IVO prop dyn. balancing
Old November 9th 05, 03:52 AM
Dave S
Default IVO prop dyn. balancing
Hey Russ... what are you flying and where?
Dave
Houston (EFD), Rotary powered Velocity under construction..
R&R Sherwood wrote:
The blades, being held by only two bolts each, can move (or
swing) chordwise in the hub......
Even with those bolts torqued to spec we had blade movement between the
plates. Fretting was evident on the blade bushings and mating plate
surfaces. Scared us.
When ground testing my auto engine with an old style 3 blade IVO prop, I
took several still photos. Some of the photos appeared to show the blades
advancing or retreating much like that of a helicopter.....not sure if this
was a trick of the camera or actually happening. After about 10 hours of
ground time I found damage to the base of the blades. Now that the engine
is flying with an MT prop I have been unable to duplicate that effect in any
of my photos.
Russell Sherwood
Houston, TX
Old November 9th 05, 07:33 PM
R&R Sherwood
blades
this
of
engine
any
of my photos.
The focal plane shutters used in many good cameras would give
that bent-prop effect. As the shutter gap moved across the plane,
either side-to-side or top-to-bottom, one side or edge of the film was
exposed before the other, so a rotating prop or rotor would be caught
over a rather long time, spread across the film, and would appear bent
or out of phase. I don't know that the IVO would move all that much,
unless it was flexing as well...........
The aperture shutters found in smaller, cheap cameras wouldn't
"bend" rotating stuff.. Were you using the same sort of camera both
times?
Dan
Same camera was used on both props. A Nikon single reflex, the shutter
moves from side-to-side. I bought it new in about 1985....before the
digitals came out.
Russell Sherwood
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
dynamic prop balancing George A. Graham Home Built 2 April 21st 05 01:20 PM
Prop balancing and assorted observations - long Dave Hyde Home Built 10 June 27th 04 01:08 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
