How does a Maule tester work?
Old October 20th 05, 10:05 PM
Michael Horowitz
Default How does a Maule tester work?
I have heard folks talk about a Maule fabric tester, but I have never
seen one in action. Apparently it puts a set amount of pressure
against fabric and if the rod goes thru, then the fabric fails.
Can someone please describe the action - especially, how does the
device keep the fabric from being deflected away from the pressure? It
doesn't grip the fabric does it?
Second - anyone built a homemade tester? Is there such a thing as a
calibrated thumb? - Mike
Old October 20th 05, 11:44 PM
wmbjk
On Thu, 20 Oct 2005 17:05:19 -0400, Michael Horowitz
http://www.ultralightnews.com/aircra...ng/fabtest.htm
Ultralight fabric tester, modified from fan belt tension meter. 2/3 of
the way down the page.
Old October 21st 05, 12:41 AM
It's like a fish scale with a tit on the end. (push instead of pull)
The tit is about the size of a small pencil eraser.
It doesn't matter if material moves while pressure is added, it still
puts proper pressure sq/in.
Old October 21st 05, 03:20 AM
Carl Ellis
Mike -
The Maule tester is essentially a spring loaded rod in a tube. The rod has
a rounded end. The rod is placed against the fabric and pressure applied
to the tube which compresses a spring. There is a scale on the side of the
tube with graduations from 10 to 80 lbs in five lbs increments (if I
remember correctly). You might be able to find a picture in Aircraft
Spruce, Wicks, or other catalog.
New fabric will stretch with applied pressure all the way to 80 lbs. A
small dimple will be left in the fabric which will disappear completely
after an hour or so. Older fabric will probably experience cracking of the
dope (you can hear it) way before 80 lbs due to the plasticizer hardening.
On my previous Taylorcraft this happened at 65lbs (1977 covering). These
cracks will appear as ring worm and should be sanded down to silver and
repainted as light may degrade the fabric through the cracks.
If you are testing a prospective airplane the owner will probably be
annoyed if you use the tester and leave ring worm all over his baby.
Before selling my aircraft I had the test done. We did one or two areas to
determine where it cracked, then backed off 10 lbs for the next 30-40 test
locations. We indicated the lower number in the log book.
Hope this helps,
- Carl -
Old October 21st 05, 10:38 AM
Michael Horowitz
What pressure is a coated fabric subjected to to determine if it has
deteriorated? - Mike
Old October 21st 05, 10:43 AM
Michael Horowitz
Carl - is 80 psi the go/no-go point?
How do you work around the seller's understandably irritation at the
tester's hurting the surface? - Mike
Carl Ellis wrote:
Mike -
Hope this helps,
- Carl -
Old October 21st 05, 02:50 PM
Carl Ellis
Mike -
I believe that if the fabric tears at any pressure it's a no go. The Maule
tester is just one tool to use to determine fabric condition. As far as I
know the tester is not an FAA approved test but is rather a somewhat
subjective evaluation tool.
There is a whole thread on this on the Taylorcraft Forum.
I would ask the seller to have his mechanic do the test and be there while
he does it. Off the cuff I'd say walk away if the dope is cracking below
50 lbs but I'm sure that a more knowledeable person has a better feeling
for this.
- Carl -
Carl Ellis wrote:
Mike -
Hope this helps,
- Carl -
Old October 21st 05, 09:50 PM
Michael Horowitz
Carl - the reason I'm asking is that the covering and the engine are
the two biggies when looking to buy. We can get metrics on an engine,
and we know how to evaluate it, but it's not so clear cut with the
fabric.
The purpose of my pre-pre-purchase inspection is to weed out those
candidates I don't even want to get to the pre-inspection stage, so
I'm trying to be as independant of the A&P as I can.
OTOH, asking him to have _his_ A&P do the test certainly has merit.
- Mike
Carl Ellis wrote:
Mike -
for this.
- Carl -
Carl Ellis wrote:
Mike -
Hope this helps,
- Carl -
Old October 22nd 05, 12:25 AM
There are different minimum pressures for different MAX airspeeds of the
aircraft.
A Stearman will have a different requirement than a Cub.
i'll try to find that data and post it.
fabric.
- Mike
Carl Ellis wrote:
Mike -
for this.
- Carl -
Carl Ellis wrote:
Mike -
Hope this helps,
- Carl -
Old October 22nd 05, 03:18 AM
Cy Galley
Look in AC 43.13-1B for fabric testing parameters.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
aircraft.
fabric.
OTOH, asking him to have _his_ A&P do the test certainly has merit. -
Mike
Carl Ellis wrote:
Mike -
Maule
I
while
for this.
- Carl -
Carl Ellis wrote:
Mike -
has
applied
hardening.
These
areas to
test
Hope this helps,
- Carl -
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
Maule Turbine kevin Owning 16 August 4th 03 10:49 PM
