I read about a homebuilder making his own static wicks using carbon fiber
and heat shrink. He attached them to a screw. He threaded copper tubing, epoxied it in with wiring that went to the engine mount. Then he just screwed in the wicks. Anyone have any thoughts on this, any other ideas? |
It is a hell of a lot easier to solder a 100K-1Meg resistor to a solder lug
with very short leads, clip the other end of the resistor short and either file the open end to a point or solder a sewing pin end to the open end to give that sharp point. Shrink sleeve the whole works except for a tiny bit of the pin tip and the area where you are going to put a screw through the solder lug to electrically attach it to the airframe. Works out to about two cents of material per wick. Google past issues of Kitplanes; I wrote this up the better part of fifteen years ago or so. Jim "keepitrunning" wrote in message ... I read about a homebuilder making his own static wicks using carbon fiber and heat shrink. He attached them to a screw. He threaded copper tubing, epoxied it in with wiring that went to the engine mount. Then he just screwed in the wicks. Anyone have any thoughts on this, any other ideas? |
RST Engineering wrote:
It is a hell of a lot easier to solder a 100K-1Meg resistor to a solder lug with very short leads, clip the other end of the resistor short and either file the open end to a point or solder a sewing pin end to the open end to give that sharp point. Shrink sleeve the whole works except for a tiny bit of the pin tip and the area where you are going to put a screw through the solder lug to electrically attach it to the airframe. Works out to about two cents of material per wick. Google past issues of Kitplanes; I wrote this up the better part of fifteen years ago or so. Jim, Question: Why do you need the resistor? Since you want to get rid of charge, why not just a sharp piece of wire? Matt |
Matt --
Because you want to get rid of the charge quietly, without any sharp transients that will cause RFI. You can come at the answer from an RC time constant angle, from a total energy (power dissipation) angle, from a couple of more exotic angles. I myself like to think of it from the total energy point of view. That charge starts out at some large potential. In travelling through the resistor to get to the pin point, moving charge is the definition of current, which by Ohm guarantees that there will be a power loss going through the resistor, and hence a lower voltage to dissipate when it does get to the pin point. If you want to come at it from the RC time constant point of view (being that the airplane is the conductor and the atmosphere is the capacitor) the R of the RC is going to round the edges of those transients nicely. YOu can't use too high a value resistor or the charge won't even see the pin point. You can't use too low a value resistor or the charge won't lose any power in gettint to the pin point. How did I come up with a value of 100K to 1M? Simple. Back when I worked for the airline, there was a spec on the static wicks on all the Boeings and on all the McDonnells that said the static wicks should measure between 100K and 1M from the attach point to the pin point(s). I figured if it was good enough for McBoeing at 500 knots, it was good enough for Jim at 100 knots. Jim "Matt Whiting" wrote in message ... RST Engineering wrote: It is a hell of a lot easier to solder a 100K-1Meg resistor to a solder lug with very short leads, Jim, Question: Why do you need the resistor? Since you want to get rid of charge, why not just a sharp piece of wire? Matt |
Matt -- Because you want to get rid of the charge quietly, without any sharp transients that will cause RFI. You can come at the answer from an RC time constant angle, from a total energy (power dissipation) angle, from a couple of more exotic angles. I myself like to think of it from the total energy point of view. That charge starts out at some large potential. In travelling through the resistor to get to the pin point, moving charge is the definition of current, which by Ohm guarantees that there will be a power loss going through the resistor, and hence a lower voltage to dissipate when it does get to the pin point. If you want to come at it from the RC time constant point of view (being that the airplane is the conductor and the atmosphere is the capacitor) the R of the RC is going to round the edges of those transients nicely. YOu can't use too high a value resistor or the charge won't even see the pin point. You can't use too low a value resistor or the charge won't lose any power in gettint to the pin point. How did I come up with a value of 100K to 1M? Simple. Back when I worked for the airline, there was a spec on the static wicks on all the Boeings and on all the McDonnells that said the static wicks should measure between 100K and 1M from the attach point to the pin point(s). I figured if it was good enough for McBoeing at 500 knots, it was good enough for Jim at 100 knots. Thanks, Jim. I simply reasoned that with sufficient wicks and given the high conductivity of the airframe, I didn't think you would likely ever build up enough charge to get an "impulse" discharge. I figured the charge would quietly leak off into the ether, but I guess if the radius of the point isn't small enough, it will take a fair bit of charge to ionize the air enough to get a discharge. Matt |
Thanks for the great info.
Gary |
On Fri, 30 Dec 2005 19:31:17 GMT, Matt Whiting
wrote: RST Engineering wrote: Matt -- Because you want to get rid of the charge quietly, without any sharp transients that will cause RFI. You can come at the answer from an RC time constant angle, from a total energy (power dissipation) angle, from a couple of more exotic angles. I myself like to think of it from the total energy point of view. That charge starts out at some large potential. In travelling through the resistor to get to the pin point, moving charge is the definition of current, which by Ohm guarantees that there will be a power loss going through the resistor, and hence a lower voltage to dissipate when it does get to the pin point. If you want to come at it from the RC time constant point of view (being that the airplane is the conductor and the atmosphere is the capacitor) the R of the RC is going to round the edges of those transients nicely. YOu can't use too high a value resistor or the charge won't even see the pin point. You can't use too low a value resistor or the charge won't lose any power in gettint to the pin point. How did I come up with a value of 100K to 1M? Simple. Back when I worked for the airline, there was a spec on the static wicks on all the Boeings and on all the McDonnells that said the static wicks should measure between 100K and 1M from the attach point to the pin point(s). I figured if it was good enough for McBoeing at 500 knots, it was good enough for Jim at 100 knots. Thanks, Jim. I simply reasoned that with sufficient wicks and given the high conductivity of the airframe, I didn't think you would likely ever build up enough charge to get an "impulse" discharge. I figured the charge would quietly leak off into the ether, but I guess if the radius of the point isn't small enough, it will take a fair bit of charge to ionize the air enough to get a discharge. Even with a fine point and no resistor you are likely to hear something like a whistle rising in pitch ending in a "pop!" over the radio. Or, it just may be a hissing sound that continues, and continues, and continues, with no pop. In the Deb, which has no static wicks, I had every radio go deaf. ADF, VOR, and communications. I shut the master off, counted to 10, turned it back on and they all went back to working... for a few minutes. Once out of the rain and well away from the storm everything worked fine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Matt |
Shocking windshield a sign you need static wicks? | Ben Jackson | Owning | 2 | June 9th 05 10:20 PM |
Four Static Ports! Which to Use? | John DeRosa Sky Soaring Chicago IL | Soaring | 3 | May 18th 04 04:55 PM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
The Great Static Wick Fraud | Craig Prouse | Owning | 3 | September 5th 03 01:54 AM |
Static in KX-165A | Chad Lemmen | Owning | 3 | July 21st 03 09:57 PM |
