Maule Turbine
Old August 1st 03, 01:17 AM
kevin
Default Maule Turbine
Does anyone have any experience with the Maule with the Allison turbine
engine ? The Maule with the Lycombing IO-540 is $170.M , where the
MT7-420 is going for $470.M new. I would have to add about $75.M in
options for either bird. What do you think about the Allison turbine in
a Maule ?
Thanks
Old August 1st 03, 01:30 PM
Dennis O'Connor
You are joking, right?
Look, the Maule is a fine airplane and does it's thing well, which is short
field and grass operations... It is not a turbine bird, and installing one
is a waste of money... Unless you are going into the bush of africa or asia
where 100LL is not available, stick to the Lycoming...
Denny
"kevin" wrote in message
news:6kiWa.22942$cF.9271@rwcrnsc53...
a Maule ?
Thanks
Old August 1st 03, 09:45 PM
kevin
Denny
I was not talking about a conversion, you can buy a new Maule from the
factory with the Allison engine. I was looking at the difference of
cruise speed 164 with the Lycoming as opposed to 190 with the Allsion.
The 2800 fpm climb is also tempting.
a Maule ?
Thanks
Old August 1st 03, 10:24 PM
Newps
The slower Maule will go a lot further between fill ups.
Old August 2nd 03, 01:42 AM
kevin
This is true. 15gph as opposed to 25 for the turbine.
Old August 2nd 03, 03:18 PM
Kyler Laird
kevin writes:
15 vs. 25gph for different speeds, right? What are the fuel consumptions
for the same speed at cruise altitudes (10-20K)?
To be fair you should also add in the extra 5 gallons the turbine can
carry (in situations where you're at gross).
--kyler
Old August 2nd 03, 04:45 PM
Dennis O'Connor
You might want to have the factory take you for a ride to see what 190mph is
like inside of a fabric covered fuselage with angular otlines....
Denny
Old August 2nd 03, 06:43 PM
kevin
Denny
Yes , without a doubt i would want a demo ride. A cruise speed of 164 is
not bad for a
STOL bird, 190 is smoking.
Old August 3rd 03, 09:54 PM
Dennis O'Connor
I recently flew a local pilots, new 260 Maule... I didn't see anything
approaching 164...
Denny
news:MKSWa.49034$Ho3.7660@sccrnsc03...
190mph is
Denny
not bad for a
Old August 1st 03, 01:58 PM
G.R. Patterson III
a Maule ?
The turbine carries 35 pounds more and takes the same distance to clear a
50' obstacle. The major difference is the 2800 fpm climb rate versus the
1500 fpm for the piston engine. The turbine goes for $450,000. There are
several models of 235 hp planes, one of which costs $139,600.
So. That climb rate will set you back over $300,000 and burn twice as much
fuel. It wouldn't be worth it to me.
Check http://www.mauleairinc.com for figures.
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
turbine in microturbine generator for aircraft? Shin Gou Home Built 19 December 26th 04 02:19 PM
turbine propeller sebastian Home Built 19 March 21st 04 12:47 AM
earliest turbine powered helicopter? Charles Gray Military Aviation 7 January 2nd 04 11:35 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
WTB: Turbine ignition exciter unit, single plug Juan E Jimenez Aviation Marketplace 0 August 25th 03 12:48 AM
