#41
I cannot do 50 words, but how about this? - 750 words.
Rory Why does a heavier glider have better performance? Gliders fly through air and in the process create drag. Drag results in a loss of energy. Due to the conservation of energy, if no energy is being supplied from another source such as an engine or thermals, then either the glider has to slow down and lose kinetic energy or the glider has to sink and lose potential energy. In a steady glide, the glider maintains its speed but loses some height and potential energy as a result of the drag. The amount of drag created by a glider at a particular speed is not fixed. A Cessna with a glide angle of 1:10 has a worse performance than a Nimbus with a glide angle of 1:60. Not all 18m gliders weighing exactly 450kg and flying at exactly 60 knots, will have the same performance. The amount of drag is not predetermined. There are two main types of drag: Induced drag and Parasitic Drag. Induced drag is a by-product of creating lift. As the wings fly through the air, they impart a slight downwash to the mass of air, which results in an upforce on the wings. This lift is equal to the weight of the glider. It varies with the angle of attack and the speed that the glider flies. In essence, the same amount of lift can be created by either flying slowly at large angles of attack or by flying fast at small angles of attack. A ballasted glider is heavier, and will need more lift than the empty glider, so it flies slightly faster at any given angle of attack to generate the appropriate amount of lift. The relationships are not linear. As the wings generate lift, they also generate induced drag in the form of vortices in the air that the glider passes through. This drag results in the glider losing some potential energy and sinking. The amount of induced drag varies. It can be minimised by using longer wing spans, wing tips, shaped wings and appropriate wing profiles, but it cannot be entirely eliminated. The induced drag and vortices are particularly sensitive to the angle of attack. At large angles of attack, the vortices are much stronger and the induced drag much greater. So if you fly very slowly, the glider sinks rapidly in a mushing stall, due to the induced drag. When flying fast, the angle of attack is only a few degrees and the induced drag is less and has a minimal effect on overall performance. Because induced drag is a by-product of the generation of lift, a heavier glider has more induced drag because it requires more lift. So at slow speeds where induced drag predominates, the heavy glider has lower performance, as shown by its greater minimum sink rate. The second type of drag is Parasitic Drag. This is caused by air resistance due to the shape of the glider as it flies through the air, and friction as air molecules slide over the surfaces of the plane. This type of drag becomes increasingly important, the faster the plane flies. In fact, the parasitic drag increases in relation to the cube of the airspeed. A glider whether empty or filled full of water, is the same shape and creates the same amount of parasitic drag whatever its weight at the same speed. So there is the same amount of energy to account for. However, the heavier glider with more mass, has more potential energy and has to sink a smaller distance to release the necessary energy. There is a point, which happens to be the best glide angle when the performance of the empty and fully ballasted gliders are the same. At this point, 3/4 of the drag is due to induced drag and 1/4 due to parasitic drag. The heavier glider will be flying faster. At speeds faster that this, the performance of the heavier glider will be better than the light glider as the parasitic drag predominates. There is also a speed, which is faster than the best glide speed for the unballasted glider, but slower than the best glide speed for the ballasted glider, where both gliders will have the same sink rate at the same speed. Thus the heavier glider may have better performance than the lighter glider when gliding fast. How the overall cross-country performance of the unballasted and ballasted gliders plays out, depends on other factors as well, such as thermal strengths. Rory 750 words. |
#42
On Tue, 11 Oct 2005 16:38:36 UTC, Pat Russell
wrote: "A glider is a gravity-powered machine. The heavier it is, the more power it has." So why don't two Grunau Babies side by side (you can join them with a length of balsa if you want to) have better performance than one Gruanau baby? Ian |
#43
On Tue, 11 Oct 2005 18:31:13 UTC, Derrick Steed
wrote: but loses all the effects due to Reynolds number which is an aerodynamic phenomena Reynolds number is not an aerodynamic phenomenon. It's a dimensionless quantity which is useful in characterising certain aerodynamic phenomena, principally those which involve a laminar - turbulent transition. Ian -- |
#44
On Tue, 11 Oct 2005 22:51:26 UTC, "Jim Kelly"
wrote: Thermalling stores energy in the glider, but thermals stop at cloud base. Water carried needs to be lifted too, thus more energy can be harnessed. Doesn't cover the aerodynamics. The fact that you have to fly faster to get the benefit is important. Ian |
#45
power it has." So why don't two Grunau Babies side by side (you can join them with a=20 length of balsa if you want to) have better performance than one=20 Gruanau baby? Ian ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~ Now that _is_ a dumb question The argument works for two aircraft which are identical in every respect apart from their mass - two grunau baby's may be twice the mass of one, but they also have twice the wing area, twice everything in fact (except, possibly, the pilot) and so the argument doesn't work for that situation. Rgds, Derrick Steed |
#46
aerodynamic phenomena Reynolds number is not an aerodynamic phenomenon. It's a dimensionless quantity which is useful in characterising certain aerodynamic=20 phenomena, principally those which involve a laminar - turbulent=20 transition. Ian ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~ Perhaps I should have said "Reynolds number which characterises certain aerodynamic phenomena" and it is a fact that the slope of the lift coefficient increases with increasing Reynolds number. Rgds, Derrick Steed |
#47
Since in theory the point of carrying ballast is to
improve overall speed....I am curious as to the actual performance improvement. The shift of the polar with added ballast is rather straightforward, but not the reduction in climb rate. Assuming something like a 25% time of flight in climbing mode, my back of the envelope calculations for a fully loaded modern ship in strong condtions would gain somewhere around 7-8% overall task speed improvement? Anyone smarter then I care to refine this number? |
#48
It isn`t. It`s more complicated because interthermal speeds doesn`t
vary with the square root of % extra weight. In condor is a nice tool which shows this very clearly. Reality shows that filling a glider meens flying "a bit" slower than sqrt(% extra weight), increasing range and the change for a real good thermal. The extra gain depend almost fully on the diameter of the thermal, with 1 m/s and huge thermals you can fly a racing glider almost full. And what about the gain running cloud streets? Also not linear. For huge thermals and weak cloudstreets of 1 m/s actual gain for an Diana would be (theoretically) 40%. Assuming 3 m/s in typical European (small) thermals shows a gain of only 8%. Life`s complicated ;-) l/d max occurs when induced and pressure drag are the same, not at 75% induced. (interference drag is (per definition) negociated) When 75% of the drag is induced you`r flying at Vy-min (min sink) One other point: the higher stall-speed is worth mentioning because of difficulties with landing, thermalling, manouvrebility etc. |
#49
#50
On Sun, 16 Oct 2005 16:27:16 UTC, Derrick Steed
wrote: Reynolds number is not an aerodynamic phenomenon. It's a dimensionless quantity which is useful in characterising certain aerodynamic=20 phenomena, principally those which involve a laminar - turbulent=20 transition. Perhaps I should have said "Reynolds number which characterises certain aerodynamic phenomena" and it is a fact that the slope of the lift coefficient increases with increasing Reynolds number. What do you mean by "slope of the lift coefficient"? With respect to what? Ian |
Airbus A380 water purification | john smith | Piloting | 1 | July 7th 05 02:50 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Water, water, everywhere, but none for thirsty wings.... | Chris OCallaghan | Soaring | 0 | November 21st 04 03:14 PM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
