Unclear Clearance
Old November 16th 05, 05:13 PM posted to rec.aviation.ifr
Default Unclear Clearance
"Dave Butler" wrote in message
news:1132150865.836980@sj-nntpcache-5...
What was unclear about it?
Well, the controller thought it was discretionary. That you and she
disagree tends to indicate it's not clear.
I'd never infer discretionary descent unless it was explicitly stated by
the controller.
The controller does not have to state "descend at pilot's discretion" in
order for the descent to be discretionary. A descent clearance with a
crossing restriction is a discretionary descent. A cruise clearance to an
airport without an IAP is a discretionary descent.
I'd say the clearance
unambiguously required vacating 7000 (before amendment).
What amendment? The pilot asked the controller to verify that the descent
was at pilot's discretion and the controller responded in the affirmative.
Old November 16th 05, 05:51 PM posted to rec.aviation.ifr
On 11/16/2005 10:57 AM, three-eight-hotel wrote the following:
Have you considered making a phone call to the controlling facility and
getting there feedback on this clearance and any expectations they
might have had?
Actually, it wasn't that big a deal. I just thought I'd
throw a little meat to the wolves. I was and am tired of
all the bickering under "IFR with a VFR GPS." :-) So ...
something new.
I'm a relatively new IFR pilot and don't get as much practice as I
would like. It's a frustrating feeling, to have been given a
clearance, and try decipher all that you can and cannot do because the
clearance was a little vague. You definitely did the right thing,
asking for clarification.
The part I'm a little unclear on is: "Center, that 4000 was pilot's
discretion, right?" ...... "Right."
How is that different from a cruise clearance? Is it because you are
cleared to decend to 4000 at your discretion, but once you leave the
altitude you can't go back, unless cleared to climb again?
Yes, I think so. But as a practical matter she was about to
lose me both on radar and on comm, so I think she was
effectively giving me the airspace below 7 until she
received my cancellation. I'm sure she didn't have any IFR
aircraft anywhere near me and didn't have any departures
coming out of KCKC.
These groups are great for getting clarification on things we encounter
in the air, but they aren't of much use when you are at 7000 feet and
concerned about picking up a little ice... ;-)
I was in the clear and the deck was thin. No real concern,
but that's why I asked for clarification.
Old November 16th 05, 06:13 PM posted to rec.aviation.ifr
OK.
the controller.
OK, agreed. I'd call those clearances explicitly discretionary.
Yes, exactly. The clearance as originally stated was not for a discretionary
descent. By responding "right" to the pilots question, the controller amended
the clearance and simultaneously demonstrated lack of understanding of the way
clearances are stated. But OK, I see your point.
Old November 23rd 05, 03:52 AM posted to rec.aviation.ifr
* Steven P. McNicoll :
Hm. I'm lacking any real world experience, but in our little wannabe Sim
world (VATSIM) I'm used to crossing restrictions like "XYZ, descend FL120
(to be) level(ed) at FIX" which is to be interpreted as "start descent
now with at least 1000fpm and be at FL120 latest at FIX". This is for
Europe and confirmed to be real-world compatible by several real-world
ATC controllers here. Now I happen to like "flying" in US airspace, where
instructions like "XYZ, cross CEDES at 11000ft" are used. Is that to be
taken analogue to European interpretation to start descending to 11000ft
_now_, or to be taken as "descend 11000ft at own discretion"? If the
latter, does ATC expect a report like "leaving FL240 for 11000" if not
explicitly requested? What is the US equivalent of the European
clearance to "descend now to X with 1000fpm or more, to be level at
FIX"? Is there any at all (short of a full "descend and maintain 11000ft,
1000fpm or more, cross CEDES at level")?
The European expectation of immediate descent with at least 1000fpm v/s
might mean that I do reach 11000ft earlier than CEDES - some folks
argued that "cross X at Y" means that I should carry out my descend so
that I reach the target altitude no later AND NO EARLIER than the fix.
Which would mean that if ATC gives the instruction too early, I would
have to descend with considerably less than 1000fpm, in case the
"cross X at Y" is to be interpreted in this way.
Comments? Insights?
Best regards,
Daniel
Old November 24th 05, 03:19 PM posted to rec.aviation.ifr
While flying at 3000 ft, I get a clearance that says "maintain 3000
until established on the localizer, cleared ILS...." If I am already
at 3000, what exactly is the purpose of "maintain 3000"?
The purpose of the "maintain 3000" is to caution the pilot that the
approach clearance does not imply that he can start descending right
away.
In this context, I take the "maintain 3000 until established" to mean
"maintain at least 3000 until establshed".
If it were an instruction to descend, it would have been issued as
"descend and maintain".
