choice? How about you actually contribute
something to the discussion rather than just jumping wildly to someone's
defence purely on the grounds they have been posting here the longest? FWIW,
I have been posting, lurking since 1999. I just don't feel that every post
requires addressing, like some, and so I don't post often.
Lucky eh!
Loses what?? Are we in a competition of some sort?
Fairdinkum, I posted my view point, politely, and the only replies I
receive are hostile and don't address any of the topic. Good work guys.
Ric
Jim in NC
  #26
Old October 13th 05, 11:19 AM
Matt Whiting
snip
Smokey was talking car engines, more specifically race car engines. Do
you rebuild your car engine every 100,000 miles as preventive maintenance?
Matt
  #27
Old October 13th 05, 11:24 AM
Stealth Pilot
On Wed, 12 Oct 2005 12:27:11 -0700, "RST Engineering"
He may not be able to "ground" an aircraft, but if an A&P decides that the
engine needs maint carried out, he, or she, aint gonna put it back
together and sign it off so it can be flown anywhere else for a second
opinion. So although technically speaking he can't ground an aircraft, in
reality he can.
Bull****, and I'm not going to argue this point still a THIRD time in two
months with somebody that doesn't have a clue.
A&P, IA
trouble is jim you are both correct.
you write from the american perspective.
ric writes from an australian perspective.
the laws in each country are different.
Stealth Pilot
Australia
  #28
Old October 13th 05, 11:54 AM
Scott
Yes, you DID say it would NEED replacement/rebuilding.
Scott
Steve Foley wrote:
I never said it WOULD
need replacement. I said to treat it as if it would need replacement, and
pay accordingly.
The original message said:
Steve Foley wrote:
Yup. It's run out, and will need replacement/rebuilding shortly.
  #30
Old October 13th 05, 01:32 PM
On 13 Oct 2005 00:02:59 -0700, "Bret Ludwig"
Cheaper for whom? How is it cheaper to rebuild frequently than to run
an engine for it's normal life?
Was Smokey a pilot? Was this comment directed at aviation engines? Is
it relevant?
Corky Scott
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
