Taxi Clearance
Old September 24th 05, 01:01 PM
Ron Rosenfeld
Default Taxi Clearance
I just noticed this today:
AIM 5-2-2. Taxi Clearance
Pilots on IFR flight plans should communicate with the control tower on the
appropriate ground control or clearance delivery frequency, prior to
starting engines, to receive engine start time, taxi and/or clearance
information.
In the Azores, Portugal, when I checked out at a local flying club, it was
mandatory to contact the control tower prior to engine start, even when
flying VFR. (And it was mandatory to receive a clearance to "start
engines" before doing so).
However, in the US, I was not taught, nor have I ever called in "prior to
starting engines" unless that requirement was explicitly stated on the ATIS
(as it has been occasionally at KBOS).
Is this a holdover from former times? Or something else altogether?
Old September 24th 05, 05:13 PM
Bob Gardner
I think this is aimed at the turbine crowd, not the piston pilots, although
the AIM does not make any distinction.
Bob Gardner
"Ron Rosenfeld" wrote in message
information.
ATIS
Old September 24th 05, 06:23 PM
TMG
In Europe start up permission is always mandatory at controlled airfields.
Not just for turbines, also for piston...
"Bob Gardner" wrote in message
although
Bob Gardner
information.
was
to
ATIS
Old September 24th 05, 06:29 PM
Steven P. McNicoll
"TMG" wrote in message
What's the reasoning behind that, if any?
Old September 24th 05, 09:00 PM
I was learning to fly at the Ramstein Aero Club, at Ramstein AB, West
Germany when this policy was started, sometime between 1984 and 1986. I
don't know for certain why they started making everyone from our F-4E
Phantom pilots on down to student pilots in Piper Tomahawks request
permission to start engines from the tower, but I'd heard it was intended as
a security measure to help prevent terrorists from attempting to steal an
aircraft. That would be Red Army Faction, not Al Queda, way back then. I'd
also thought back then that it was just a local policy at Ramstein, or
perhaps throughout USAFE, but from the orginal posting in this thread I see
that it was impemented all over Europe.
Scott Wilson
airfields.
Old September 25th 05, 01:15 AM
Lynne
Europe uses a system of airport and airway slots to avoid delays. If
your airway or airport slot has expired, a new one must be
renegotiated. Once you taxi in Europe, you takeoff as soon as you get
to the runway. So to avoid delays at the end of the runway, one must
call pre-start for clearance and to permit ATC coordination.
Lynne
Old September 25th 05, 01:29 AM
Mike Rapoport
ink.net...
airfields.
They seem to have a rigid system of airways between city pairs so ground
holds are fairly common.
MU-2
Old September 25th 05, 09:20 PM
Patrick Mayer
more important: the slots at the airports! Sometimes, it's so crowded they
don't let you take off because they know traffic at your destination is too
heavy for you to fit in :-/
Pat
Old September 24th 05, 07:22 PM
Newps
Poor souls.
Old September 25th 05, 02:19 AM
Russ MacDonald
I teach my students to call before engine start to get their clearance
(controlled fields). You are allowed to call up to two hours before your
proposed departure, so why waste your gas waiting for the clearance to be
issued?
However, I have yet to ever receive a 'start time' from any clearance
delivery. They just say 'contact ground when ready to taxi'.
Also, if you have a handheld, you can get your clearance using it instead of
using your aircraft battery, so on that cold day, you will have every ounce
of juice the battery can deliver for the start.
Russ MacDonald
Bob Gardner
information.
was
ATIS
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Touch and Goes versus Full Stop Taxi Backs Kevin Dunlevy Piloting 81 September 18th 05 09:26 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
