If the speed of sound is faster in denser air..
Old December 17th 05, 07:41 PM posted to rec.aviation.piloting
Default If the speed of sound is faster in denser air..
On 17 Dec 2005 09:45:07 -0800, "nrp" wrote in
.com::
"in an ideal gas the sonic velocity depends only on the molecular
weight and the absolute temperature (degF + 460), and is proportional
to the square root of that absolute temperature".
In which units does that equation provide the sonic velocity?
More he
http://roger.ecn.purdue.edu/~aerodyn...Lecture06.html
Old December 17th 05, 08:07 PM posted to rec.aviation.piloting
When I took thermo, there were only ft lbs, BTUs, and lbm. It was a
lot simpler before Metric became PC. (I wonder how we happened to keep
seconds?)
Old December 17th 05, 08:09 PM posted to rec.aviation.piloting
"nrp" wrote in message
I found the MKS system to be simpler.
Old December 17th 05, 08:17 PM posted to rec.aviation.piloting
seconds?)
You must be REALLY old as the SI system has been around at least since
1875. :-)
Matt
Old December 17th 05, 08:41 PM posted to rec.aviation.piloting
On 17 Dec 2005 12:07:43 -0800, "nrp" wrote in
.com::
So you don't know if your equation expresses sonic velocity in knots
or MPH?
Old December 17th 05, 08:56 PM posted to rec.aviation.piloting
In hotter air the molecules can move faster, so they carry disturbances
(sound waves) faster.
In denser substances such as water and steel, the molecules do not move
far from a central point so the increased temperature does not give
them the opportunity to transmit the sound disturbance at a faster rate
when heated.
However, because of the greater density and the fact that molecules are
closer together in water and steel than in air, sound does travel
faster in water and steel than in air. The closer the molecules are
together, the more quickly a disturbance is transmitted from one
molecule to another.
.com::
or MPH?
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
How Aircraft Stay In The Air Sarah Hotdesking Military Aviation 145 March 25th 04 05:13 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Kestral 1000 Wind Speed Meter NEW IN BOX Cecil E. Chapman Products 0 November 7th 03 06:56 PM
