#31
Not a data error? If the pilot doesn't identify the airport I may have to
ask him where he's going. If he does identify it and it's not the airport I'm going to I can ignore him. The location is important data. Correct. Not a data error (more precisely, not an indication that what was understood is different from what was transmitted). It may well be an error on the part of the person transmitting to omit the data, but that's not the kind of error that pertains to "zero two". Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#32
![]() "Jose" wrote in message . .. "Podunk traffic, Waco niner eight zero one victor, entering downwind runway two ZERO, stop-and-go, Podunk." He's actually coming the other way, head on to you who hears "runway two, stop and go..." Nope, there wasn't enough room between "runway" and "stop" for "two zero". He definitely said "downwind runway two, stop-and-go". There was no zero. I suppose you don't, and that's the argument for omitting the leading zero. Further, you could hear it correctly and transpose it in your own mind. Which one trumps the other? I don't think either is trump. Do what other pilots expect to hear, whether by local practice or AIM. Non-use of the leading zero trumps the use of it, no question about it. Note that all of the scenarios used to support the use of the leading zero rely on improper phraseology. If proper phraseology is used the leading zero provides nothing positive, but if it is used it creates the possibility for confusion as it can be transposed with the other digit. That possibility is not limited to runway 2/20 either, as the field may have an intersecting runway it could be confused with, such as runways 1/19 an 10/28. Bottom line, the leading zero should not be used. |
#33
I would simply ask north or south.
The garbling prevented my distinguishing between "zero two" and "two zero," so I surely wouldn't have been able to distinguish "north" from "south." vince norris |
#34
He definitely said "downwind runway two, stop-and-go". There was no zero. Yes, but =she= (the next week) spoke slower, and with a more varied cadence. Non-use of the leading zero trumps the use of it, no question about it. Well, the discussion here shows that there =is= some question about it, just not in your mind. I tend to agree with you that non-use is probably better. However, it is not without benefit. As for being nonstandard, that's just a matter of changing the standard. Elsewhere they use a different standard, but the laws of physics are the same. That possibility is not limited to runway 2/20 either, as the field may have an intersecting runway it could be confused with, such as runways 1/19 an 10/28. Good point. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#35
Jose wrote:
As for being nonstandard, that's just a matter of changing the standard. Elsewhere they use a different standard, but the laws of physics are the same. correct. Since the US does allow non-US registered airplanes to land in the US, does it make sense to follow international standards. Since the AIM is not regulatory, it makes sense to conform to international standards. Instead the FAA has decided to do as they see fit and not give a damn about international standard. For this, I don't see anything wrong with following international standard as international aircraft can misunderstand the US phraseology. BTW, I've heard many complaints from non-US pilot saying US pilots use way too much non-international standard phraseology making it hard to understand and dangerous for when US pilots fly abroad. Gerald Sylvester |
#36
Gerald Sylvester wrote:
Instead the FAA has decided to do as they see fit and not give a damn about international standard. As have the aviation boards of every other country, as far as they can. It's the only way they can keep their turf. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
#37
BTW, I've heard many complaints from non-US pilot saying US pilots use way too much non-international standard phraseology making it hard to understand and dangerous for when US pilots fly abroad. The main problem with US pilots is that they often speak some undefinable mumblejumble instead of English... Stefan |
#38
Yeah, or even being able to distinguish "landing from the south" vs
"landing to the south" ![]() |
#39
![]() Since when did US prevent foreign-registered aircrafy from landing in the US? Can you cite specific examples of US pilots phrasology causing dangerous conditions? Gerald Sylvester wrote in : correct. Since the US does allow non-US registered airplanes to land in the US, does it make sense to follow international standards. Since the AIM is not regulatory, it makes sense to conform to international standards. Instead the FAA has decided to do as they see fit and not give a damn about international standard. For this, I don't see anything wrong with following international standard as international aircraft can misunderstand the US phraseology. BTW, I've heard many complaints from non-US pilot saying US pilots use way too much non-international standard phraseology making it hard to understand and dangerous for when US pilots fly abroad. Gerald Sylvester -- Andrew Sarangan CFII http://www.sarangan.org/aviation/ |
#40
Andrew Sarangan wrote:
Can you cite specific examples of US pilots phrasology causing dangerous conditions? no as often it is ignored. Can you imagine if every time non-standard phraseology is used other pilots are requesting clarification? One instance where English was not used was when my friend flying for a major was going into Mexico City. He was the PNF. The PF on the approach made a sharp turn. My friend asked what the turn was for. The PF said the controller told the preceding a/c about a severe windshear alert but the call was in spanish. The other a/c cancelled their approach. If the PF didn't understand spanish, it very well could have been dangerous. Another instance was living in Germany. I was half way through my PPL and went flying with a friend of a friend. Looking back, the guy was a moron. He barely understood English and couldn't copy the clearance nor follow the clearance out of Salzburg and then busted the Class B (I think it is B) MUC airspace due to his lack of English. Although no near miss happened but if the airspace was more dangerous, it certainly could have been bad. Although this is non-US pilots not being fluent in English ATC phraseology, the same happens the other way for sure. Gerald Sylvester |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