Old November 24th 05, 04:00 PM posted to rec.aviation.ifr
away.
"Maintain" means "don't go higher or lower. There may be terrain lower.
There may be traffic higher.
Jose
He who laughs, lasts.
Old November 25th 05, 06:49 AM posted to rec.aviation.ifr
On 24 Nov 2005 07:19:39 -0800, "Andrew Sarangan"
away.
Another way of thinking of about it would be a clearance that says,
"Descend to and maintain 3000 until established, cleared for the
approach."
Maintain 3000 until established is what you get when you are alread at
the altitude ATC wans.
www.rogerhalstead.com
  #28
Old November 25th 05, 04:02 PM posted to rec.aviation.ifr
Actually, "maintain 3000 until established" is what you get even if
you are at a different altitude. This is the cause of the confusion, as
the original poster to this thread mentioned.
  #29
Old November 27th 05, 09:46 PM posted to rec.aviation.ifr
Comments? Insights?
From the (US) AIM:
e. If the altitude information of an ATC DESCENT clearance includes a
provision to "CROSS (fix) AT" or "AT OR ABOVE/BELOW (altitude)," the manner
in which the descent is executed to comply with the crossing altitude is at
the pilot's discretion. This authorization to descend at pilot's discretion
is only applicable to that portion of the flight to which the crossing
altitude restriction applies, and the pilot is expected to comply with the
crossing altitude as a provision of the clearance. Any other clearance in
which pilot execution is optional will so state "AT PILOT'S DISCRETION."
Here are three examples, also from the AIM, which I believe cover the
various nuances:
EXAMPLE-
3. "United Four Seventeen, cross Lakeview V-O-R at or above Flight
Level two zero zero, descend and maintain six thousand."
NOTE-
3. The pilot is authorized to conduct descent at pilot's discretion
until reaching Lakeview VOR and must comply with the clearance provision to
cross the Lakeview VOR at or above FL 200. After passing Lakeview VOR, the
pilot is expected to descend at the suggested rates until reaching the
assigned altitude of 6,000 feet.
EXAMPLE-
4. "United Four Seventeen, cross Lakeview V-O-R at six thousand,
NOTE-
4. The pilot is authorized to conduct descent at pilot's discretion,
however, must comply with the clearance provision to cross the Lakeview VOR
at 6,000 feet.
EXAMPLE-
5. "United Four Seventeen, descend now to Flight Level two seven zero,
cross Lakeview V-O-R at or below one zero thousand, descend and maintain
six thousand."
NOTE-
5. The pilot is expected to promptly execute and complete descent to FL
270 upon receipt of the clearance. After reaching FL 270 the pilot is
authorized to descend "at pilot's discretion" until reaching Lakeview VOR.
The pilot must comply with the clearance provision to cross Lakeview VOR at
or below 10,000 feet. After Lakeview VOR the pilot is expected to descend
at the suggested rates until reaching 6,000 feet.
Also, so far as the "proper" rate of descent or climb is concerned:
Descend or climb at an optimum rate consistent with the operating
characteristics of the aircraft to 1,000 feet above or below the assigned
altitude, and then attempt to descend or climb at a rate of between 500 and
1,500 fpm until the assigned altitude is reached.
Hope this helps.
  #30
Old November 28th 05, 03:30 AM posted to rec.aviation.ifr
* Ron Rosenfeld :
From the (US) AIM:
Thank you very much for citing the relevant regs. Is this stuff available
online for future reference?
OK, that's clear.
various nuances:
Yep, covered my questions. Thanks.
six thousand."
NOTE-
Hm... interesting. "optimum rate consistent with the operating
characteristics of the aircraft". This is fuzzy.
The most economically way to descend a jet is at near idle thrust,
tactically. But strategically, that's only true if I'm on my computed
economic descent path. So if ATC orders me earlier than reaching my ToD
to "descend now FL270", at what rate do I descend? "optimum rate"
would be very shallow and be not quick enough for the controller who
wants to get me out of the way of something. Should I descend at near
idle thrust? But that would bring me down much quicker than strategically
economic, as I have to fly a longer distance on a suboptimal low flight
level.
I guess this is why in Europe a descent/climb instruction implies
(unwritten rule) "1000fpm or more" - and actually the FMS of a 737NG
seems to do exactly that (at least in the simulation that I have) when
you initiate a VNAV descent earlier than ToD via the "DES NOW"
function. It descends with 1000fpm until it either reaches the target
altitude dialed in the MCP, or it crosses the computed optimum vertical
descent path at which point it raises the rate of descend and lowers
the thrust, in order to maintain the optimum descent path.
Best regards,
Daniel
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Taxi Clearance Ron Rosenfeld Instrument Flight Rules 27 September 29th 05 01:57 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
