How does a Maule tester work?
Old October 22nd 05, 01:21 PM
Stealth Pilot
Default How does a Maule tester work?
On Fri, 21 Oct 2005 05:38:56 -0400, Michael Horowitz
What pressure is a coated fabric subjected to to determine if it has
deteriorated? - Mike
mike
I have seen a guy try to repair a wing that his arm went through just
leaning near it.
you gotta stop pussyfooting around with fabric.
make your hand into a "bird" walk down the side of the aircraft and
whang that finger into the fabric as hard as your finger can stand.
if it ever goes through you just saved yourself from a midair
breakup.
aircraft fabric in serviceable nick is pretty damn resilient. there is
a video somewhere of a kid at oshkosh bouncing on a fabric wing like a
trampoline. I'm pretty sure it actually didnt damage the wing.
next time you are in flight you should rest your hand against a
section of fuselage fabric. you'll be truely surprised at how much it
moves around.
fabric safety isnt about "its just 1 pound over the minimum strength
so I'll get another 3 months and 2 days out of it" its about making
sure that in turbulence at VNE in a steep turn nothing even looks like
coming adrift.(thats what you need to be testing for)
if you are buying an aircraft and the owner hasnt the confidence that
it will withstand a robust "birding" then that guy has just admitted
something and you should turn tail and walk away.
I get asked on occasion about fabric testing since I fly a fabric
covered aircraft (among a field which is overwhelmingly aluminium) and
I demonstrate a robust birding to the point that the guy winces at the
possible consequences. I'm actually only testing the Stits fabric to
about half it's strength. If it ever breaks he's just saved my neck.
have a look in AC43-13 at the table on page 2-2.
56psi if vne over 160mph
46psi for slower aircraft.
....but dont kid yourself that those figures may always be safe.
Stealth Pilot
Old October 22nd 05, 07:29 PM
Michael Horowitz
Thanks for the pointer; I"ll give her a look.
I don't think I could run from an irate seller, so I'll probably end
up leaving the testing to an A&P - Mike
mike
leaning near it.
breakup.
moves around.
Stealth Pilot
Old October 23rd 05, 11:45 PM
Michael Horowitz
Cy -
When an A&P does a test, does he have to be prepared to repair any
damage he might do i.e. crack the paint or punch a hole? - Mike
"Cy Galley" wrote:
Look in AC 43.13-1B for fabric testing parameters.
Old October 24th 05, 01:20 AM
Cy Galley
The beauty of the Maule tester is that there isn't a hole IF the fabric
passes. There can be some very minimal paint damage which is easily fixed.
If the hole punches below the minimum level, then the fabric should be
removed and replaced as it doesn't meet safe strength levels. If one
continues the test to a higher level until it punches a hole, just a drop
of paint to fill the hole can be used.
"Michael Horowitz" wrote in message
Cy -
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
Maule Turbine kevin Owning 16 August 4th 03 10:49 PM
