If the speed of sound is faster in denser air..
Old December 17th 05, 05:07 AM posted to rec.aviation.piloting
Default If the speed of sound is faster in denser air..
.... why does an increase in temperature mean an increase in the speed of
sound?
That's got me confused. Hotter = less dense.
Thanks in advance.
Old December 17th 05, 05:32 AM posted to rec.aviation.piloting
"xerj" wrote in message
sound?
Because density is not the sole determining factor for the sound of speed
through some medium.
Old December 17th 05, 05:41 AM posted to rec.aviation.piloting
Got it.
Found a page that explains it :-
http://www.newton.dep.anl.gov/askasc...0/phy00826.htm
"Peter Duniho" wrote in message
sound?
Old December 17th 05, 01:51 PM posted to rec.aviation.piloting
sound?
Thanks in advance.
The speed of sound varies with temperature alone.
Old December 17th 05, 02:17 PM posted to rec.aviation.piloting
In article et,
sound?
Thanks in advance.
The speed of sound varies with temperature and type of medium.
Bob Noel
New NHL? what a joke
Old December 17th 05, 03:07 PM posted to rec.aviation.piloting
Bob Noel wrote:
Thanks in advance.
The speed of sound in air varies almost solely with
temperature. For other types of mediums, the temperature is
less of a factor. The general formula for the speed of sound
is the density divided by the bulk modulus. The issue is that
with gases the other variables in the equation all cancel each
other out.
In water for example, density is a MAJOR factor. The speed
of sound in salt water is faster than fresh water in addition
to temperature.
Old December 17th 05, 04:02 PM posted to rec.aviation.piloting
m...
Bob Noel wrote:
Thanks in advance.
other out.
to temperature.
You're mixing apples and oranges. Water (H2O) does not equal salt water
(H2O + NaCl). They are two different media. Just as air is a nominal mix
of N + O + a few other gasses. Change that mix and it's a different media
with a different gamma and bulk modulus (R). So your density change is
really a change in media.
If the media doesn't change, density doesn't have an effect on the speed of
sound. Changing the media changes the gamma and R; but for any one specific
media, only temperature will cause a change in the speed of sound.
Gerry
Old December 17th 05, 04:29 PM posted to rec.aviation.piloting
Ron Natalie wrote:
Bob Noel wrote:
Thanks in advance.
other out.
to temperature.
Commpressibility is the major factor. Water isn't very compressible
and transmits sound quite well, but air is and sound dissipates.
Frequency dispersion which has to do with how well various frequencies
are transmitted, affects how much the receiver will understand what is
being sent. It is an exceedingly complicated phenomenom -- ask any
sonar designer or a Navy weapons person.
Old December 17th 05, 04:36 PM posted to rec.aviation.piloting
"Bob Noel" wrote in message
The medium under discussion per the subject line is air. Since this is a
piloting group it can be reasonably assumed to be air at temperatures found
in the atmosphere. Air at atmospheric temperatures behaves as an ideal gas
and the speed of sound in an ideal gas is a function of temperature.
Old December 17th 05, 05:45 PM posted to rec.aviation.piloting
Deriving the sonic velocity is one favorite question for the final exam
of mechanical engineering thermodynamics courses. From my old
textbook:
"in an ideal gas the sonic velocity depends only on the molecular
weight and the absolute temperature (degF + 460), and is proportional
to the square root of that absolute temperature".
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
How Aircraft Stay In The Air Sarah Hotdesking Military Aviation 145 March 25th 04 05:13 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Kestral 1000 Wind Speed Meter NEW IN BOX Cecil E. Chapman Products 0 November 7th 03 06:56 PM
