#21
Well dang Jim!
There would only be two or three folks on here that can win!!!! ![]() Patrick student SP aircraft structural mech By the way, condescending loses every time. -- Jim in NC |
![]() "Ric" wrote My point stands, the fact you don't wish to "argue" the point, I think, means you agree but don't wish to lose face. Don't sweat it mate. Hmm, ric spouts off, new on the scene. Jim spouts off, been around since dirt was invented (sorry, Jim) and now I have to make a choice. Not a hard decision, mate. By the way, condescending loses every time. -- Jim in NC |
An aside, most of these airplanes that had 65 horse Continentals
originally were upgraded to 75, 85 or bigger engines with starter and generator pads and electrics. It added a little weight but power went up and the airplane flew better. Then they ripped the electrics out and went back to the 65s for authenticity, I guess. If you want to fly NORDO, buy an ultralight, is my philosophy. I want lights and radios. |
#24
![]() RST Engineering wrote: snip The other side of that coin is that bearing/crankshaft wear tends to become exponential after a point in time when it departs from linear. That is, for a long time (extrapolated by the manufacturer to be "TBO") the wear on the bearings and the crank is linear. At some point when the bearings get to be sloppy on the crank, the wear accelerates, and the faster it accelerates, the faster it accelerates. If you want to play the crankshaft roulette game, you extend TBO until the bearings start to make metal. Then you pull the engine down, and if you are lucky, the bearings (the cheap part) took the hit and left the crank journals intact. If you lose, you grind the crank UNLESS somebody else played crankshaft roulette before you and the crank had already been ground to minimums. Now you REALLY have a rough row to hoe, in that you get to find a replacement crank ... which ain't cheap by anybody's standards. As Smokey Yunick said, the more often you rebuild, the cheaper it is. Going much beyond TBO on an aircraft engine-or beyond what the consensus says is the usual life on other engines, be they car or boat-is fool's coinage. Dismantle, clean, mike and magnaflux. |
#25
![]() "Morgans" wrote in message ... "Ric" wrote My point stands, the fact you don't wish to "argue" the point, I think, means you agree but don't wish to lose face. Don't sweat it mate. Hmm, ric spouts off, new on the scene. Jim spouts off, been around since dirt was invented (sorry, Jim) and now I have to make a choice. Why do you feel you have to make a choice? How about you actually contribute something to the discussion rather than just jumping wildly to someone's defence purely on the grounds they have been posting here the longest? FWIW, I have been posting, lurking since 1999. I just don't feel that every post requires addressing, like some, and so I don't post often. Not a hard decision, mate. Lucky eh! By the way, condescending loses every time. Loses what?? Are we in a competition of some sort? Fairdinkum, I posted my view point, politely, and the only replies I receive are hostile and don't address any of the topic. Good work guys. Ric -- Jim in NC |
#26
Bret Ludwig wrote:
RST Engineering wrote: snip The other side of that coin is that bearing/crankshaft wear tends to become exponential after a point in time when it departs from linear. That is, for a long time (extrapolated by the manufacturer to be "TBO") the wear on the bearings and the crank is linear. At some point when the bearings get to be sloppy on the crank, the wear accelerates, and the faster it accelerates, the faster it accelerates. If you want to play the crankshaft roulette game, you extend TBO until the bearings start to make metal. Then you pull the engine down, and if you are lucky, the bearings (the cheap part) took the hit and left the crank journals intact. If you lose, you grind the crank UNLESS somebody else played crankshaft roulette before you and the crank had already been ground to minimums. Now you REALLY have a rough row to hoe, in that you get to find a replacement crank ... which ain't cheap by anybody's standards. As Smokey Yunick said, the more often you rebuild, the cheaper it is. Going much beyond TBO on an aircraft engine-or beyond what the consensus says is the usual life on other engines, be they car or boat-is fool's coinage. Dismantle, clean, mike and magnaflux. Smokey was talking car engines, more specifically race car engines. Do you rebuild your car engine every 100,000 miles as preventive maintenance? Matt |
#27
On Wed, 12 Oct 2005 12:27:11 -0700, "RST Engineering"
wrote: He may not be able to "ground" an aircraft, but if an A&P decides that the engine needs maint carried out, he, or she, aint gonna put it back together and sign it off so it can be flown anywhere else for a second opinion. So although technically speaking he can't ground an aircraft, in reality he can. Bull****, and I'm not going to argue this point still a THIRD time in two months with somebody that doesn't have a clue. Jim A&P, IA trouble is jim you are both correct. you write from the american perspective. ric writes from an australian perspective. the laws in each country are different. Stealth Pilot Australia |
#28
Yes, you DID say it would NEED replacement/rebuilding.
Scott Steve Foley wrote: I never said it WOULD need replacement. I said to treat it as if it would need replacement, and pay accordingly. The original message said: Steve Foley wrote: Yup. It's run out, and will need replacement/rebuilding shortly. |
#29
My Continentals have never had a leakage issue...even my old C-85 that
had 2400 hours on it and had never been majored ![]() however, and needed to be replaced/overhauled ![]() Scott wrote: RST Engineering wrote: "Jonathan Lowe" wrote in message ... Making Metal, means that particles of the metal lineing on the main bearing shells Or the rod bearing inserts. Another thing to consider since it is a Continental after all ;-), is just how much oil it is drooling all over itself out of every seam, gasket and seal, to help determine whether or not it's time to tear it down for the inevitable rebuild. (Not that I'm insinuating old Continentals are profuse oil leakers -- no nothing like that!) |
#30
On 13 Oct 2005 00:02:59 -0700, "Bret Ludwig"
wrote: As Smokey Yunick said, the more often you rebuild, the cheaper it is. Going much beyond TBO on an aircraft engine-or beyond what the consensus says is the usual life on other engines, be they car or boat-is fool's coinage. Dismantle, clean, mike and magnaflux. Cheaper for whom? How is it cheaper to rebuild frequently than to run an engine for it's normal life? Was Smokey a pilot? Was this comment directed at aviation engines? Is it relevant? Corky Scott |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
