A query for folks here. While discussing bad things that can happen between the chocks, I posited that it's a really bad place to be in a medical emergency, etc. -- based on how long it takes to get on the ground. That brings up the question of how long that time really is.... So: If you are at cruise in Boeing's finest at FL430 & declare an emergency; how fast CAN you be down and stopped? (Or Airbus, for that matter....) a) Assuming ATC can clear a lane, I assume it's a function of how steep a decent you can use without exceeding the max IAS. What are the limits on speed brakes, dropping gear, etc. to dirty things ups? b) It's a big country. I assume if you're over one coast or the other, your decent will cover a radius sufficient to get you to a long-enough runway. But what about over North Dakota, etc? [We'll skip trans-ocean routes.] Will there be cases where you won't use a max-rate decent above because there's no place within that range? I'm looking for realistic numbers here; I welcome any data. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
| 182RG question | Paul Anton | Owning | 11 | May 16th 05 10:45 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question for CFIs | Casey Wilson | Piloting | 11 | February 24th 05 11:29 PM |
| Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 06:09 AM |
| Defining Composites (long) | B Lacovara | Soaring | 1 | September 13th 03 09:04 PM |
